WSFF627
WSFF627's Achievements
If the repeater is listed as "open" you do not need to request access. It really depends on how often a repeater owner checks their email and logs in to approve requests. There is little a repeater owner can do to prevent people from using a repeater with published tones. There are also radios capable of scanning the tone to gain access, GMRS repeaters really are not secure.
As lots have mentioned here Heliax is the ideal choice. However you need to decide how much you want to spend. LMR400 is cheapest, LMR600 is more expensive but loss wise more comparable to 1/2 Heliax. For your length the dB loss doesn't justify the cost of 7/8 Heliax in my opinion. Yes the LRM types risk noise in full duplex operation, however that's more prevalent in wattages much higher than 50 watts and when there is a bunch of cable flex. I ran a test on a 100 watt 70cm HAM repeater for a while on 65 feet of LMR600 and didn't see a noise issue. Yes 400 will work but is not the best choice due to higher loss. Everyone thinks about TX and power out loss, but not many talk about RX loss, and a pre-amp cant do something for what never makes it to it. In high RF environments or with poor filtering, or a combination of both, they can do more harm than good. If your going to try one, get if from AdvancedReceiver.com I have several of them, they work great, and if you have a service monitor and the knowledge, can adjust them. Large Heliax is the best performing choice, and the most expensive, the connectors alone are $35 each. LMR600 is a good economical and good performing choice. Its actually in service in a lot of commercial setups on short runs, so is LMR400. But you wont find either going up a commercial tower due to loss and the noise issue at high wattage. Andrews and Times Microwave also offer grounding kits for LMR600. I recommend grounding the cable shield as well as a good quality (not a cheap amazon) lightning arrestor. A good one will run you $100 or so. Check repeaterbuilder.com It has lots of good info and a copy of the Motorola site standards, which you may find very helpful. I own and operate a GMRS repeater with a 60 mile radius as well as a 70cm DMR HAM repeater that can go farther (both have site elevation to their advantage, they are high). I've also put together other large footprint repeaters at commercial sites.
WSFF627 reacted to a post in a topic: Repeater Antenna
I'm wondering what coax your using. I'd recommend 7/8 heliax or similar due to the length involved. You can often find some good used cable from radio shops that they have removed from service on a commercial site. Also run a jumper from the main feedline to the antenna to allow for movement between the two in order to take stress off the connectors. A loose connection will cause desense and drive you nuts. I'd also recommend a RX preamp from Advanced Receiver. I have a handful of them and they make a big difference. To your comment about getting above the trees, your right on point there, just getting above the tree line will make a big positive improvement. Also, ground the coax toward the lower end of the tower above where it bends to go into your repeater location and take the ground straight down towards the ground to a proper ground rod. The lightning arrestor should be located just outside the building. Repeater Builder has a section on Motorola site standards that is helpful. Here is a site you can model your coverage on https://www.ve2dbe.com/english1.html
WRYZ926 reacted to a post in a topic: Battery Backup
Lots of good options have been discussed here. All work relatively well. For a base radio, pretty much any 12 volt battery will work. Keep in mind that TX power can vary greatly with battery voltage. 1-2 volts can mean the difference between 35 watts and 50 watts, depending on the radio. Granted, this is only a couple of dB, but those may be the dB's you need. Battery power for base radios can be pretty easy, and all the options above are pretty good and will work for your application. Repeaters are a different story, while you control the use of your radio, repeater use can vary quite a bit and be a lot more demanding. A typical radio is built to TX with a 20% duty cycle, a repeater is built for a 100% TX duty cycle. I run a 50 watt GMRS repeater with a large footprint, a 100 watt 70cm HAM repeater, and a remote RX station for a very large 70cm HAM repeater out of my "repeater shack". The GMRS and remote RX are Kenwood TKRs which run on 13.8vdc, the GMRS has an amp for duty cycle at 100%, and both are running pre-amps at 13.8vdc. The power supply for them is a Astron 50amp with built in battery backup. Its battery backup is 12vdc. The 100 watt 70cm repeater is Motorola MTR3000 (100% duty cycle at 100 watts), which requires 28vdc and a battery reverting charger (its also equipped with a pre-amp that its built in supply handles). Battery capacity is sized to run the repeaters under full power with moderate usage for at least 24 hours before they have to transfer to an inverter generator (regular alternator generators produce very dirty power). Its essential the 70cm remote RX stays on the air because its part of the SKWARN network. The other HAM repeater may join it in SKYWARN service in the future, likely in digital or mixed mode. Its also pretty important the GMRS repeater stays on the air because users have expressed they want and or need it for emergency comms with family and friends. Currently I have to transfer power to generator manually, but I'm planning an auto start and ATS project for that so its all auto. The best power / battery backup option for you is one that works for you and costs what your willing to spend on it.
Just tuned one today. Confirmed at 0.6dB insertion loss on the service monitor. https://www.bridgecomsystems.com/products/4-cavity-txrx-350w-uhf-duplexer?currency=USD&variant=41431623172261&utm_source=google&utm_medium=cpc&utm_campaign=Google Shopping&stkn=d6eaad281b8a&utm_source=Google_Ads&utm_medium=Duplexers_Shopping&utm_campaign=Duplexers_Shopping_Campaign&tw_source=google&tw_adid=664925858611&tw_campaign=20342176746&gad_source=1&gclid=Cj0KCQiAlbW-BhCMARIsADnwasqZg1QSmh5e4yADfPU4xLrwHKAbWB9BFk2ZIo6jHxDCf44DJQ4fp-AaAj7BEALw_wcB
Thats correct. TXRX duplexers have the lowest loss of any duplexer I have seen. 0.6dB, some loss, yes, you should see 50w in and 41-43w out of the duplexer. A lot less loss on the RX path, which in my opinion is more important than TX power.
Sorry for being short,, only got a sec... Bridgecom not bad, set tx at legal 50w out of the rpt. A good TXRX 4 can 350 watt duplexer, 0.6dB insertion loss will offer the best post duplexer wattage. Obvioulsy dont forget loss is a two way street.. Advanced Receiver makes nice pre amps. I run them on all my projects.
Nice!! That's quite a lot of feedline. Doesn't surprise me. All probably using the same type of feedline. 2M VHF doesn't loose nearly as much in the line as 70cm UHF. GMRS (UHF not far from 70cm, as I'm sure you know quite well) with 500 +/- less feedline. Any pre amp will also play a part on the RX side. For the sake of argument lets assume the tower is using Heliax LDF6-50 1-1/4 inch feedline. Feedline loss only, in addition to any combiner or duplexer, etc. loss. Rough numbers only. VHF at 900 feet is about 2.89 dB loss (125w TX,48% power loss) UHF at 900 feet is about 5.27 dB loss (125w TX, 70% power loss) GMRS UHF at 400 feet is 2.44 dB loss (50w TX, 43% power loss)
WRYZ926 reacted to a post in a topic: Line of sight
WRUE951 reacted to a post in a topic: Line of sight
SteveShannon reacted to a post in a topic: Line of sight
Line of site theoretical vs practical, in theory in space with nothing to attenuate the signal, very, very far. ISS contacts happen all the time with 5w or less. In practical application on earth, it boils down to terrain, geology, height above average terrain, occasionally ducting, and the equipment in use. There are simply too many variables in play to say it will go X miles. All transceivers and repeaters are not created equal. My Motorola's have the best receivers, my Baofeng's the worst. A repeaters performance varies greatly based on its antenna height above average terrain, antenna type, quality and gain, overall losses from feedline, duplexer and jumpers, if there is an RX pre amp, RF environment (other RF at repeater site) etc. I can have a conversation on my repeater at 30 miles from some locations with a 4 watt Motorola portable. Standing in that same spot, a 5 watt, $15 Baofeng sometimes works, sometimes does not. I can also move 10 feet and it will no longer work.
WRUE951 reacted to a post in a topic: Imagine Nationwide or International Coverage of your GMRS Repeater, Legally!
WRHS218 reacted to a post in a topic: Imagine Nationwide or International Coverage of your GMRS Repeater, Legally!
kirk5056 reacted to a post in a topic: Imagine Nationwide or International Coverage of your GMRS Repeater, Legally!
WSGZ436 reacted to a post in a topic: So who here uses GMRS properly?
SteveShannon reacted to a post in a topic: Imagine Nationwide or International Coverage of your GMRS Repeater, Legally!
CogentRadios reacted to a post in a topic: Imagine Nationwide or International Coverage of your GMRS Repeater, Legally!
I understand what your trying to do, its a cool idea and I sincerely hope it works out for you. However, I believe the FCC is going to tell you you cant do it because it is a clear violation of the rules as written. POC uses the Cell telephone / data network. It is a network in every sense of the word. As I and others have stated before, yes you can connect a repeater for remote control of the repeater, you cant do it to carry messages / voice comms. In any case, please keep us posted with the FCCs answer. This is and has been a good conversation.
Please go read the Law. Its clear you cant operate on digital modes on GMRS. Its clear you cant connect GMRS to another network for comms. I don't need an attorney to take it to court to show its illegal, its written in the law. This horse is dead. If you don't want to read the law or are looking for bits and pieces to justify what you want to do, go hire an attorney for a few hundred to review it and give you a legal opinion. Or do it anyway and end up on the FCC enforcement radar and risk it. Telling people what your doing and selling them a product or service that is not legal opens you up to liability. Hire an attorney and get a legal opinion from them.
I'm not saying it wouldn't be a win, but currently what your doing is not legal. Also, it sounds a lot like your talking about DMR talk groups on GMRS and taking a page out of the HAM / DMR / Brandmeister playbook and marketing it. All of which is available on the HAM bands for free, including linked and worldwide repeater network, hotspots, etc. as I'm sure you know. Now I'm knocking you for trying this, cant really fault you for it. But at the end of the day, GMRS does not allow it and does not have the bandwidth other radio services do, like HAM, which is easily accessible to the public.
WSFF627 reacted to a post in a topic: Imagine Nationwide or International Coverage of your GMRS Repeater, Legally!
