WSBP738
WSBP738's Achievements
  1. No it's narrow band the mic hole was to small. Sent from my SM-A156U1 using Tapatalk
  2. Well you were right the hole opening was to small. I took the mic apart and made the hole a little bit bigger and of course it made a huge difference. Thanks again for the advice! Sent from my SM-A156U1 using Tapatalk
  3. I have a Radioddity DB20-G. The antenna is a UT72G Nagoya mag base and a pyramid powersupply. I am using this as a base in an apartment on the 2nd floor. I have the antenna setting on the power supply near my sliding glass door. I'm hitting the repeater, but the person on the other end says I'm very quiet. My question is, I have a baking pan but is not magnetic but it is aluminum. Will that still work as a ground plane? Sent from my SM-A156U1 using Tapatalk
