dmcpher326
dmcpher326's Achievements
  1. what does this mean and how n I get rid of it??? I try to save and overwrite the old file and I get an error saying it can't with this as the solution.... System.UnauthorizedAccessException: Access to the path 'C:\Program Files (x86)\GM5R CPS\unins000.dat' is denied. at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath) <configuration> <system.windows.forms jitDebugging="true" /> </configuration>
  2. I have two boofwang UV-5G plus radios. Up till now, they have been good radios. Now, when turned on, neither radio seems to transmit or receive. I get the power bar, the freq off set change, but even with one radio setting next to the other, there is nothing on either radio. suggestions, or have I now got to bricks??? thanks David
  3. this is weird or just me. Went to chnl 30, freq 462.7250...put in NO offset, NO DCS, NO R/T-CTCSS but the radio added the + offset and I can't get rid of it. Does this chnl/freq automatically ad the offset? If I switch to VFO, it isn't there, just under chnl mode....Radio is a UV-5G plus... Ideas? Thanks David
  4. that worked, thanks....thought I bought a brick...WSAL924 or KC9UBR... David
  5. I just received this radio. Have the cable for it so I connected it up to the computer. Found the correct comm port and read the radio. So far so good. But when I tried WRITING back to the radio, it said "completed" on the computer but now it has a password set..I DID NOT SET A PASSWORD. Is there a way to get this corrected to no password? I have no idea what the password is... Thanks David
