WRTK502
About WRTK502
  • Birthday 03/24/1992
    Chris
    Colorado
  • Interests
    Touring/Overlanding
WRTK502's Achievements
  1. So it has been a bit since I was on here and I can say I got a good amount of responses. That said the first one was a bit hilarious. I have a feeling that marc has not looked at the antennas mentioned let alone the antennas that the Australians use for those CB Radios. With that all said I found out that the Ghost Antenna is not meant for much if it isn't grounded well. That was something I found out recently from Midland. Because of that I decided to go ahead and purchase the Highland antenna. Why? Because that antenna does not require a Ground Plane. Because of that I should technically get better performance causing me to get better range(within reason). Now for those wondering why a 3dB antenna has been chosen over other antennas, I understand my particular use. I don't necessarily need to talk to the moon, but I know that a good antenna paired with a good radio you can get an excellent range in multiple terrains allowing you to speak to others and get weather information from NOAA(if there is a tower nearby). The antenna was just ordered today and I am looking to get it installed in the next weekend. Once that happens I will test the performance and report back.
  2. Hello all, I have a question related to the rules for Canada specifically when it comes to using mobile radios like the GMRS or others. I myself do have a license to operate a GMRS Radio in the US and I currently have a Midland MXT575 Radio in my vehicle. I also have a Garmin Tread equipped with the Group Ride that uses MURS at 5 Watts at best. In the near future(probably in about 2 years) I see myself moving up to Canada for work and I'm curious if I will be ok to keep the radios I have(even if it means getting the appropriate license) or if I will need to change the radios on the vehicle. Any information will be helpful!
  3. Hello to all as I am a bit new here, but not entirely new to GMRS. I had a question related to the Antenna height. So I personally use GMRS in my adventure vehicle for Touring/Overlanding. I currently have the Midland MXT575(50 Watt Radio) in it and I can say that is a nice radio with the power. I also have the Midland Ghost Antenna as well which is a 3 dB type Antenna. It is mounted on the roof to help clear any instructions on the vehicle, but here are a few things on the roof that are kinda in the way(recovery boards, fuel cans, water tanks and whatever else I may throw up top). Something I have been looking at and considering is the new Midland Highland and Canyon Edge 3 dB Antenna's(28-28.5 inches tall over the 3.5 inch Ghost). If anything they would be taller and still be mounted on the roof. I would also make sure to have the folding base for when I don't have it in use. My only question is would there be any benefits other than not having to worry about obstructions from item on the roof? Again I would be staying with a 3 dB so the projection pattern and range should be the same if not mistaken. Thanks in advance
