Lscott
    105
Everything posted by Lscott
  1. PastorGary, Thanks for the info. I wasn't sure if the radio was legal to use on MURS. There isn't a definitive clearly stated policy from the FCC I could find that states any Part 90 radio with a grant date before the creation of the radio service MURS or GMRS would be legal to use with the right programming to comply with the rules. That seems to be implied in the rules for the service in question. A bit off topic but I also have the older TK-370, not the "G" version, programed for GMRS. It has only 32 channels and wide band only. The radio has an FCC grant for Part 95, FCC ID ALHTK-370-1. I have it programed for the 22 GMRS simplex channels and 8 more for repeaters use leaving two spare. The FRS channels are programmed for RX only, 8 to 14, since they are narrow band only. The audio volume will be low but usable. The only issue with that radio is the antenna connector is the Motorola MX type. I think the newer one uses the same reverse SMA antenna connector as the TK-270G and the Chinese radios. I found an adapter that will convert from MX to female BNC for using an external antenna. FCC Grant TK-370-1.pdf
  2. I've looked around but can't find any hard info for old Part 90 radios that are legal to use for MURS. For example I have a TK-270G HT purchased at the Dayton Hamvention. The FCC ID is ALH29463110. The grant is dated 10/25/1999 which is before the creation of the MURS service in 2000. If I read the rules and understand them it should be OK as long as the radio is programed to conform to the rules. Anybody else have a source for info on this topic? TK-270G-1 FCC - OET EAS Form 731 Grant of Equipment Authorization.pdf
  3. Lscott
    Untitled Album
