MrCoffee
MrCoffee's Achievements
  1. Very interesting, seriously. Somewhere I read through the link that you had gave, a person installed them vertical. Now this may be a much easier and cheaper approach and a simular out come to the folded dipole array. Especially if they were to be home brewed! I appreciate all of you who are sharing your input and ideas. Good read for sure! Sorry that I have not been active. I am only able to be active as the time that I am able to utilize. Thank you all as you all are appreciated.
  2. Okay let's work this out. (Seriously) Point to me where to purchase an omi directional antenna with 12db? Thanks for the reply. MrCoffee
  3. Hello, Has anyone installed an entire system on a tower? I have an outside utility box that I believe its big enough to fit two mobile radios, a duplexer (flat Pack) and a power supply and a fan. My thoughts are installing this near the top of a 50 foot tower and running 120 volts AC up the tower to the utility box to feed the power supply. Also a GFI and any other safety switches to prevent any hazard situations. Also maybe an internet connection to an AC outlet to cut the power off from another location in case of an emergency. I am sure there are other safety ideas and such. Now there will be heat issues in the Summer time and probably moisture issues too. In the winter, perhaps moisture as well. Also I am sure there will be some insect or even ants finding their way in as well. But is there anyone who has given this a try? I am looking for results, and of course issues! Since there will be signal loss in the flat pack, and of course in the coax if ran at long distance, this may be an alternative way to get a better signal over the air. Happy Thanksgiving to All! MrCoffee
  4. Sorry I don't get a chance to get in here as often as I would like. Understood on a good duplexer and to have it correctly tuned. On your duplexer, roughly where are you located? Thank you for your reply.
  5. This is a very good reply, well said. Only thing I would like to add. When making a purchase on a radio, be sure the output power will work on the band you plan to use. I found that the 706mrk2G will transmit on GMRS but the output power drops down to about 1.5 watts. WRQC527.... very well said.
  6. I was told a long time ago that each connection takes about .05db from the circuit. It's been a while since I was told so, and my memory isn't the same back then! You can look it up. I personally would have soldered type connectors installed and then have it electrical taped, then some sort of coax seal over the tape and then taped again to protect the coax seal. The first layer of tape protects the connectors from getting the coax seal stuck to the connectors in case you need to separate them in the future. It is always best to have one complete run of coax instead of using a barrel connector. Speaking of which, an 'N' connector should be used for UHF and above. Really 100 mhz and above in my opinion but anyway....
  7. Hello WRKC935, I'm sorry if in my reply sounded as I was maybe angry or disturb or... I guess I was just explaining who I am relating to your reply. Something like that anyway! Also I had worked on installing a new antenna for a friend all day yesterday and the heat from the sun worn me out! I did not take your reply in a harsh way, at least as far as I recall ! Just the same, I'm sorry if I did. Thank you for bringing this to my attention.
  8. I try to be considerate, I don't like confrontation. That doesn't mean I will be quiet, but I will try to void any issues if possible, for the reason for this post. Life is to short, time flies by and later you are ask, where did it go? Thanks for chiming in.
  9. Thank you, but I have had the cables and the connectors for a long time, its about time I start using them! My tower may be anywhere from 30 feet to 125 without counting the run to the house. More than likely though, I will probably place the tower height at 40 or 50 feet. I been around cells sights and other communications for a long time. However I need to learn the in and outs of GMRS. Connections, type of cables, how to seal the connectors, radius of the hardline, grounding, SWR, pointing Yagi antennas, tuning antennas...I have that covered. I just need to know the ins and outs basically. Meaning a good Repeater antenna, a good duplexer, and later down the road a good solid GMRS repeater instead of two mobiles connected for RX/TX. I can make all the connections, climb towers, install towers along with guy wires, and so on, as I have been learning all of this since I started in radio communications at the age of 10. I enjoy the installation experience more then anything! Thanks for the reply.
  10. Yeah that is an issue isn't! One guy says he will tune it on my frequency. ($450.00). The other guy buy as is...(300.00)
  11. Thank you Steve. I will be glad to post back when it happens! Everyone has been very helpful.
  12. I never thought of that idea. I would first have to find who they are. I can't seem to access their repeater. Not sure what tone they may be using either. I have tried all of them! They may have some other coding/tones that I was not trying to use too. It seem that they may not be listed either, but I am not totally sure on that either. I am still searching. Thank you for that "Food for Thought"! In my opinion, that is a very wise thought.
  13. Thank you for your reply and for your help on the antenna and the cabling. I have posted about what antenna to use so to speak or at least an idea of an antenna. I will look up the Laird Base Station antenna. I have several towers that I can employ for height purposes and maybe horizontal separation. However I think I want to keep it as simple as possible in the beginning. (KISS) So I probably will just use one antenna and a duplexer. As for cabling, I have some runs of LDF4, LDF5, and even some LDF7. Maybe even some LDF6, not sure how much though, but cabling I do happen to have. Thank you for your insight and as mentioned I will look up the Laird Base Station antenna.
  14. Hello Steve, Perhaps? Just not at the moment. The group are mostly retired and doesn't have much or any experience using UHF frequencies. At the moment two are trying to communicate simplex. One using a HT only and the other did install a J-pole at maybe 20 feet. The one one with the HT is at lower elavation and the separation is a bit to far, well with only a HT. The group would rather talk simplex or on a private repeater with no one listening in except for the group. Two others can hit one of the repeaters that might be 30 to 45 minutes away. Maybe 30 minutes the way the crow flies. We are all generally close to one another. The one with the HT happens to the fartherest away. He does have a 20 or 30 foot tower that might help aid in getting signal across the way later on. I have purchased the Retevis RA87s and I am planning to installed them together for repeater usage. I figure they may be worth experimenting with as I have mentioned before due to their low price. I have my eye on a couple of DB Duplexers that may cost me $300.00 to $450.00 depending what one I might be able to buy. Anyway thats where I am coming from other then I also think it will be a good experience for me and hopefully for the others as well. Thank you Steve, I do appreciate your replies.
  15. I appreciate the reply as I do from all, thank you. I sense a sign of hope!
