105
Everything posted by Lscott
Try looking at battery packs from this company. They do a lot of business with Hams for portable operations. They have pretty good prices considering. https://www.bioennopower.com/collections/12v-series-lifepo4-batteries Personally I have the 6AH pack ($80) for portable work with HT's. I have the 40AH ($360) for home use when the power dies. If you get the batteries make sure to buy the charger too. The 6AH LFP weights a lot less than the old 5AH Lead Acid Gell Cell, and with much more usable capacity too. I don't recommend anybody use a Lead Acid battery unless cost is an extreme concern. Personally I've wreck too many Gell Cell and AGM batteries to want to fool around with them anymore. If you don't maintain them at full charge when not in use they will sulfate and fail. And if you do they still don't last that long. The other disadvantage is the terminal voltage falls fairly quickly to the point where you're lucky to get maybe 50 some percent of the rated capacity out of them. Most mobile equipment wants to see a nominal 13.8 VDC (+/- 15 %) and when it drops to around 11.75 VDC the equipment misbehaves or shuts down. Then there is the weight. Using LFP, Lithium Iron Phosphate (LiFePO4), batteries have a nominal terminal voltage of around 13.3/13.4 VDC over most of the full discharge range, which is a good match for mobile equipment. By the time they drop to 12.8 VDC you have used around 90 percent of the rated capacity. The batteries will routinely allow you to discharge them to 80 to 90 percent without damage. Under this kind of use expect to get around 2000 charge/discharge cycles out of the pack. Lead Acid is only good for a few hundred when using just 50 percent, using more the cycle life drops even more. You can charge up a LFP battery and let it sit for weeks to months without it hardly self discharging. Further for very long term storage you only partially charge them. Sitting around for very long periods doesn't seem to hurt the batteries at all.
It could end up being a rather long list. Here are a few examples. >8-| http://www.ominous-valve.com/acronyms.txt https://rsgb.org/main/publications-archives/radcom/supplementary-information/abbreviations-and-acronyms/ https://www.electronics-notes.com/articles/ham_radio/abbreviations_codes/abbreviations.php
I agree. For the most part it did what his intended purpose was, a very basic explanation of antenna tuning and gain. Since it wasn't meant as a highly technical article minor errors can slide by without a major loss in the concepts. Great effort.
This is a valid point. The antenna impedance is not a simple resistance when off resonance. Combine that with some capacitive coupling in series I’m sure will also generate some weird SWR characteristics.
For a quarter wave antenna it has some rather odd behavior. There seems to be several peaks and dips in the SWR over the range. I would have expected to see just one dip at the resonate frequency and smoothly rising to either side, which is what I saw with the antenna I built. Also the EZNEC+ antenna simulation I ran for it showed the same thing. I'm wondering if part of what you're seeing is caused by the UHF (SO-239 to PL-259) adapter used on the antenna analyzer. Of course those adapters are nowhere near a 50 ohm impedance. The simple 1/4 wave i made used BNC adapters which are 50 ohms. Have to be careful because there are 75 ohm versions too and hard to tell apart since the size is very similar. The interface between the two adapters is likely around 1/2 inch, however due to the velocity factor of that part electrically it looks longer. Teflon has a dialectic constant or 2.1 and the velocity factor is the square root of the reciprocal of the dialectic constant. So for Teflon that works out to 0.69. At 462/467 MHz the RF travels through the connector interface at 69 percent the speed of light, or you can consider the connector looks longer by the factor of 1/0.69, or 1.45 times longer. For a straight barrel adapter, female to female SO-239, I measured the center OD and the shell's ID and using a basic formula to calculate the impedance I got around 28 to 29 ohms. https://www.electronics-notes.com/articles/antennas-propagation/rf-feeders-transmission-lines/coaxial-cable-characteristic-impedance.php So if we consider the adapter interface is around 0.72 inches long at 28 to 29 ohms we could use the lossless transmission line equations to figure out what the impedance will be with a given load on the other end. I did that for various frequencies for my own education and the results were "interesting." At the frequencies we are using for GMRS that impedance bump is rather large. I have a PDF of some calculations a while back along those lines just to see how it affected the SWR. If somebody wants them I would have to PM the file. I can't seem to attached anything to my messages in a long while, I keep getting an error that says I only have 666 some bytes left to attach a file. If I could I would. I know this might be getting a bit deep for some people, but what really counts is the results.
Very good! We could use more real world info like this. Far better than saying “I can hit such and such repeater x miles away.” I see questions always coming up asking if such and such antenna can be tuned for Ham and GMRS. Nothing like having the measurements which speak for themselves.
For a really high gain antenna that is likely true. For a modest gain one the answer isn't so clear cut. I recommended a Comet CA-2x4SR dual band antenna for a friend at work, who got his GMRS license, and looks forward to getting his Ham license as soon as local clubs open up for testing again. You can get it in either a UHF or NMO type mount. http://www.cometantenna.com/wp-content/uploads/2013/09/CA-2x4SR.pdf He mounted the antenna on the fender of his pickup truck. It would have been better on the roof but at 40 inches tall it made things difficult going into parking garages, drive thru windows at banks and fast food joints. I used a Rigexpert AA-1000 antenna analyzer to do an SWR sweep of the operating range. https://rigexpert.com/products/antenna-analyzers/aa-1000/ On UHF the SWR was OK. As long as the SWR is under 2:1 most radios should have no issues and work OK. 432 MHz - 2:1 438 MHz - <1.1:1 454 MHz - 1.9:1 464 MHz - 1.2:1 467 MHz - 1.6:1 469 MHz - 2:1 The SWR on VHF was even better. 140 MHz - 1.5:1 152 MHz - <1.1:1 160 MHz - 1.6:1 This is close to what the published spec's from Comet are for the antenna. While the UHF band has some notable dips and peaks in the sweep it is still very usable. The antenna was mounted close to the roof pillar. I would guess if it was mounted further away the SWR sweep would have looked a bit better. You're right about a 1/4 wave having a large bandwidth. I built a couple out of PCB mount type female BNC sockets and some 1/16 inch stiff buss wire for the elements soldered to the center pin and the flange, bent down at 45 degrees for the ground plane. All about 6 inches long. Sitting on a table top the SWR scan showed a max SWR of 1.4:1 at 430 MHZ and 470 MHz after some slight trimming. The minimum of almost 1:1 was at 445 MHz.. I'm using this on top of a bookcase at the office with a handheld UHF radio. It works better than the typical rubber dummy load, called a rubber duck antenna, that the radios ship with from the manufacture.
That depends. The range on UHF is 3 to 5 miles between mobile radios. You can get more range if you can access a repeater. However you will likely drive out of range of the repeater in 15 to 30 or so miles, if the repeater antenna is located high enough. As an example there is a Ham Radio UHF repeater by me with the antenna at 800 feet. The usable range is about 40 miles more or less. The problem with repeaters used on a long trip are two fold. First you need to know where they are and the channel used. Second most use an access tone, without it you won’t even activate it. Trying to input a tone as you’re driving down the road isn’t recommended. Many of the real GMRS mobile radios require some measure of screwing around to set the tone, that is if it’s even possible. Some you have to use the programming software. If you’re lucky you may get a contact with a base station, in which case you don’t need to normally worry about access tones. If the base station has their antenna up 30 feet or more you could get 10 to 20 mile range. Some of the other people here have pointed out in other posts that running a 40 to 50 watt radio mobile didn’t really increase their range much. I would recommend just using a hand held radio, typically 4 to 5 watt output, connected to a good magnet mount antenna on the vehicle roof. You can buy a hand held GMRS radio for under a $100, some are even less. While you can get a cheap mobile radio for about the same price the output power is about the same. Also the hand held you can use the stubby antenna while out walking around and keep the radio in your pocket when not in use. Don’t even think about trying to use a hand held with the stubby antenna inside the vehicle, you’ll be VERY disappointed. Your most likely contacts are a few others operating mobile GMRS, some base stations and likely a fair number of people using FRS radios mobile. Remember FRS and GMRS share the same exact frequencies exclusive of the repeater ones. My experience with people using FRS radios mobile inside of a vehicle is the range seems to be no more than 1/2 to 1 mile. In fact the FRS users are likely to hear you well past the point where you will hear them.
Lscott replied to coryb27's topic in General Discussion
Unfortunately that's not exactly what the rules really say. https://www.law.cornell.edu/cfr/text/47/95.1751 Reading the above we have the following: There are two usage cases that are being confused. One where everyone using the repeater is operating under the authority of the repeater owner (FCC licensee), and the other is when "others" with their own FCC issued call sign use it, either granted permission by the owner or the repeater is listed as "open" for public use. If the users are all operating under the authority of the repeater owner then yes it doesn't need to self ID. 95.1751 (c1) and (c2) This is the only exception to the repeater ID requirements. This makes sense since everyone operating under the authority of the repeater owner all are using the same call sign. So when they ID the repeater is also properly ID. However if you read this critically the repeater MUST self ID, as stated in the rules for any GMRS station, if it is being used by anyone else other than stations operating under the authority of the repeater owner. This is the part I think everyone misses. Just because the FCC hasn't busted anyone for this doesn't imply a rule violation is not occurring. Same thing with Part 90 radios being used on GMRS, some in fact have been used for building GMRS repeaters! In the usage case I had originally mentioned the repeater owner is allowing other licensees to use it and it doesn't self ID with its owners call sign, ever, when in use or otherwise. I've never asserted that GMRS repeaters must ID if they are not in use. It would be nice if they did. That helped me very late last night, 2AM to 3AM, when tropospheric ducting was going on. A distance GMRS repeater, I caught only part of its CW ID before it faded out, operating on the same repeater channel as the one I use locally, the one that never ID's. No the DX repeater wasn't activity being used so without it automatically self ID'ing I wouldn't have known it was there. -
GMRS doesn’t have to ID? What section is that in the rules? When I’m scanning I have all the tone decoding turned off so I don’t miss anything. I’ve never had it on. Still don’t hear any ID. I do occasionally hear the MDC burst from Motorola radios, but not all of them. This really isn’t just an academic issue. There have been enough posts I’ve read where users have the same problem, trying to figure out who to contact for permission to use a repeater. The typical answer is listen for the ID, dah, what if there isn’t one? Without something to work with the problem isn’t easy. For anybody thinking about putting one up some thought needs to be put into the decision based on who is going to use it and how is anybody monitoring it on the air going to figure out who to contact. Not everyone has access to expensive for pay database services. Not every GMRS, for that matter Ham, repeater is listed in commonly available on line databases. That’s been another complaint here as well. The database on this site has repeaters listed that no longer exist, repeaters that exist but the owners choose not to list it, I know of a few of those too where a buddy lives, and just plain wrong info on some that do exist, like the one I tried tracking down. When somebody asks about putting up a repeater it isn’t just about do you need one. There is the engineering aspect and the regulatory requirements too. The repeater doesn’t live in a vacuum, it has to coexist with other stations and users so going a step beyond what the letter of the rules require could be well worth the effort. All are important IMHO when asking about advise. -
The repeater I was trying to locate turns out it’s on the top of a building that’s listed as the roof top at 206 feet above ground level. So per your points it wouldn’t have been required to be registered with the FCC. There is also a Ham repeater on the top of what is now GM’s headquarters. That’s only 14 to 15 miles line of sight from my house. http://www.gmarc.org/wp/wp-content/uploads/2020/05/RenCen-repeater-qsl-compressed.jpg There is also another Ham repeater just a mile or so from the GMRS one on top of another building at 300+ feet. Both of which are just under 5 miles to the west of my location. Both Ham repeaters do self ID. Since the above are not on a tower, and the antennas are mounted close to the roof top there is no legal requirement they be registered with the FCC? I was not aware of any FCC requirement to register if you’re on a tower however. That’s new one for me. Thanks for educating me on that. I also monitor the security frequencies from two local malls. It was rather interesting when the police protesters showed up by the one in Sterling Heights a few weeks back. Both use repeaters. Nether one self ID’s that I can tell from several years of monitoring them. Both are listed in a well known on line scanner database. https://www.radioreference.com In that one of the two shows the call sign for the repeater. There is nothing listed for the other one. Again doing an FCC GEO search on either the input or output frequencies yielded nothing that makes sense. A search of just the frequencies used for the city, where I’m guessing the repeater is located at the mall, didn’t yield anything useful either. How would one use freely available sources to track down the owner, and the call sign, of the non ID’ing repeater? So for the two malls how can they operate with out either the repeater nor the hand held radios used ID? Is there a specific FCC rule that allows this or are they in violation? -
What you said is true I’m sure for commercial systems, public safety etc. I don’t recall seeing anything in the FCC rules requiring a GMRS repeater to be registered with the FCC. Neither are Ham repeaters, but you do work through a local frequency coordination body which is not part of the FCC. The only requirement is each station must ID, so as long as only qualifying family members use the machine it doesn’t need to self ID. Each qualifying family member when they ID satisfies the requirements. However if non qualifying family members use it then it’s impossible to determine who is the owner unless it self ID’s. This was EXACTLY the problem I had trying to identify the local repeater I’m currently using. No self ID, nothing shows up of any use when doing an FCC GEO search on the exact frequency over a limited range of 50 miles. I finally tried contacting the owner because it was listed on this site’s repeater database, by shear luck and I still wasn’t really sure. But even then the info was wrong because the owner died and the listing wasn’t updated for a few years. Months went by and no response to my emails, unknown at the time they were going to a dead guy’s account. Then when it was updated everything got worked out really quick. If it had ID’ed with the current owners call sign a simple lookup of that in the FCC license database would have given me the contact info I needed and saved me a lot of screwing around. -
That doesn’t make any sense to me. The point of ID’ing is so the owner of the repeater can be contacted in case of a problem. I don’t own the repeater I mentioned and I’m sure the FCC won’t be knocking on my door, nor anyone else using it with their own call sign, if there are issues. Without a proper ID how would they know who really is in control of it? It’s a lot less work to get the call sign of the owner from the on-air self ID, look them up in the FCC database then contact them directly. The other choice is having the FCC pull the plug then wait around to see who shows up to check the system out wondering why their repeater quit. If nobody shows up, the repeater is off the air problem solved anyway. Might even pack it up and take it with them on the way out the door. If their nice they could leave a nasty note taped to the empty rack. -
I’ve looked at those cheap repeater controllers. Those are the ones you connect two radios together using the mic/speaker jacks and key the other radio using VOX. The main complaint I have with using one for a quick throw together repeater is the lack of an ID function. I have looked at the “ID- O-Matic” which has it but you need a COR it seems to make the thing work, which of course an modified radio doesn’t provide. So that brought me back to the first option about hacking the hardware to add an ID function. The cheap controllers without the ID could be used in two cases. The first is a half-duplexer repeater, which has the limitations you pointed out previously, and used exclusively by the licensed user. The second is with GMRS, but only if qualified family members use it exclusively since everybody ID’s using the same call sign. All other cases the repeater needs to self ID. The strange thing is the one GMRS repeater by me, which I have the owners permission to use, along with a few friends, I have NEVER heard it ID yet. How the owner is getting away with it beats me other than the FCC doesn’t want to bother with it. It doesn’t get much use so unless you know it’s there you wouldn’t notice. -
I think his was a full cross band, duplex, design. The two radios are cross connected. He did his initial testing with the antenna on his tower. He is also the main radio tech for a local city’s transportation department. He done some tower climbing and repeater installs. Many of his comments are similar to yours. The one I remember most is a story where another tech went out to check the repeater equipment in the shack at the tower base. Opened the door only to discover a huge hornets nest inside. By the time help arrived he was passed out on the ground from all the stings. Luckily he survived. -
That all depends. I have a Ham buddy who built a special event repeater, for local marathons and bike runs, really cheap with some used radios and a good power amp. The way it was done is using cross-band repeating so the expensive cavity filters get ditched. Most Ham HT’s can be programmed to do split band operation. You RX on one frequency on one band, say VHF, and TX on another, UHF, when you press the PTT button. For Ham radio this usually ends up being the 2 meter and 70 cm bands. On the repeater side a simple diplexer is enough to work the VHF and UHF radios into and can be had for $50 to $75 new. Then he takes advantage of the local high rise buildings. Through his contacts he has access to the roof tops. No need for an expensive tower and feed line. When you’re on top of a 10 to 15+ story building you get some decent coverage. Since the repeater can be located close to the temporary antenna you don’t need expensive feed line. And what you do use is fairly short thus keeping the losses down and thus the TX’er power required. Granted his conditions are not the general case but if one looks around and takes advantage of the local resources you can save a huge amount of money and effort. However if one wants to build an in-band repeater, then yes it gets more complicated and likely expensive as you pointed out. -
New Interfering (IX) Signals - "Baby Monitors" using GMRS/FRS
Lscott replied to intermod's topic in General Discussion
The usual non compliant consumer marketed Chinese wireless crap being sold in the US. Some years ago there was a problem with “high power telephone wireless handsets” that claimed 1 mile plus range. Turned out they were operating on the Ham 2 meter band. After a series of complaints to the FCC the issue was addressed.- 44 replies
- ix
- interference
(and 5 more)
Tagged with:
Unfortunately data transmissions are allowed on any MURS channel. While the FCC requires monitoring for activity before transmitting I seriously doubt for automaticity operating stations they employ “busy channel lock out” and just key up regardless. Even with a max power output of 2 watts and a simple antenna a data transmitting station can ruin a given channel for a 1 to 2 mile radius with frequent use. With only 5 channels it doesn’t take many stations keying up automatically to ruin things for MURS in an area. I remember driving through a particular area near me frequently and could always count on picking up a data burst every few minutes on one of the channels. That went on for months. Eventually I locked it out of the scan list in my mobile Ham rig. Like you I found it very annoying. Lately about the only thing I do hear is the local Walmarts, Sams Clubs etc. and seldom at that.
Setting up repeater for GMRS radios compared to base station
Lscott replied to AlphaTango15's topic in General Discussion
That's very strange. I just tried it again and it works for me. Maybe you have some security limitations on your computer. Anyway here is a snippet of what is there. It is a radio propagation modeling program using publicly available geodata. I this this would along the lines of the for pay service you use but for amateur radio, or other radio service, uses. **************************************************************************************************************************************************** Calculations The hart of every RF simulation tool is the prediction model. There are many models that predict RF propagation but the most known is the 'Hata-Okumura' model. This model is 'the mother of all models'. Over the years new models have been developed where the growth of commercial cellular networks like GSM UMTS, and now WiMAX are the main drive. These networks operate in th UHF and SHF bands (450 to 2400 MHZ). Other frequency's are used for broadcast of Radio and TV (VHF and UHF, 50-800 MHz) and a small portion for PAMR and PMR networks. Their focus is in the VHF and low UHF frequency's (50-500 MHz). The prediction models used for these networks are devided by coverage distance. For GSM, DCS and UMTS (900-2400 MHz) these models are limited to predictions over a short range. Due to the nature of broadcast the distance over wich predictions are made is extensively bigger than for cellular networks. The difference in range for the model is devided in to two main categories: 2-way communication or 1-way communication.This choice is influenced strongly by the en-user terminal. A if a uplink is required, a hand held terminal will limit the coverage because these devices have limited transmit power and poor antenna performance. In the case of broadcast A Radio receiver does not need to talk back to the broadcaster so bigger powers do no harm to the link budget. When prediction over small distances are required to be accurate it is important that the influence of local buildings (clutter) is taken in account. when predictions are performed over bigger distances the dominance of clutter decreases and eventually can be left out of the calculations. This simplifies the formula for calculating RF propagation. Accurate RF predictions require detailed clutter and height data bu this data is generally expensive and only affordable when income out of the exploitation of a radio network is high. For amateurradio, emergency services, and students for example it is not realistic to have this accurate data available. Therefore low budget and easy accessable data must be accessed. Radio Mobile uses geodata that is available on the internet for free. Based on the Hata model many other models have been derived. Also models have been improved for their specific purpose. But some general models have been almost the same and available for free. On very well known model is the Longley-Rice model. This model is accurate over a wide range of frequencys and over various distances. Based on this model the US Institute for Telecommunications Science (ITS) created a propagation prediction model know as the Irregular Terrain Model or ITM. Radio Mobile uses the ITM model. To understand the operation and limitations of the model I have collected information about the Longly-Rise and ITM model on this website. ******************************************************************************************************************************************************** The link below is for the "on-line" version. Maybe you'll have better luck with this link. http://radiomobileonline.pe1mew.nl/ This is the snippet from the link above. ****************************************************************************************************************************************************** Welcome To the website dedicated to Radio Mobile Online. Radio Mobile Online is the online version of the popular RF propagation tool Radio Mobile by Roger Coudé. Radio Mobile Online can be found at: http://www.ve2dbe.com/rmonline.html Radio Mobile Online is a radio wave propagation prediction tool dedicated to amateur radio. It uses digital terrain information and a mathematical model to simulate radio transmissions between two fixed sites (radio link) or between a fixed site and a mobile (Radio coverage). The digital terrain information comprises two databases: Elevation and land cover. Those databases are located on the server and represent a total of 198 GigaBytes. Radio Mobile is a popular tool for RF studies. Between 2012 and 2015 663304 studies have been performed and 26198 accounts have been made. More information? Follow this link: RMW Online popularity. *************************************************************************************************************************************** -
You might want to try it again. The website is in the Netherlands. I tried earlier today, no luck. Tried again just a few minutes ago and now it seems to be working. All I did was click on the link in the post using Firefox on my laptop. http://radiomobile.pe1mew.nl/?Welcome... -
I'd like to use my Yaesu FT-60 for GMRS repeater
Lscott replied to kaos26's topic in Amateur Radio (Ham)
That's very true. I have a couple of friends with GMRS licenses, also looking to get their Ham license when the local clubs open up again for testing, that are using non Part 95 certified equipment on GMRS. I had to advise them the use of those radios is not per the FCC rules. They had asked for some advise about equipment and operating. I felt I needed to do that as being a responsible Ham and GMRS operator and not miss lead them. They are adults and can make their own decisions. I just wanted them to be fully aware of what they are doing. Some have pointed out that a number of non Part 95 certified radios are being used for GMRS that most likely meet or exceed the frequency stability, bandwidth and can be adjusted to comply with the power output requirements for GMRS. The opinion that some people just don't care if that's the case as long as the major technical requirements are met is understandable. I think sooner or later the FCC will just throw in the towel on using Part 90 radios on GMRS and make it legal. It likely will be just like the FRS/GMRS combo radio mess. They knew people were not getting the licenses but used the radios on the then GMRS only channels. Rather than waste resources busting people using the radios illegally, or ignoring those people and making excuses for not doing anything, they took the easy way out and just made the already wide spread practice legal by changing the rules. Problem solved, and they don't have to make excuses anymore for not enforcing the rules. Same thing with CB radios years ago. So many people quit getting licenses, or failed to ID per the rules, and the FCC had a hard time keeping up with the volume of license applications they did get, the FCC finally dumped the requirement and made it "license by rule". Again they simply made legal what people were already doing and got rid of a administration headache at the same time, again they took the easy way out. -
Have you use this software before? http://radiomobile.pe1mew.nl/?Welcome... -
Yeah, I can see your point. Many of the older Hams hangout on HF. They might have a VHF/UHF radio but likely don’t use it much except on the morning or evening commute. The other times the portable radio gets used at the Ham Radio flea markets then goes home to sit around until the next one. Alas there are those few Hams that just have an elitist attitude and won’t talk to people with a Tech Class license. Sometimes you can tell by the call sign format the license class. Certain formats are reserved for higher license classes. I’ve kept my original Tech call sign just to surprise those that look me up on the FCC database or on QRZ.
I’m not sure. The few minutes I poked around on the USGS site all I found were the small 7.5x7.5 topo maps that looked like a postage stamps scattered across the Detroit Metro area. I need to spent a bit more time looking around there to see if there is something that covers several counties that can be downloaded. -
Thanks. I’ll have to look at that. I’ve got a friend who is looking for a cheap tower to put up. Something like an old TV type with a multi-band stick antenna. It would good to know what his likely range will look like based on the surrounding terrain.
