intermod
    8
intermod last won the day on May 24 2021
intermod had the most liked content!
    San Francisco Bay Area
2197 profile views
intermod's Achievements
  1. The real question is how we can re-program the analog side of this radio to make it more flexible. On FRS frequencies, of course.
  2. Thanks....I probably should have read the submission date on the FCC site. My attention span continiues to diminish.... G
  3. Did the Commission ever respond to this, or even acknowlege it? Update: Nevermind - he *just* submitted it
  4. In general, no. The number of IX complaints we have filed - 98% are maritime issues on 467.600 - now number about 190+ over five years. The FCC regional director here in the west has attempted to pursuade DC to issue a general notice to Maritime companies, but I don't think he has been successful yet. But the FCC requires us to do quite a bit of foot work in advance - and I can't when I get busy at work. The FCC did put us in touch with the Port Warfinger (yea, there is a maritime position with that strange name). This person can help identify which vessels have just arrived - and you can correlate this with the start and end of the IX. The FCC usually asks us to record the traffic and email it to them as well. However - the FCC has responded several times, but the offenders are only there for 1-3 days, so they miss them. And the FCC does not work weekends. In some cases, where the FCC could not respond but we needed the offender to immediate cease (as we were having an event, net or some such on our repeater), we would contact the offender direfctly on 467.600 using a remote base station we temporarily installed (set for the tone they were using); we were sometimes able to get them to change channels (all of them seen to understand english). But that is no longer permitted after the FCC has restricted GMRS network connections for conveying messages. So our problems are now going unresolved.
  5. Mistake #3: Fail to Communicate with Existing (Incumbent) Repeater Licensees You fail to coordinate access codes with the other repeater owners on your channel and install your repeater anyway. The incumbent(s) become unhinged and pissed off. You also fail to realize that some repeaters use multiple access codes (for different user groups), and may also be using unmatched code pairs on the repeater uplink and downlink (i.e., repeater access/uplink uses 141.3 Hz, but its downlink uses 85.4 Hz). While this can be closely related to Mistake #2 described earlier, it’s also possible you are using one of the incumbent's codes. You could have attempted to contact the incumbent and ask whether they were using any of your proposed codes (via mygmrs.com, over their repeater, or by reading their Morse code repeater ID and getting their address through the FCC website). Or - you could have researched the codes in use the traditional way: purchasing one of the essential tools used by repeaters owners for decades, called the "CTCSS/DCS decoder". Also, many new radio models will automatically decode and display downlink codes when set correctly.
  6. Agree. Another question: As GMRS licnesees, are we obligated to accept interference by the rules, regardless of the shared channel environment? I believe that FRS users are obligated to not cause IX, and must accept IX.
  7. SteveSHannon is correct. All of them were approved under FRS rules. However, there is no restriction on "continuous carrier" modes under the 95.3 (general) area or the FRS rules. This is a problem that needs resolution. This can be resolved with one sentance in the rules. We ordered several models of these to test a few years ago (thankfully Amazon has a Free Return policy...). At the time, we were searching for models operating on 467 MHz GMRS repeater uplink channels. There were some models that did this (we never found the model). However, their operation on 462.725 MHz regularly interfere with reception of licensed GMRS direct and repeater communications. They seem to propgage well, assuming they comply with the 2-watt requirement. I am going to look for a rule that restricts one-way communication in FRS.
  8. Excellent idea, but somewhat inconvenient. But why not do real time-slicing? If the FCC would permit DMR technology, it would provide two discreet channels/time-slices (slots) - one for each user group - to use *at the same time*, and would only require half of the standard GMRS channel. Maybe I should not have mentioned DMR - it triggers some people.
  9. Mistake #2: Ignore the 467 MHz "Uplink" Problem You choose a unique repeater CTCSS / DCS / PL / Privacy code, but other incumbent repeater owners become unhinged and pissed off. That is because signals from users trying to access your repeater are still being heard by the incumbent's repeater *receiver*. Those signals don't activate the incumbent's repeater - but they still exist and can block or walk on the incumbent's users, particularly when the incumbent’s users are operating handheld radios. CTCSS / DCS / PL / Privacy Codes, etc. only prevent inadvertent repeater activation - they cannot prevent uplink IX. Clue - your repeater's transmitter is not causing the interference; it’s your users' transmitters that are causing this type of interference. This cannot be fixed by making any adjustments to your repeater. Of course.
  10. This is correct. After working with business frequency coordinators in the Part 90 bands (450-470 MHz) for many years, the same approach applies there - if you can't find a clear channel, you can still coordinate, license and install your repeater at the same site as another licensee operating on the same frequency (assumes neither is an FB8 class - centralized trunked). Just don't interfere. This often works out fine because the incumbent repeater is not being used (user moved on, or seasonal), or no longer exists, even though a license still exists. It really is the best way to fully utilize spectrum. However, the FCC's disservice was to lengthen the license term from five to ten years, resulting in tens of thousands to Peper" or non-existent repeaters.
  11. Planning a new repeater? What are the most common mistakes a new repeater owner makes? Below is Mistake #1. Additional installments are forthcoming. Mistake #1: Using Mygmrs.com to Find a Clear Channel You pick a channel from the Mygmrs Repeater Database having the least number of repeaters, or nothing immediately close by. You end up causing interference (IX). Other co-channel repeater owners (e.g., incumbents) become unhinged and pissed off. Many existing repeaters, particularly those that have existed for decades, are not listed in Mygmrs.com. Often, these owners may not want the hassles of having multiple users, and prefer to avoid repeater kerchunker's, weak scratchy handheld radio users that are really annoying to listen to, and poorly performing radios (see Note 1 below). Also, radio signals can travel 150+ miles with no obstructions, even portable radio signals. There are possibly other repeaters just 50 miles away that are at a high elevation (or on a tall tower) that can hear your users just fine, causing IX. Notice I said “your users” and not “your repeater”. This will be discussed under Mistake #2. (Note 1: The current trend in Cheap Chinese Radios [CCR] are models with unresolvable low transmit audio/volume, very poor quality audio [includes poor quality speaker/microphones] and improper default settings, like Roger Beeps.)
  12. As your repeater existed first, ask the other repeater owner to move to a different channel. I think the other repeater is programmable, and a duplexer tuned for that particular channel would likely not require retuning as the frequency change is minor.
  13. But we can get 25 mile range on this portable radio, right?
  14. This is where many groups should really start. The organization can pay for one commercial (or public safety) license for ~$300 (for 10 years) and be assigned one callsign that everyone uses. As opposed to every member having to figure out CORES, FRNs, and pay $35 for a GMRS license. GMRS may have been used originally due to the low-cost radios, but Part 90 radios are just as low cost today. Eventually PII (Personally Identifiable Information) will be enforced for CERT and SAR organizations, and FCC rules permit encrypted transmissions on commercial and public safety channels. And they allow for digital for greater clarity and capacity. And they can be linked easily and without controversy. And have slightly greater protection from interference, particularly if the groups chooses to use public safety catagory channels. Downsides?
