106
Everything posted by Lscott
Oops that should have been 16 mile road, not 15 mile. The road name I got right at least.
Seems you're in the same metro area, around Detroit, as me. This a bit off topic but if you're within about 20 miles of interstate 75 and 15 mile road, Big Beaver, in the city of Troy is where a nice repeater is located you can use for GMRS. It's a closed machine but all you need to do is email the owner and ask permission. Several friends have done the same and he doesn't have a problem letting the public use it. He just wants to know who is accessing it. I think all you need to do is ask for permission and give your FCC assigned call sign. The listing is in the "myGMRS.com" site's repeater database. Look for the state of Michigan. The repeater is listed as Troy575. There are two shown. You want the second one in the list. The first one is an older listing for the same machine but the data and contact info is wrong or out of date. That's the topic of another thread elsewhere, bad, out of date repeater info in the database. This should be the correct link below. https://mygmrs.com/view?id=3562 You will need to register on this site and login to get the input, output frequencies and access tones or ask for it in your email from the owner. There is another one listed in the Westland/Canton area which is an open repeater, no permission required, but the coverage map shows a smaller area. I haven't accessed it yet from my location and I don't know if it's currently in operation. I think the owner is still in the process of setting things up and this is a fairly new listing. This is the link: https://mygmrs.com/view?id=3808 The owner of the Troy575 machine sent an email out, to the people requesting access permission, about a week or so back asking if there was any interest in setting up an informal "net". The idea was the various users can get together to chit-chat for a while. The repeater doesn't see much use and I monitor it frequently along with several Ham UHF machines near me. I haven't heard anything further about the net from the owner. Congratulations on getting licensed!
Yea, some say you're not a real radio guy until you drill holes in your ride to mount the antennas. Can't do that with company stuff, rentals or lease.
Makes you wonder how their customer service is like if you have a problem.
Unless you're really desperate to get rid of them my offer would likely be too low for you. I'm really looking for super bargains when buying radio stuff.
CW Coder/Decoder Software vs. Learning Morse Code and Attitudes
Lscott replied to SeldomSeen's topic in Amateur Radio (Ham)
Don't worry about it. Switch to another repeater or use the VFO to find somebody else to talk to. The crappy attitude was at its height around the time the FCC dropped the CW requirement for all license classes. There were endless debates, some still going on, about the merits of dropping or not dropping the CW requirements. Some of the old timers hated that change, and likely will never get over it. I guess they though of it as a some kind of exclusive club. If that was what they valued most then they got into Ham radio for the wrong reason. Go out, make contacts and have fun. -
Does it have the ID function available in the controller? Without that it really isn’t useful outside a single license use operation.
Most antennas I see are gain type and the height gets up there. The link below has a selection of 1/4 wave types. https://www.pctel.com/wp-content/uploads/2018/11/Product-Datasheet-25.pdf (catalog page) https://www.pctel.com/ (Main site) The above is a suggestion for reference. The model PCTCN4347 I think will work and about 6.2 inches tall. This is pre-tuned for 430 MHz to 470 MHz. You will also have to get the magnet mount which is an extra cost. It looks like they require an NMO type mount. I don't known what the cost is for the antenna and mount. You can contact the company. This company seems to carry the antenna series but I don't see anything mentioned about selling a pre-tuned one. I think you have to cut the element to length for the frequency you need. The manufacture may have that data or the antenna comes with a chart you reference for the recommended length. Again I would contact them for details. https://www.theantennafarm.com/catalog/pctel-maxrad-pctcnmft-5913
One thing you need to be sure of is the TX frequency is not harmonically related to the RX frequency. For example if the TX frequency is 146 MHz you don't want your RX frequency anywhere close to 438 MHz for example, which is the third harmonic. The tiny amount of harmonics generated, all radios have some, could be enough to break the squelch on the RX and cause interference. This is a common error most people make setting up a cross band repeater. You could have some other unrelated problem but this issue should be addressed none the less.
A 1/4 wave whip maybe your best bet for the moment, and not just for technical reasons. It seems you want to put the antenna on the roof of a pickup truck at some point. A 1/4 wave antenna will only be around 6 to 8 inches tall. You'll soon discover that's an asset when you find it necessary to go through a "drive through" window at a bank, fast food joint, parking garage all with a low overhead limit. The truck, or most SUV's, roof is already taller that a typical car decreasing your head room. A higher gain antenna is going to be taller. I have a high gain dual band on my Jeep that's about 60 inches tall. I have to think all the time about where I need to drive to avoid damaging it. Sometimes I have to get out and unscrew the thing from the roof rack mount. One other point a 1/4 whip, when tuned right, has a very wide bandwidth. I've built a few for inside and temporary use out of a male BNC PCB socket and stiff bus wire. I can get the SWR down to under 1.5:1 from 430 MHz to 470 MHz with 3 feet of small gauge coax measured using an AA-1000 antenna analyzer. That covers all of the usable Ham 70 cm band and all of the FRS/GMRS channels. You'll find that advantageous when you get your Ham license.
Just a note about antenna restricted areas. I read some time back a Ham had a problem with is HOA with wanting to put up some antennas. Well he researched the bylaws and came up with the following solution. He installed a small crank up tower on a trailer and parked it in his back yard where you couldn't see the trailer part. Cranked it up when he operated. Since the bylaws didn't prohibit antennas on vehicles, which you could reasonably argue applies to trailers. He moved the trailer every once in a while so they couldn't claim it was permanently parked in one spot either to qualify as a vehicle. The HOA couldn't say much. Another Ham did something similar by installing a telescoping mast on his truck parked in the driveway. He then snaked the coax across the ground to the truck from the house. The HOA wasn't very happy but he wasn't breaking any of the rules either. 8-))
I you down load the TK-360G/TK-370G Service Manual from the link in my last post then look at page 11. That's section 8, Self Programming Mode. There it shows you where D17 is located, which has to be removed, and also the front panel/self programming mode enabled in the software has to be selected. The sequence for entering the various parameters through the front panel is covered in the service manual section. As you can see from the tables and flow charts it's really a pain. I've never modified my radios since it's far easier to use the programming software. 8-/ The radios don't have a real "VFO" so any programming done has to be to a particular memory slot. So field programming is not that useful IMHO. Oh, to "simulate" a VFO I did program one memory bank in the 370G with a sequence of frequencies every 25KHz. The memory names were like 440-000, 440-025, 440-050 etc. for example. So skipping to the simplex bank and adjusting the big top side channel selector nob simulates the operation of an adjustable VFO with the frequency step size set at 25KHz. That covered most, depending on how many memory channels you have left, of the simplex section of the band outlined in the ARRL recommended layout for 70cm. Better than nothing I guess. Another good radio that is still currently manufactured by Kenwood is the TK-3170. Also Part 95 certified. If you find them used they tend to sell for more than the TK-370G's do. I've only seen one with a full keypad however. Most just have the top row of function keys. https://5.imimg.com/data5/LH/CE/FE/SELLER-3451103/kenwood-tk-3170-uhf-two-way-radio.pdf You'll notice the band split is spec'd at 440 MHz to 480 MHz for the type one. No question this will cover part of the Ham 70cm band. If you want a mono band radio for VHF look at the TK-2170's band spilt in the same brochure. It will cover the complete 2 meter band up past where the NOAA weather channels are around 162 MHz. These radios are hard to find and people want way too much for them. I think you can guess why. I have both types and they are good radios. 73 KC8LDO WRBZ532
I have both types. I agree the radios are great, particularly the TK-370G-1's. They are also both Part 95 certified too. I use the official Kenwood software to program the 370G's and Chrip for the 370's. I had issues with Chirp and the 370G's. When trying to organize the frequencies using the "Memory Group" feature Chirp would fail to add frequencies in, some would get deleted and other odd things. It seems to work fine for the 370's which is good because the official software for that model is DOS based. The down side is you don't have access to all of the features in the radio. For the 370G you want the "KPG-56Dv422.zip" file. This works with Windows 10 by the way. You will need some kind of serial number to install the software which should be included in a text file in the download. This software gives you full access to ALL of the radio's features. http://rsws.zapto.org/RadioSoftware/Kenwood/Kenwood.htm As far as I know both models are in fact field programmable. However two things must be done to enable that. First the option must be enabled in the programing software and second a small component must be removed from one of the circuit boards inside. Enabling the feature in software is not sufficient. Also if the radios don't have a full keyboard self programming isn't going to do you much good. http://www.repeater-builder.com/kenwood/pdfs/tk-360g-tk-370g-svc-man.pdf http://yo3hjv.blogspot.com/2010/05/field-programming-for-kenwood-tk-370.html http://rsws.zapto.org/radiosoftware/kenwood/Field Programming the Kenwood Tk-270 370.pdf https://www.manasrekha.com/pdf/TK-270G-370G.pdf https://www.manualslib.com/products/Kenwood-Tk-370g-3058542.html While the radio spec's don't show it you can program in frequencies outside of the official band spread for both models. I have the 370G programed for GMRS wide band and narrow band plus a number of Ham UHF repeaters and some simplex frequencies. The Ham repeater section of the band and simplex section are mostly between 440 MHz to 450 MHz which the radio will TX and RX on it seems OK. The official Kenwood programming software will throw up a warning about those frequencies being out of range but you can click OK and the software will accept it. Its just a bit annoying when building the code plug.
The results look pretty good for a quick test. Some people say they get better range when they add a “rat tail”, “tiger tail” or more correctly a counterpoise to the radio. https://hackaday.com/2014/02/08/improve-your-ht-ham-radio-by-adding-a-counterpoise-antenna-wire/
I'm not sure about the software he has but I've run across some that still use 16 bit installers. Those don't work on Win 10 at all. Setting the compatibility mode is useless. The solution he used is a good one, running Win XP in a VM. https://www.virtualbox.org You can get a Win XP VM in Win 10 but you have to pay for the much more expensive Pro version to get the VM subsystem, "Hyper-V". https://www.download3k.com/articles/How-to-add-an-XP-Mode-Virtual-Machine-to-Windows-10-or-8-using-Hyper-V-00770 VirtualBox does about the same thing for zero cost. However you're left with finding a copy of the Win XP on your own. Virtual Box is a good opensource VM package. I've even run Windows 3.1 in it. Even managed to find a copy of IBM's OS2 Warp 4 and got that to install and run too. If IBM and Microsoft had their act together we would all be running OS2 instead of Windows. https://en.wikipedia.org/wiki/OS/2 Remember "Windows is a pane in the glass".
It's still would be an interesting experiment. Stories surface about counterfeit antennas from at least one well known manufacture are out there. I think it is Nagoya. Antenna testing showed the difference between the real one and the fake. https://www.eham.net/reviews/view-product?id=7741 On another point I have purchased a few "cheap" magnet mount antennas mostly to get the mount from Ham Radio flea market vendors. After testing them the performance was nowhere close to the spec's on the package. Some antenna testing results. http://www.km4fmk.com/AntTesting.html
If the link above doesn't work, you have to copy the whole line and past it into the browser. Then try this one. http://www.w3pga.org/Antenna%20Books/Reflections%20III.pdf
You may find this book of interest. The book is about antennas and transmission lines. I hope Firefox didn't mangle this link again. http://www.w3pga.org/Antenna Books/Reflections III.pdf It's a good reference to keep on hand.
You want to really have some fun try testing some HT antennas! They're not easy since the radio, and part of your body, ends up as part of the antenna. When you see the results you'll wonder why they work at all. A few I've tested belong in a landfill somewhere.
I wonder if the guy did the FCC RF safety evaluation. Depending on band, power level and antenna location it's a requirement. Just because its a mobile station the safety issue can't be ignored.
As the license holder of record you're responsible to insure those operating under it follow the rules. Kids have to learn rules for everything as they grow up. GMRS shouldn't be any different. As far as paying a fine the FCC, when they issue one, they don't screw around. Somehow getting one for $7,500 to $10,000 is sort of scary. They want to get your attention and make a point. And yes they most certainly have in other radio services for failure to ID, unlicensed operation, willful interference etc. I don't know about GMRS but it wouldn't be any different. A number of the cases I've seen the FCC contacted the party informing them of the rule violation(s) first. The fine(s) get issued when they party continues to ignore the rules and the FCC notices. Oh, they also have a habit of taking the equipment too in some cases along with issuing the fine(s). I remember years ago asking somebody at the local FCC field office here what they do with all of the confiscated equipment. I was told it goes to a local junk yard straight into the crusher. None of it ever gets sold or returned to the owner.
- 32 replies
- kids
- neighborhood
(and 3 more)
Tagged with:
Thanks. Sometimes the copy and past with Firefox doesn't work so good.
Oops. Linked the wrong version or Part 95 rules.
To be strictly legal the equipment must be Part 95 certified. Older equipment might be listed as Part 95 while newer equipment would be Part 95A. This should be a good reference for Part 95. It covers several of the radio services, specially GMRS, FRS and CB. https://www.govinfo.gov/content/pkg/CFR-2009-title47-vol5/pdf/CFR-2009-title47-vol5-part95.pdf
