WSDU416
    BriarMay
    Sussex, NJ
WSDU416's Achievements
  1. In this instance - that field can't be changed. It's grayed out.
  2. Good point - anything glaringly wrong here? I just tested again with the below and it didn't work.
  3. Hi - I'm new to GMRS. I have two Baofeng GM-15 pro radios. I'm using Radiodity GM-30 software. The repeater I'm trying to program has both an input and output tone of 131 DPL. I programed the following configurations into the radios and none have worked. D131N in both input and output D131i in both input and output D131N in input and D131i in output and vice versa. And lastly 131.8 in both input and output I was hoping to guess and check my way to the answer and reverse engineer my brain but that didn't pan out. Can anyone shine some light on what the problem is? Any help is appreciated.
  4. Holy moly - it never crossed my mind that "username" for the repeater info is actually the call sign rather than my email address I use to log into the forums. I just tried my call sign instead of email address and it totally worked. I'm in! yay!
  5. I'm sure - because I'm logged in with my call sign in the forums but I can't see the repeater info. There's a disconnect between the two. You can see I'm logged into the forums with my call sign.
  6. Thank you and Merry Christmas to you as well!
  7. I'm having the same problem. Was there ever a resolution to this problem? I'm logged in and able to access the forums and my profile but when I try to access repeater information I'm asked to log in again. When I log in using the same username and password - I get an error message stating my credentials aren't valid. I've already reset my password so I know I'm using valid credentials. I emailed a moderator and messaged site support a few days ago. I like the map set up on this site but I can't use it. Is there another site anyone can recommend with the same info? I searched, I didn't see anything as well laid out and I'm chomping at the bit to get my families radio set up. Any guidance is appreciated. Lauren
