kidphc
    16
Everything posted by kidphc
  1. You have all the awesome toys!!
  2. You are going to look like a porcupine, just try to get over it fast. If you are lucky enough to get a tower and some verticals. In my land the Sauron (HOA) has eyes on all. I'm not allowed any antennas outside of satellite dish. Even then it has to be hidden. I have no trees on the back side of the house and the house is viewable from the street on all sides FML My psedo elmer gave me this article to ponder. He also advised against attic installs, he had it once and was un happy. Guess where all mine are going even with that said. Early plans are 40m,20m,10m,6m home brew fan dipole (the 40m will be in a ramsay configuration) with commercial balun. Diamond x50 or x300 (depends on how much space I have left over from the fan dipole). and a M2 stacked halo for 2m ssb. http://k3rrr.com/wire-antennas-287-different-wire-antennas-to-choose-from/ I hope to add either a scorpion screwdriver home setup or crank ir in a couple of years. If you have trees on your lot in the back. Go for a fan dipole in the trees or long wire. The tree that is circled decided to rest on my neighbors house so it is gone now. Current Progress of setup
  3. Yes. The recieve has been better when I have added cattails. It works best when you get it close to the 1/4 wave of the frequency in use. I had the best results with 2m with a 19" cattail. The abree made no difference with the cattail. I believe it is due to the coil at the base of the antenna. Which looks to be the counterpoise. Sent from my SM-G975U using Tapatalk
  4. Good to know. I still have a valid VWare from my days at EMC.
  5. Just remember there is a lot of loss on 70CM as well as 2m in the coax. Don't get cheap, hopefully you'll only be doing the run once. Here is a chart from DXengineering that will show you some of the losses you can expect. Don't expect a cheap Chinese LMR 400 to have the same losses as something from Times microwave. In fact from reviews the charts that the cheap chinese coax company send it's not even close, almost double the amount of loss they specifiy. https://static.dxengineering.com/global/images/chartsguides/d/dxe-11u_us.pdf
  6. Did you try setting the backward compatibility in Windows 10? Right click icon. Properties Compatibility tab "run this porgram in compatibility mod for" "windows 7" or "windows Vista sp2" Doesn't always work but can work wonders for some software
  7. Ok. First off. I do not know how to property test Ht antennas. A calibration was done with the SMA extension for each frequency band when changed. All antennas are authentic from what I can tell. The Nagoya's are from Btech and the Abree is from Abree. Nagoya 701c 144.000 1:1.38 146.460 1:1.15 147.999 1:1.32 420.000 1:2.06 450.000 1:2.21 462.5625 1:2.15 467.7250 1:2.13 Nagoya 771 144.000 1:1.23 147.999 1:1.50 420.000 1:1.55 450.000 1:1.14 462.5625 1:1.37 467.7250 1:1.45 Abree 42" 144.000 1:1.55 147.999 1:2.02 420.000 1:1.55 450.000 1:1.84 462.5625 1:2.24 467.7250 1:2.38 There was a big difference between holding the coil of the antenna(base) and the lead. Unfortunately, it isn't like an MFJ analyzer where I could screw it into. So I chose to hold them by the coil except for the Abree. Holding the Abree by the coil it would go from 1:1.55 and then jump to 1:6.63. Even laying the antennas on the table it would jump by quite a bit. Try holding a 42" antenna by the SMA lug, my fingers hurt.. Again take this with a grain of salt. Should add, for GMRS the 701c is the one I would go with. The 771 works but I perfer the 701c. The Abree rocks for 2m.
  8. Yes correct. Miss info mis type no difference it was the wrong info. The info I typed turns out was for proposed c4fm national simplex calling. Which apparently there 3 different frequincies. Sent from my SM-G975U using Tapatalk
  9. I know to get accurate numbers its difficult. So I won't be doing any soon. As long as the antenna is equal to or greater then a dummy load I am good. I should say I don't mind as much since most hts can handle the higher swr. Sent from my SM-G975U using Tapatalk
  10. yeah. Not keying up with the ft991a any more on vhf. The baofeng, well its a baofeng and a ht.... so I will be pounding the ptt. Sent from my SM-G975U using Tapatalk
  11. Here is the video on swr (standing wave ratio). Long and reminds of video from grade school. But worth it. Sent from my SM-G975U using Tapatalk
  12. Sorry the third part. You can use a sealant for the connectors. It is available from most radio shops. I'd use a weatherproof boot specific to the connector and maybe some electrical tape. Problem with heat shrink is if you need to remove the wrap to service the connector you need to cut it off. In doing so you may cut the cable. Sent from my SM-G975U using Tapatalk
  13. Low swr is better. 1:1 means you are getting all the power out. Higher means you are getting reflected power or wasting some as heat. There is an old video (50's 60's) that explains it with models. Swr is not the end all to antennas and many focus on it too much. But generally strive for lower. Db is the increase of gain on the antenna. Dbi means it is based off a reference. Usually DBi gives you a better idea of increase in gain to a reference antenna. Where db may the gain vs a pencil for all you know. So 3 db with make your 5 watt radio equal to a radio with 15 watts of power with no gain. The higher the gain value normally the radiation pattern is flatter with a higher take off angle. For example 1/4 wave antenna is a bit more spherical (like a ball). So when offroading it can be beneficial if you are going up a dune at the crest and there is a truck below you, you'll can hear him. With a half wave design the pattern is flatter and you may not hear him. However, when using a repeater from a mobile the 1/2 wave can more beneficial because then repeater is higher and you have more gain. Sent from my SM-G975U using Tapatalk
  14. Here is a little review. Since I got the Nano VNA f I decided to test an antenna that I have had for a while. I had bought 2 for a road trip. Btech sells them for $29. They are a lot cheaper then buying a magnet NMO and nmo antenna. I have been happy with the 2m (144mhz) performance, It has ok performance with GMRS and I feel it has been meh with 70cm (444mhz) performance. So I wanted to see what the numbers were like as far as SWR. I have been mostly using it for repeater usage on 2M and GMRS. No luck on 2m simplex, FRS/GMRS works well for simplex when in range. Furthest GMRS repeater has been to Alexandria give or take 11 miles from the truck. The same antenna, is being tested on a cookie backing pan in my dining room connected to an FT991a. I have managed to connect to 2m Frederick MD repeaters which are 27+ miles away on 5 watts. Still can't make a simplex call 5 miles with the same setup running 30 watts. The stats from BTech 's website: https://baofengtech.com/NAGOYA-UT-72 Frequency Range: 136-174MHz, 400-520MHz; Optimal Frequency Range: 140-170MHz, 420-470MHzWave: 1/4λ (144MHz) - 5/8λ (430MHz)Gain: 3.5dBiMax power: 80 WattsVSWR : Less 1.5:1Impedance: 50 OHMConnector: SMA-F & PL-259Length: 20 inches So the VNA is showing the following. 144.562 National 2m SWR 2.53 :1 144.000 MHz SWR 2.89:1 147.999 MHz SWR 2.21:1 159.300-163.500 lowest SWR of 1.18:1 420.000 SWR 1.92:1 450.000 SWR 1.33:1 444.900-445.800 lowest of SWR of 1.3:1 FRS/GMRS Frequencies 462.5625 SWR 1.35:1 467.7250 SWR 1.40 SWR was 1.35-1.38:1 for most of the FRS/GMRS band. Lowest actually was at 1.27:1 at 464.575 - 465.763 MHZ well outside of Amateur radio and FRS/GMRS service allocations.
  15. Congrats!!!. I have the FT991a... it's an awesome radio. Well minus the menu system, 99 memory slots and lack of a true second vfo. I personally bought it for an intermediate radio. I wanted a 10m,6m,2m,70cm radio, really to utilize a lot of the technician license. I really hope to have the fan dipole, 2m vertical and 2m horizontal up soon. If you want something like that to grow into there is also the IC 7100. Then you have the likes of icom 706 mk2, Icom 7000, Yaesu FT857d that should be considered. Even a baofeng will get you on the air. As soon as you get your call, you'll be legal on the 2m and 70cm bands with that radio. Which you already knew. However, I would suggest you spend a little more and get something like a Yaesu 60r. If looking at HTs. Don't exclude some of the mono band mobile units for base station usage. Oh talk to club members. Again a lot of them will loan stuff till you get your own gear. Just to get you on the air.
  16. Do you know what a forum like this would look like if they allowed dmr on those frequencies. Gmrs/frs were meant to be pretty much plug and play. Have Bob and his family trying to do a code plug would be a nightmare for all. Couple that with big companies saying how easy it is to program.. I have seen seasoned hams have a hard time with. I suspect alot more of the services being narrow banded to squeeze as much as they can out of the services. If you are talking about pre-installed code plug then maybe. Sent from my SM-G975U using Tapatalk
  17. You really want them to go nuts. After you tell them why, run a script that has it trying to track different sats. So the assembly is going nuts tracking and skipping to another sat and goes nuts again seconds later. Chance are they will grab a sledge hammer and help you tie down some guys through the asphalt.
  18. Just tell thjem the white house asked you to put it up for the testing of their early detection of incoming UFOs. Once it starts tracking they may shut up.
  19. MarcSpaz showed a portable antenna on a mast in the following post. He was kinda enough to put up the SWR number he was seeing both with the Diamond x30 and x50. I could of swore they made a commercial variant of the antenna designed for about the frequency of GMRS. Not sure what the numbers or model were. https://forums.mygmrs.com/topic/1723-new-portable-repeater-antenna-setup-is-done/ It was laird and comet, that made antennas closer tuned closer to the GMRS frequencies. Not sure how well they work. . https://www.theantennafarm.com/catalog/comet-ca-f72gf-1067 You also have the likes of Ed Fong, who customize to your desire, you just have to provide the outer shealth (PVC), which is a jpole design.
  20. A good 1/2 wave mounted to the roof. If you are going to use it on a mast, you are probably going to be happy with one that has radials. Sent from my SM-G975U using Tapatalk
  21. They do make power port passive diplexers. Not sure if that will help. The satellite hams sometimes but rarely use something similar. Not sure if that is any help. I don't know enough about the topic to really offer much. But this might lead you down the path till someone can chime in. Note this is 75 ohms.. really for satellite dishes not ham/gmrs use. https://www.summitsource.com/Channel-Master-4001IFD-Satellite-Diplexer-Separator-Mixer-VHFUHF-CM4001IFD-950-2150-with-DC-Pass-High-Performance-In-line-IF-Satellite-Diplexer-Digital-Video-Signal-Part-4001-IFD-P11530.aspx
  22. There are some interesting set ups. I can't find the need for 4-5 2m/70cm setups, yet there are tons out there. Outside of tactical control. But eh each to their own.
  23. Don't you live in a circle? I know where you could put your satellite antenna. Lol your neighbors might get the pitchforks out though. Sent from my SM-G975U using Tapatalk
  24. A ham in neighbor hood. Love the trees for his long wires. Hated it for the satellite work. The 2m uplink was fine but the 70cm downlink was constantly wrecked in the the summer due to the leafs.
  25. Should also add don't forget the feed line losses of the given line of coax... that could easily sway which way you go. Any gain from antenna design could easily be lost by choose the wrong feed line or being cheap about it. Feed line loss gets pretty bad the higher up you go in frequency. A piece of coax might have a loss of 1.2db at 144mhz but at 470 it might be 6-7 db loss per 100 feet. That is without the connectors.
