Sonicgott
1383 profile views
Sonicgott's Achievements
  1. Beautiful dog.
  2. Thanks to those of you who are leaving positive feedback.
  3. Seems a lot of people make this mistake as a newbie GMRS user. I'm seeing several topics on it. People not hearing you? Here's my explanation. CTCSS - Continuous Tone Coded Squelch System DCS - Digital Coded Squelch Both of these serve the same purpose: To isolate conversation. Be warned, however, some radios advertise these as "privacy tones." They have nothing to do with privacy. They do not "hide" your conversation in any way. For example: If you connect to a repeater using 462.725MHz (Channel 22. Repeater channel 22 is 467.725MHz), and the requested CTCSS is 141.3Hz, then anyone listening with that tone code will be able to hear you. Without it, they won't hear you at all. However, if you're listening, and you're not using a tone code, you will hear EVERYTHING (hence why tones have nothing to do with privacy). The CTCSS code ensures that only traffic using that transmit tone code will be heard on your radio. Anything else not using that code or using a different code your radio will ignore. While it's not necessary to have a receive code since you will hear everything, it's because that you'll hear everything that you may not know who's actually talking from that repeater, or who just happens to be using that frequency. That may end up causing confusion with conversations. TL;DR: If people aren't responding to you, it's probably because they can't hear you because of a missing CTCSS code for your radio. Double check with the repeater owner to see if a transmit CTCSS or DCS code is required. Do note that not all GMRS radios support repeaters or CTCSS/DCS codes. WSCL244/KF0QNM
  4. I've been using my GMRS radio for work, and helping others set up their stuff and giving signal feedback. It's also fun to play with the kids in the neighborhood. Other than that, I leave the extensive ragchew to my ham radio, but leaving the GMRS open just in case. My mother will use the GMRS radio as well (she can share my call sign, thanks FCC) just to keep in touch with me when I'm out and about at the nearby nature trail.
  5. Oh yeah, I recognize his type of personality. He needs help.
  6. I admire your concern, but there's a few things I'll point out: 1. I prefer to be nondestructive to my vehicle, at least on the surface. I've done only a small hole puncture in the grommet of my firewall. 2. I've done a large amount of research before making my purchase, and I've learned quite a bit. 3. I'd prefer constructive criticism as opposed to discriminant condescending tones. Only Notarubicon is permitted to do that. Have a nice day.
  7. This is just my interpretation, but you can think of watts on a radio as brightness on a flashlight at night. Line-of-sight, a bright flashlight will be clearly different than a dim flashlight, but you will see both. However, if there's a hill, a brighter flashlight is more likely to have a "halo" that you may see from the reflections, but a dim flashlight you may not. Think of someone coming from a road behind the hill that you can clearly tell has their high beams on, even though they're not directly in your face. So, more power may get you around difficult terrain, but if you're on flat terrain, or high on a hill, you may be able to achieve communication with less power.
  8. Before I begin: I've endeavored to obtain both a GMRS license, and an Amateur Extra radio license. WSCL244/KF0QNM. I have learned much since then, but there's always more to learn. - Installation - This was difficult, but only due to the fact that my type of vehicle (Ford Fusion 2017) is extremely difficult to get through the firewall. Since also installing an HF Radio (Yaesu FT-891), getting a power cord routed through the door jam from the battery was much easier, at the risk of interference, which fortunately was minimal. The center of my console fit the KG1000G+ perfectly. The antenna system I chose was the Midland MXTA26 6dBi whip antenna, and the Midland MXTA12 mag mount. These work perfectly with the KG1000G+, and the radio is quite happy with it. The mag mount is on the center of the roof of my vehicle, with the cables guided around the edge of the rear windshield with mild adhesive, going through the rear side of my trunk lid. The weather stripping is slightly depressed from the cable, but it has not caused an issue, nor has water traveled into the trunk. In retrospect, there is most likely a better way to route the antenna cable, but this would involve physically drilling holes into my car, which I want to avoid. Signal quality is 80% good. Rare moments of static, which is unavoidable because of my route to work and where I live. As the great Notarubicon would say: Your FARS may vary. I can communicate to repeaters pretty far. I was able to reach Lakeville from Brooklyn Park, MN, which is 40+ miles. I am wired directly to my car's battery. You can build a battery box for use inside the vehicle if you so desire. My KG1000G+ operates just fine between 11.8v to 15.1v. - Ease of Use - This radio does require a bit of a learning curve, but is nowhere near as advanced as a ham radio. Programming from the handset is possible, but is quite slow. Easiest way to program the radio is by connecting the radio to a computer. I recommend using a laptop if you're mobile. You can listen to 2 meter frequencies on the KG1000G+ as well. It does this quite well if you like to monitor certain frequencies. You, cannot, however, transmit on ham bands. There are no ways to "unlock" this radio to do that, either. That is possibly for the best. The buttons on the handset are solid, and the handset itself is decent. I'm currently hanging the handset with a vent mount. It's easy to switch from GMRS, NOAA, and the 2m/70cm bands. You can listen to FM radio on this thing, too, I believe... but why? It's best to treat this radio as a "set it and forget it" like a Ronco product. Know what you want to do and who to talk to, and all is good. I do have a scan function set on this radio with one of the programmable buttons on top. Useful if I ever want to eavesdrop on a conversation. Don't actually join in on someone else's conversation unless you can provide useful information, though. It's kind of the same principle of interrupting people when they're talking in person. I have used my KG1000G+ with my job, however. They use FRS radios, which are compatible with GMRS, and I can communicate to them just fine. - Complaints - Periodically, there will be buzzing on random channels. Worried that this was a problem with the radio, some people have told me that it might be because some people are using digital signals on GMRS, it's interpreted as garbage. The KG1000G+ is an analog-only radio. This has been the only issue. - Compliments - This radio has impressive range, both on send and receive. 50 watts is the maximum power allowed on GMRS, and it works quite well. I've met some people on the GMRS system and do talk to them every now and then. GMRS is touted as a tool, however, a bit of ragchew every now and then isn't too bad. I try to keep transmissions under 15 seconds. The fans do kick in after a while. This radio works well in very cold environment as well as hot ones, but if the temperature is too high, such as a car sitting in the hot sun, the radio may refuse to transmit. This isn't an issue, but rather, a feature to protect the radio. The KG1000G+ is very sensitive, and it's interesting to hear the conversations that my scanner will pick up on. It works well communicating long distances, works with my job, my handheld radios, and the Midland GMRS radio I have attached to my desk at home. - Tips - Get an external speaker. I got an Icom speaker for $20 on Amazon. It is MUCH louder than the speaker built into the radio. Oftentimes I'm having to hold the handset to my ear to hear better. Just get a single speaker for the channel you want to listen to the most. I don't think it's needed to have both speaker ports occupied, unless you really want to. - Final Thoughts - This was a pricey GMRS radio, and I know that cheaper ones exist, but honestly the Wouxun KG1000G+ has been solid and reliable, even if the installation was a pain. I recommend it as both a mobile and as a base station radio. One feature I've not used is operating it as a repeater (requires a second radio). I am not in the most ideal situation as far as radios go since I live in an apartment, so my "shack" is my car. Final Verdict: 7/10 + Good receive/transmit quality, + Handset and radio are solidly built, - Installation was difficult, but that's because of my vehicle type, - Doesn't like digital noise.
  9. R-CTCSS - Receive - Continuous Tone-Coded Squelch System R-DCS - Receive - Digital Coded Squelch And the T is the transmit tone codes. One for receive, one for transmit. Like most of what everyone else said in here, it's just to silence the other people sharing that frequency.
  10. Hey! I resemble that remark! >.>
  11. WSDV362 - Whiskey-Sierra-Delta-Victor-362. NATO phonetics aren't as often used in GMRS, but it does help. Mine, WSCL244 - Whiskey-Sierra-Charlie-Lima-244. Note that Lima is "Lee-muh," and not like the bean.
  12. Depends on what you want to do and how much you're willing to invest. Keep something in mind is that GMRS is more of a utility rather than the "rag chew" radio service. It's used to keep in touch with people you know you travel with on a regular basis, such as hiking, camping, traveling on the road, and so on. Some people will use it for casual conversation, but it varies quite a bit. I'd research GMRS radios, and what you want to do. Do you want to: Walk with a radio? Travel with one in the car? Have one at home as a base station? A lot of companies make good quality radios. I happen to have a Wouxun KG1000G+ in my car. It was a bit of an investment, but works reliably and I use it all the time when I travel. I don't do home base stations due to living on the ground floor of my apartment. Line-of-Sight is very helpful with GMRS. If you're surrounded with hills and railroad tracks like I am, then a GMRS base station won't be good for you. If you're out in the open, such as walking to parks, going camping with buddies, a handheld transceiver (or handy-talky as they might be called, HT for short) might be for you. A "get-your-feet-wet" GMRS radio might set you back $30, but a good handheld radio may run $100 or more. If you've got the money, buy a good radio. But even better, make sure to have a good antenna, as that can make a huge difference on its own. Stock antennas that come with some radios are not as efficient. (FRS radios cannot have their antennas changed -- usually). Hope this helps.
  13. Was easier to wire directly to the battery. Doing all of the fuse-hunting stuff wasn't something I was fully understanding, but, it worked nonetheless, and by going directly to the battery, I avoided noise on the line.
  14. TL;DR - This is a great radio, and is highly recommended. Now for the details: Setup - Radio: This was a huge pain in the butt, but I blame the make and model of my vehicle for being difficult. I have a 2017 Ford Fusion. I had to puncture the grommet in the firewall from the passenger side, and on the inside of the vehicle, I had to disassemble the passenger side vent assembly and remove the glove box. Then, using a curved metal coat hanger, I fed it through the punctured grommet in the firewall, around the center vent mechanism (and avoiding the passenger side airbag deployment mechanism), and once that coat hanger was completely through, I firmly duct taped the ends of the power cables for the radio, and covered up the fuse with the duct tape. Then, using a lubricant, I coated the now duct-tape covered cords, and SLOWLY pulled them through the grommet and popped them on the other side. I fed a little more cable than was necessary to reach the battery. Once the cables were all the way through, I cut off the duct tape and cleaned the cables, then I proceeded to crimp O-ring connectors onto the cables. Red cord went to the positive terminal of the battery, on the bolt sticking up from it, and the black cord to the negative ground chassis (DO NOT connect the black back to the battery directly!) I removed the nuts from the battery and chassis ground (each of those took a DIFFERENT EXTENDED wrench mechanism, had to make TWO trips to the hardware store!) Then I used 1/2" convoluted tubing (rated for high heat resistance) to protect the wires. On the radio side, there was a cubby right beneath my dash stereo panel which fit this GMRS radio awesome, but I opted to use adhesive instead of screwing things in. This does not work well in high heat, so I had to fix it. It's heavy, and I needed a gap for the speakers. Since I don't have a speaker box to connect to the radio (any recommendations?), I left the head connected to the radio. The handset is heavy, and I wasn't able to reliably use adhesive to mount the handset holder, so, it sits loose in the console for now. Not a huge deal, but I think there's a better option. I'd rather not screw holes into my dash. Antenna: Midland MicroMobile MXTA26 6dB Gain Whip Antenna with an MXTA12 Mag Mount. This antenna comes with a LONG cable, and I chose to mount it on top of the middle of my car. The roof is metal, and the mag mount works very well with it. Huge ground plane, too. I fed the cable down the groove of the side of the rear wind shield, and into the trunk. The weather stripping isn't damaging the cable at all, and I'm not worried about pinching it. I used some small carabiners to keep the cord from being loose in the trunk. I fed it through the back seat on the passenger side, went down to the floor and underneath the mat, and guided the cable with some adhesive cable organizers to keep it from being pinched from the moving seat. Fed the antenna cable into the back of the radio along with the power source, cable managed with some velcro straps. This entire install took me longer than I thought, about 4+ hours due to having to figure out how to install things as I went along. Hopefully my experiences will help others. Use - First, I always remember to power my radio off after I turn off my car. It's directly fed through the battery, so no mechanical switch or feeding through the fuse box. However, there's a safety setting on the Wouxun KG1000G+ that you can turn on which monitors a below-recommended-voltage to disable the radio to prevent excess battery drain. I'm not too worried. However, when I power up the radio, Sometimes I see the screen showing excess of 14+ volts. This is a tad concerning, but so far hasn't really been a problem. If I see it shoot past 16 volts, I'm sure the fuse would be tripped. Signal quality varies. Channels 1-7 are very range dependent. Channels 8-14 I can listen to, but not talk to, so that's not really that important. Channels 15-22 (and the repeater channels) sound amazing -- AS LONG AS I HAVE A CLEAR LINE OF SIGHT. If I'm going through valleys, walls, buildings, or lots of tall trees, the signal will "flutter." On the highway, I've been able to keep in touch with repeaters up to 60+ miles away. (I do not recommend the MXTA25 stubby antenna. It's design is not good for use when mobile and you're trying to reach distant repeaters. As an offroader antenna, though, it would be fine, so I keep it as a backup option). In most scenarios, however, signals are solid and reliable. The fans do kick in when transmitting, and while the noise is audible, I feel that it isn't a problem. Other thoughts - I also have a CB radio and a Ham radio sharing roof space with my other antennas. My colleague has nicknamed my car "the porcupine." Haha. The 70cm/2m Ham radio antenna does not interfere with the GMRS Wouxun radio at all, either transmit or receive. The CB radio, however, does NOT like it when I transmit from the GMRS radio, so I need to turn the CB off, first. Again, the Ham radio is unaffected. There's a lot of programmability when it comes to the Wouxun radio. I'd recommend getting a dirt cheap laptop purely for running radio software so that you can program it in the car, otherwise you'll be using the handset to program. The most annoying thing when programming a channel, though, is naming it. There's no "backspace." You make a mistake, you have to hit the # button to cycle through the letter options again so you can choose another letter. Programming channel names into this thing from the handset is awful. I really want a better speaker for this radio. The sound is okay, but I have to turn off almost everything else to hear it. I'm worried about cranking up the volume too high or blowing out the internal speakers. I do notice a slight audio level loss when doing dual-monitoring. It's also stupid that you can't program the radio name from the handset -- you need the PC and the software to do it. Not willing to buy a internal power supply to temporarily work on my radio in my PC at home. Just get a cheap laptop to bring to the car. (Seriously, you can get a laptop for $80.) It would also be nice to be able to program this thing from a smartphone, iPhone, Android, whatever. Give it Bluetooth or something. A $480 radio should at least be able to do that. My final thoughts: Installation: Varies. My experience: 4/10. My car was just not built to have a radio installed. Perhaps a Jeep or another kind of truck would be better. Don't take my personal review as a reason to not buy this radio. Radio quality: 8/10. Does not like hot weather. Let the fans run for a bit if the inside of your car is hot. The chassis is VERY solid, but the handset is so-so. Nice to have a removable face plate, though I haven't used that feature, yet. Ease of use: 6/10. For most basic functionality, it's fine, but adjusting settings has a bit of a learning curve. Audio quality: 7/10. Could definitely be louder. I'd love to do an external speaker and mount the radio elsewhere in the car and free up space. Handset speaker is subpar. On some rare occasions, I've heard random fluttering-buzzing on my ham radio and GMRS radio. Not sure where that comes from, but it seems to happen on only one channel. It goes away on its own. Might be some punk kid, or some lid. I dunno. Is this radio worth the investment? Absolutely. Performs admirably. Static, however, is inevitable depending on your location. As the great Queen of all that is GMRS once said, "Your FARS may vary." Thanks, guys. WSCL244/KF0QNM
