I've purchased the cable required for programming my KG-935G Plus and downloaded the program, but can't seen to figure out how to connect them. I'm using COM3 and the greem litght blinks when I attempt to read the radio configuration, but I get an error that says "Please check all connections and communication port setting." I've also downloaded the USB driver and executed the install.exe, but I'm not seeing that it was installed. Still just see the USB Serial Port (COM3) under Ports in Device Manager. I did not see any port setting so I'm using the default 9600, 8, 1 and None. Does anyone know what I'm failing to do?
