koni13
1040 profile views
koni13's Achievements
  1. Hi everyone any clubs in Central Texas?
  2. WRUE951 which Midland do you suggest and price range at current, do understand tariffs increasing!!!!!
  3. Greetings, debating which budget radio would provide better reception and setup for a jeep. The BTECH GMRS-20v2 which can be programmed via CHIRP on IOS or the Radioddity DB20-G which not capable from what I view non CHIRP compatible. Unless a handheld can be attached via an outside antenna to facilitate reception, any suggestions are welcomed.
  4. Running onto same issue on a Baofeng UV82 despite the video posted on YouTube radio, will not unlock? Anyone have any other tricks to accomplish unlocking radio.
  5. Programmed a UV82 Baofeng radio with GMRS-FRS-MURS, local repeaters and HAM frequencies. Only monitor HAM frequencies when scanning, does the UV82 have capability in transmit & receive GMRS channels or solely HAM, Hear lots of chatter on local repeaters although not much if any for GMRS understanding dual frequency capability for UV82 radio.
  6. Disregard posted question, found the answer.
  7. Can both ham frequencies & repeaters, also GMRS frequencies & repeaters be installed onto a UV82 radio
  8. FOr the UV15 Pro does it matter if selecting a DIY or any number repeater number on radios frequencies. Or best selecting an empty channel to save and then go thru the process to set CTCSS and RTCSS modes to communicate with repeaters in my area.
  9. Thanks assuming reason could not connect and communicate via repeater, although do pick up traffic here in there based on line of sight in areas.
  10. So would I locate this frequency, and input to enable this repeater? 462.700 123.0 / 123.0 Killeen, Three Angels Bridge
  11. Just picked up a set of UV 15 Pro GMRS radios. I frequently pick up receptions on people talking based on line of sight. My question to enable communicating via repeaters do I need to set up or program R/T CTCSS codes to talk and receive? Understanding many of the frequencies are preset for GMRS, making sure I don't screw up the presets enabled per factory on radios. So would I locate this frequency, and input to enable this repeater? 462.700 123.0 / 123.0 Killeen, Three Angels Bridge Bell WRZE964 OPEN
  12. Just picked up a set of UV 15 Pro GMRS radios. I frequently pick up receptions on people talking based on line of sight. My question to enable communicating via repeaters do I need to set up or program R/T CTCSS codes to talk and receive? Understanding many of the frequencies are preset for GMRS, making sure I don't screw up the presets enabled per factory on radios.
  13. Just picked up a set of UV 15 Pro GMRS radios. I frequently pick up receptions on people talking based on line of sight. My question to enable communicating via repeaters do I need to set up or program R/T CTCSS codes to talk and receive? Understanding many of the frequencies are preset for GMRS, making sure I don't screw up the presets enabled per factory on radios.
  14. Which radio is a better deal debating with wither Baofeng UV-5G 9uv-5x) or UV-5R. Although really considering Wouxon KG-805G and Wouxon-KG905G.
  15. After numerous YouTube videos, finally came across one which explained easily repeater setups. Failed to understand step of deleting channel, followed by memory channel 3X to save, receive and transmit. Now I'm on repeater book manually inserting repeaters!!!!
