wrci350
6
Everything posted by wrci350
wrci350 replied to SvenMarbles's topic in General Discussion
I think you spelled "Part 95" wrong. Part 90 rules do NOT apply to GMRS, any more than Part 97 rules do (or vice-versa). Part 95 has its own definition section (95.303) where we find: Base station. A station at a fixed location that communicates directly with mobile stations and other base stations. Control station. A station at a fixed location that communicates with mobile stations and other control stations through repeater stations, and may also be used to control the operation of repeater stations. Mobile station. A station, intended to be used while in motion or during halts at unspecified locations, that communicates directly with base stations and other mobile stations, and with control stations and other mobile stations through repeater stations. So as defined by Part 95 (which covers GMRS), if you have a radio at home connected to a power supply and antenna on your roof and are talking simplex to either a mobile (which includes HT) radio or to another 'fixed' installation, that's considered a base station. If you are using that same radio to talk through a repeater, that's a control station. The fact that some think those definitions are "dumb", or don't make sense is not relevant, nor is what Part 90 might say since Part 90 doesn't apply to GMRS. Not sure how this relates to the horrible suffering of those who must bear the burden of hearing people use their callsigns, but whatever. -
The "Digital Transition and Public Safety Act of 2005" mandated that TELEVISION move from Analog to Digital, to free up space for public safety. It did not mandate that public safety move to digital. Either you misunderstood your friend or he is misinformed. Federal grants for new communications systems mandate P25. That doesn't mean a new DMR, NXDN or analog system can't be set up, it just means that system won't qualify for those grants. There is nothing "illegal" about analog or non-P25 digital public safetey radio systems.
Yes, except the FCC regs require use of call signs, not "numerical IDs". Apparently the owners of those repeaters don't care, unless you are saying these IDs are used along with the call signs, not instead of. For whatever reason, the "cool thing" around here seems to be using just the numeric part of the call sign. "123 this is 456". Not sure I would find memorizing a three-digit number any easier than memorizing an alphanumeric call sign.
There is no need to ID after each transmission on either GMRS or amateur radio. Periodically (15 minutes on GMRS, 10 on amateur radio) and at the end of a conversation. The point of IDing at the beginning of a conversation is just that ... identification. "Joe this is Bill do you hear me" is not as specific as "This is <callsign1>. Callsign2 do you hear me? Sure, if it's a private repeater and only you and other members of your family are using it then just names works fine. But in the general case, not so much.
Having a plan to "just call anyone" isn't really a plan. As has been mentioned, that's the flaw in "I got my GMRS (or technician) license and bought a radio that I store in a box in case of emergencies but have never actually used it". Rumor has it that there is a TLA agency that monitors "the full spectrum of radio communications" but they are looking for particular types of radio traffic and are not going to send help, no matter what the disaster. There is no way for local authorities to listen everywhere all the time. Chances are they don't have the resources to even listen to a few frequencies. Back in the day, CB 9 *was* monitored in a lot of places, but those days are long gone.
You sometimes need a tone code - CTCSS - to speak to repeaters.
wrci350 replied to Sonicgott's topic in General Discussion
8-14 are for HT (hand-held) use only. 467 MHz interstitial channels. Only hand-held portable units may transmit on these 7 channels. The channel center frequencies are: 467.5625, 467.5875, 467.6125, 467.6375, 467.6625, 467.6875, and 467.7125 MHz. -
I had a pair of GXT1000 radios back before the 2017 rule changes. They *were* GMRS/FRS 'combo' radios, and in the owner's manual it told you that you were only allowed to use it on channels 8-14 unless you had a GMRS license. As can be expected, 99.9% of owners either never read the manual or ignored that rule, and used them as high-power FRS radios. As part of the 2017 changes, all of those combo radios were reclassified as either FRS or GMRS, based on the power output. A lot of them are now FRS, but the GXT1000 is considered a GMRS radio BUT it is not repeater-capable, just as it wasn't back in 2015. -
Question regrading the Radioddity GM-30 Plus
wrci350 replied to WSGT281's question in Technical Discussion
Yes. The GM-30 Plus has 10 banks of 100 channels, and you can use any channel for either a GMRS frequency (that you can transmit on) or a VHF or UHF channel you want to monitor only. The one restriction to note is that the radio can only use one bank at a time. As long as you have 100 or fewer repeaters you want to program (which I'm going to guess is the case) you can put them all in one bank; if you have 101 or more you will have to change banks at some point ... but still easier than reprogramming! -
wrci350 replied to Lscott's topic in Multi-Use Radio Service (MURS)
Exactly ... but you shouldn't have to do that. -
The Wouxon KG-805M has 128 slots and looks like you can program the same MURS frequency as many times as you want. I would have included that in my ealier reply but I had to charge mine first ... some of the Wouxun radios (including the KG-805M) are notorious for having a parasitic battery drain when stored. I think the Baofeng Tech MURS-V2 will let you do what you want as well, but I don't seem to have the programming software installed, the download from the BTech site is broken and won't install, and I don't feel like installing CHIRP so I cannot test on the one I have. -
The Radioddity MU-5 has 20 slots so you can definitely have with and without tones. One thing to note is that slots 6-20 are just the five MURS frequencies repeated three times so you can't (for example) have 151.820 with 8 different tones, but you could have each frequency with no tone and then three more times (each) with a CTCSS or DCS tone. -
The difference between 136.5 and 141.3 is what? About 5%? Probably within the tolerance of that Retevis repeater's tone detect circuit. I would try setting the repeater to a PL of something like 203.5 and see if that fixes the issue.
OMG you don't even know me ... yet you KNOW me!
Should I remove channels 8-14 from my radio? (Kenwood TK-372G)
wrci350 replied to ElectricXpert's question in Technical Discussion
467 MHz interstitial channels. Only hand-held portable units may transmit on these 7 channels. The channel center frequencies are: 467.5625, 467.5875, 467.6125, 467.6375, 467.6625, 467.6875, and 467.7125 MHz. If you want to follow the rules, lock them out. -
You might want to do a bit of Internet research before you buy one of the "new" ones from China (if that is your plan). They are probably counterfeit.
The post mentioning DMR and the Anytone AT-D578 reminded my of another radio that fits in the "lower power on 220" category: Alinco DR-MD520, which is the tr-band version of the DR-MD500 DMR radio. (If you ever see them side-by-side you'll quickly discover that they are cousins to the D578.) The MD520 will do 55 watts on 2 meters, 40 on 70cm, but only 5 watts on 220.
I actually have all three and the Alinco is the one that's in my shack ... the others are in their boxes. I really like it. It only has three reviews on e-ham (two 4 and one 5) so I think that's pretty good. As far as HTs go, Kenwood has a history of putting out tri-banders that do full power on 220 (TH-F6A, TH-D74A, TH-D75A) so I"m hopeful that the mobile will do that too. Pretty sure the TYT TH-350 does 5w on all three bands too. I had one and it's a decent radio, IMHO a notch above some of the other CCRs. The Yaesu VX-6R *does* fit into the "lower power on 220" category though, and that's kept me from buying one. So far.
Chances are pretty good that all those people you hear are using FRS radios, and traffic of that nature is explicitly permitted by Part 95B. FRS is licensed-by-rule, so no call signs. As of 2017, there are no "FRS" channels, since GMRS and FRS share the same frequencies with different max power and (in some cases) bandwidth. The only exception is that FRS radios cannot transmit on the repeater inputs since repeaters are not allowed on FRS. If the schools, construction workers, bus company and nursing homes are using FRS radios (on any channel 1-22) there is nothing to "enforce".
@WRPV394 Were you able to get that Amazon multi-cable to work with the Alinco DJ-G46T? Here's what I said in my mini-review about the cable: While the radio has a K-type accessory connector, it does NOT use a K-type programming cable. That means the Baofeng cable many folks have lying around will not work. Instead, an Alinco ERW-7 or ERW-15 cable is needed. Expect to spend at least $25 to get the correct cable. I'm also curious to hear if one of those Amazon multi-cables works since that might be a cheaper option. Fortunately for me, I already had the RT Systems equivalent cable (USB 29-A) since it is used for a number of other Alinco radios, both HT and mobile.
My disclaimer is that I am not a GMRS power user by any means, but I do have all three of those radios. Many consider Alinco as the fourth of the big three Japanese amateur radio manufacturers. I have a number of Alinco radios (I'm also a ham) and I really like them. The DJ-G46T appears to be built on the same chassis as some of their commercial radios. Nice little radio and not cheap-feeling at all. I posted a review here: https://forums.mygmrs.com/topic/6817-amateur-radio-maker-getting-into-the-gmrs-market/page/2/#comment-72115 Couple other posts in that thread talk about the RT Systems sofware and cable.
A couple more options: Radioddity GM-30. Black Friday special. https://www.amazon.com/gp/product/B08SLR7W7F/ Radioddity GM-30 Plus. Black Friday special. https://www.amazon.com/gp/product/B0D8752P5L/ Alinco DJ-G46T. Also Black Friday ... put in cart for discount price. https://www.mtcradio.com/alinco-dj-g46t-portable-5w-gmrs-ht/ RT Systems has software for all three which I highly recommend but there is vendor software for all three as well. Either way you'll need a programming cable if you don't already have one.
Again, they have just as much right to those frequencies as you do. Don't like it? Find a different channel.
Wow. Those kids and parents have just as much right to use those channels as you.
Using 462.xxxx MHz Frequencies Outside of GMRS Channels
wrci350 replied to WSEI687's question in Technical Discussion
As others have said, one of the reasons that only type-accepted radios are supposed to be used on GMRS is that those radios can only transmit on the GMRS frequencies. Obviously the radio you are using is not FCC Part 95E accepted. It's up to you whether or not that is important. But the "private frequency" you picked is a Part 90 business frequency. You are not allowed to transmit on that frequency. -
But back to the GM-30 Plus. Available on Amazon (for Prime members) today for $29.59 or in a two-pack for $55.99. As an aside, the GM-30 is $19.99 and extra GM-30 batteries are $12.79. Oh, and RT Systems has a programmer for the GM-30 too!
