WSAA635
Everything posted by WSAA635
  1. The BTech GMRS v2(same basic radio as the Baofeng UV-82) can go to vfo mode by holding down the menu button when you turn on the radio but it doesn't unlock it.
  2. I went into vfo mode and put my local NOAA channel in so when I switch to vfo I'll get NOAA. I had hopes there'd be a single button to press and hold like they have for FM radio. I'd bet there's someway yo unlock it, just need to figure out the key/button combo to press. Maybe someone will figure it out and post it.
  3. Also, not to change the subject but how do I "toggle" NOAA? No where in the manual does it tell how to do this. I see the FM button for FM broadcast radio but NOTHING for NOAS Weather radio.
  4. Not asking if I'm "allowed", I want to know if there's a hack (Mars/Cap mod, unlock, whatever you want to call it)to be ABLE to transmit on 8-14 and on VHF/MURS frequencies?
  5. Title says it all. Can this radio be unlocked? I'll receive VHF and UHF but in it's locked state it'll only transmit on channels 1-7 and 15-22 GMRS plus the repeater channels. You can't transmit on GMRS/FRS 8-14 or any VHF channels like MURS. It'd be nice to be able to transmit on a wider channel range for emergency use if needed.
  6. So when I Tx the +5 is added to the 462MHz and the Rx is on the channel that listed, i.e. 462MHz. Ok, I've got things set right then. Thanks.
  7. So the factory settings in ALL my radios are wrong then? This is the factory settings for repeaters from my BTech 20v2 and it's showing Tx on 462MHg.
  8. Just to be clear, when using a repeater you transmit on 462MHz and the +5 offset lets you receive on 467MHz. I just want to make sure I've got this right.
  9. I always disable that feature. One channel at a time is more than enough for me.
  10. Checked my truck radio, didn't have an AUX so I canceled the cable. Also, I'm sure that big ol' truck hood will give me plenty of ground plane.
  11. Well, that wasn't all that hard. Power port worked with the radio so no hot wire needed. Figured out a good way to mount the antenna and run the cable. Used 3M VHB double side tape to mount the bracket. Programed it with 1-7(low power)and 15-22(high power)plus the 8 repeater channels, 3 of which had tones so I can use them AND I got my 4 DPS channels(scan only)so I can hear what's happening on the roads. I think this'll work out fine for my needs. I did order a speaker cable so I can plug into my stereo's AUX port to use those speakers if needed.
  12. https://www.amazon.com/gp/aw/d/B07PQVPNLQ?psc=1&ref=ppx_pop_mob_b_asin_title 04 Dodge Ram on the hood and my shoe size is a 13 wide, LOL.
  13. I wanted to get a radio for the truck for a while now. I ended up getting a BTech 20v2 and a "Ghost" antenna for it. With any luck a buddy of mine will come over tomorrow to help me do the install. I had to order the BTech cable to get CHIRP to read the radio. I removed channels 8 through 14 since the radio won't transmit on those channels because the power settings can't go low enough for FCC requirements. 1-7 are hard set to "low" power which is supposed to be 5 watts and 15-22 along with repeater 15-22 are high power which should be 20 watts but from YouTube tests I've seen is closer to 14 watts. If all goes well I'll be mobile by this time tomorrow.
  14. You can use the KG-UVD1P profile in CHIRP to program channels with the 805g but you'll have to do the settings from the buttons on the radio which isn't that big of a deal since IIRC there's on 22 of them and most of them you'll skip over.
  15. The Talkpod A36 Plus has Airbands and has worked better for me than the H3's I sent back.
  16. My entire take on this "Type Approved" deal is that a person should buy the radio of THEIR choice(Type Approved or Not), program it with the channels they want to use and enjoy talking to family and friends while they're out shooting, off roading, hiking or whatever. As long as you're not setting up drug deals or talking about bringing the next load of illegals across our wide open Southern Border then people just need to worry about themselves and not worry about what others do.
  17. This reminds me of "Street Legal" with cars/trucks. There are plenty of folks driving "street legal" vehicles that break the law with them on a daily basis. Then there are those who modify their vehicles with different parts and accessories that makes their car or truck NOT street legal but they still follow the laws and rules of the road while driving. Who should we really be pointing our fingers at, someone with a "Type Accepted" radio who broadcasts out of band and acts like a jerk when they're on the air or someone who's not using a type accepted radio but stays within their licensed frequencies and plays nice when they're on the air.
  18. I'm sure I could fine a local News/Talk FM Broadcast station to get local weather reports. My main question is WHY something as important as NOAA doesn't have at least a couple UHF channels? Not trying yo start a big debate over which radio to get or anything.
  19. Notice I didn't say "transmit" on 400-470MHz, my KG-805g will RECEIVE on any 400-470MHz channel, I can only transmit on 462/467MHz. With NOAA I only care about receiving. I have radios I use for GMRS too that'll get NOAA, FM Broadcast, MURS and even one that gets Airband but most of those are unlocked HAM radios. With something like the 805g(which will get broadcast FM radio) or the 905g(which will only receive 400-470MHz) there's no NOAA channels that I can use.
  20. Ditto, with Linux we generally don't need anti-virus. When you run programs in WINE though you DO open your system up to Windows Issues.
  21. For some reason NOAA Weather channels are all VHF. Why no UHF channels so GMRS only radios that'll only get 400-470MHz frequencies could get weather info too? Is there anyway to get NOAA to add some UHF channels?
  22. I have the TDR turned off on my 82's and they've tested at over 6 watts output(on medium, high gives lower output)and they work well with the $8 Wouxun dual band antennas I have on them. For Air Band I have an A36 Plus that works well. Sometimes FM Broadcast radio is spotty as to whether it comes on but most times I can get it to work. For my hunting radio I'll probably use my UV-5r with a stubby antenna on MURS 5(aka Green Dot) set on high power so I'll get a little better range. We never get more than a few hundred yards apart when dove hunting. Further than I'd want to yell but too close to make a cell phone call, especially if we don't hsve cell service.
  23. I'm honestly struggling with why I should keep this radio when it doesn't do anything that my $20 UV-82 won't do. Yes, it seems to be a nice radio but is it $150 nice? I could almost pick up 2 805g radios for what I have into this one radio. I don't know, I'll probably end up keeping it just to have a Yaesu radio in my collection but truthfully I'll probably use my UV-82 or 805g more.
  24. There's no provision to have a different TX freq. vs a RX freq. Also, it's NOT an Issue with my other unlocked HAM radios, the UV-5r, UV-82 and A36 Plus(I got the HAM version and unlocked it vs the GMRS version) all let me set the Duplex to "off" to stop transmitting. GMRS vs HAM makes no difference, it's all in how the radio handles frequencies and what options you're given. In the mean time I just removed the DPS channels so I'll not use the FT-65r as a scanner. I can use one of my other 3 radios I have set up for DPS scanning if I want to listen to all the stuff going on locally.
  25. I guess it just takes diving in and doing it so that you'll learn it. It's like anything, it's going to be difficult until you do it a few times and get the hang of it.
