Crash1
Everything posted by Crash1
  1. "With the current firmware and v2.02 of the Radioddity CPS software, Channels 31-54 should be DIY." So are you saying with the FW update you are able to set TX Frequencies? I guess you can Rx HAM frequencies but no TX and the advertising and FCC approval looks like you should be able to hit repeaters?l.....(but Tx is disabled).
  2. Thanks so much....I don't know why it's so hard to find....The site didn't even show GM models when I went through my searches....to impatient??? Not much to the link though....if you look at download it takes you to the main page.... Anyway thanks for the link! Have a great day...
  3. Actually I would RTFM IF I could find one and I've searched their site....heck I can't even find the GM-15PRO on baofengradio but I did find the manual for the radio...
  4. I've emailed BAOFENG and requested since I find links that take me to their radios (but it looks like they send you to Chirp which does NOT support the GM-15PRO. Doesn't BAOFENG have it's own software? I've got Radioddity and it works but how would I do a FW update? Thanks for everyone's help!
  5. I guess that's a possibility....I would like it better if it would restrict you to ONLY entering Freqs that are allowed....but it's workable No I have not updated the firmware for my GM-15Pro....have you? Any problems? Any benefits? Thanks for the replies!
  6. So while getting Doggie and wife help in the kitchen..... Found this that I didn't see before....good stuff https://forums.mygmrs.com/topic/3221-gmrs-swr-meter/ Need to find someone with a good SWR to confirm my SWR and that the duckys not showing correctly...?....
  7. Gotta run for a while wifey calling.......
  8. Well that was the lowest on the mid channel around 16....others were higher
  9. @WRYS709 No.....heard some issues.....I don't rush into FW updates unless I find others with the same radio that have no issues....too old for that BTW...the according to the RTFM....it's not supposed to TX above channel 32.....ARG
  10. @Sshannon Helps to RTFM....I just found that the other 170 channels for RX only scanning! Well it no biggie...if I mod a channel below 32 with tones I'll just create the same in the RX only channels so I can still scan it....or does the Tone NOT prevent receiving RX regular TX....the code is only for my radio for TX?
  11. Hello, I just got the Gam3Gear SURECOM SW-33 Mark II Power/SWR meter. I've checked both antennas that came with the HT and I cannot get below 2! Most are Higher! The radios were a 2 pack so I even tried the other antennas with the same results. Did I get a bum SWR or are the stock antenna crap (and yes I know these are budget radios....) I do have a mobile antenna arriving today (Bingfu Ham Radio Vehicle Car Mobile Radio Antenna Dual Band VHF UHF 136-174MHz 400-520MHz Magnetic Base PL259 Male Antenna for BTECH ICOM Kenwood Midland Yaesu TYT AnyTone Amateur Radio Two Way Radio and it says "FRS GMRS Radio"....... I was hoping to test that but if my test equipment is bad....... Suggestions? Thanks for the help!
  12. That's my problem; with my GM-15Pro using Radioddity ALL Tx frequencies are locked even on the DIY....
  13. Hello, I'm trying to program my Baofeng GM-15Pro with radioddity set to GM-30 as people say they are the same radio. Radioddity does not have an option for GM-15Pro just like Chirp or Chirp Next. I'm trying to setup a repeater channel and the Rx frequency is good but the TX frequency is not correct and it's greyed out. Am I doing something wrong? I could manually input the frequencies but documentation is not very good Any help for this newbee would be awesome! Thanks!
