WRHS218
    6
Everything posted by WRHS218
  1. I had a Kenwood 2m radio installed in my truck for years with no problems and then one day it started doing exactly what you described. After a ton of trouble shooting I removed the radio and hooked it up to another source of power outside of the vehicle and it worked fine. I finally removed the installed wiring which was routed along a pillar and above the head liner and found the black wire had a compressed spot on it and had rubbed through the insulation over time. The wire was running through a tight spot. I replaced the wire and rerouted it and no more problem. I had done the initial installation so it was all on me... So, if you can remove the radio and use a different power source it might be helpful to either narrow down the source of the problem or at least eliminate the wiring as the culprit.
  2. RAM Stubby cupholder mount I got on fleabag. RAM Universal Cradle for Devices with Belt Clips I got from mypilotstore dot com. Sorry it took so long to get the pictures. Wish I had a cool excuse. I just forgot.
  3. My set-up is a mish mash of RAM mount parts. I will get a picture of what I have later today.
  4. Under the Main Memory Group tab the 462.xxxx frequency would go in the RX Freq column and the 467.xxxx frequency would go in the TX Freq column. The RX CTCSS/DCS and TX CTCSS/DCS have their own column with pull down menus to set the required tones. While testing your radios you might want to leave the RX CTCSS/DCS tone off on both radios until you are sure they are working. And as that other guy said try separating the radios. Are you sure you are hitting the repeater? If you are not you might want to get closer to it.
  5. I have had a KG-935G for over a year and use the Wouxun software to program it. I have repeaters programmed in and also have a RT-97 with it's own set of repeater channels programmed into the radio. What is the problem you are having?
  6. I have the 935G and use it with a cup holder mount and external antenna in my wife's Honda. It works well. That looks like a good set up you have there.
  7. I found what I needed in the following thread on this site: https://shop.mygmrs.com/pages/retevis-rt97-and-rt97s-usb-driver-installation I followed the instructions for the USB driver installation and it worked. Before I was getting the error you have.
  8. I occasionally have the scan stop on either GMRS02 or GMRS06 when I am in the car, but it is normally accompanied by digital signal audio from some close by device. Does this happen on the same channels every time or most of the time? You might check your squelch settings. If you can get to the radio while it is stopped you might try pressing the monitor button to see if you can hear anything. Are you using Priority Scan? I am sure someone who knows more than I do will have some suggestions.
  9. That would happen here if cities had the money, but they don't.
  10. I don't have much GMRS traffic where I am either. I have programmed local LEO and Fire frequencies and listen to them when things are happening like the last month with wildfires. Not complaining, love the radio.
  11. I now realize that I know nothing. It could be that the 935G and the radios based on the UV9P are both Wouxun but are speced out by two different companies. But that wouldn't explain the difference between SMUTESET and SIM-RX. Do the 935Gs that came out after March of this year have both SMUTESET and SIM-RX? Not that I really care, just curious.
  12. As far as I can tell the KG-UV9GX (GMRS) is based on the UV9P (HAM) as is the UV9PX (HAM). Both of those radios refer back to the UV9P manual for some things. I cannot find a SIM-RX in any of the three manuals. There is a S-Mute option that will mute the alternate receiver during RX or TX or both on the main receiver. That sounds like it does almost the same thing. I don't know what the actually wording is for SIM-RX because it isn't in the manual.
  13. Mystery solved. I recieved this from good folks at Buy Two Way Radios this morning: "Yes, It’s a new setting that Wouxun added back in March, after the manual was printed. It allows you to turn off simultaneous RX on both areas. Unfortunately there isn’t an option at this time to do a firmware update. Wouxun has not told us if or when a firmware update could be available."
  14. Yep! I spent some time in the Wouxun programming software and as 6045 said there is no mention of that option and no way to access firmware version. I'm assuming it is a firmware option that was added after I got my 935G in August of 2021. I have used the radio for a year without it so it isn't a big deal but I did send an email to the seller to see what they say. My inquiring mind wants to know.
  15. Well fiddlesticks, my radio is: 52 TIMER 53 AUTOLOCK 54 PONMSG I don't have SIM-RX anywhere. I will have to dig around in software and see what I can see.
  16. I was using the 935G as a scanner the other day listening to two different county sheriff departments during a large wild fire. It got confusing and I was thinking it sure would be nice if there was a way to scan both but not hear both at once. Sad thing is the user manual is pretty easy to read... if only I had read that far. Thanks for the heads up on #53.
  17. To be fair, I don't experience the Sad ham behavior that often and I know there are worse things going on especially on busy repeaters in big cities. It just happens enough to discourage some folks that are new to radio. The internet experts are not limited to radio. Any forum or video comment section has them and that is fine. I have even seen "some people" behavior on a couple of cancer forums I am a member of. Air wave anonymity was a thing long before there was an "on-line". Everyone needs a hobby I guess. I don't always play well with others and I can be a lukewarm pile of sarcasm at times. I just try not to be a jack wagon to people that have genuine questions, people that make mistakes in etiquette, or kids playing on FRS radios. We are all Flawed Dogs.
  18. I didn't want to derail the GMRS Enforcement thread, but after reading it I did a little research on the FCC website. I searched my zip code and found 83 active ham licenses and 13 active GMRS licenses. 7 people on those lists have both active ham and GMRS licenses. I don't know the Sad/Happy ratio on either list, and don't care. I'm not sure I ever cared but am sure I haven't cared in the last 20 years or so. I am amused by the Sadness that has always infected ham radio and is now spreading on GMRS but I don't get involved in the Sadness pandemic. The FCC licensed Sadducees and Pharisees live on via the internet and occasionally the air waves. No Virginia, apparently, we can't all just get along. William Romeo Hotel Sam 218
  19. Does anybody really know watt time it is...
  20. Are you close enough to the repeater to reach it? Can you hear traffic on the repeater at all? I don't know your radio but if the repeater requires tones make sure you have the correct TX tone selected on your radio. You might want to leave the RX tone off until you are sure you can open up the repeater. If the tones are correct do you hear a squelch tail when you transmit? If you are not opening the repeater and everything else is correct you might try moving closer to the repeater and see if you can open it. Try all this on both radios. Will the radios talk to each other on simplex? You could try the Talk Around feature if your radio has it to see if the radios will communicate to each other. try getting some distance between the radios if you can. I imagine someone else will correct me or add anything I didn't know or think of. Let us know what happens.
  21. Welcome, Ron.
  22. I can hit a repeater on the west side of Fresno County, California from the Sierra foothills on the east side of the valley 70 miles away, inside of a car with a 5W GMRS HT with standard antenna. While you cannot see that many fars on most days, there is an unobstructed line of site between my handheld and the repeater which is on top of a 5000 ft. peak. It is easily doable if the conditions are right and the equipment is working correctly.
  23. That switch is rated at less than .2 dB insertion loss. We never figured the total loss. The situation we had was we were using a commercial uhf antenna and cable from a older commercial base station install at our plant. We went to a completely different setup but the antenna and cable were left in place. We bought the switch and used it to switch between two personal uhf (non-gmrs) handhelds. Later we replaced one of the HT's with a scanner and still used the switch. We could find no information on the old cable and antenna though it all worked pretty well. The switch was mounted in the control room.
  24. Apparently, reading comprehension is not my strong suite. I read the OP's post but didn't recall it long enough to not waste everyone's time. Sorry about that.
  25. I used one of these, MFJ-1702 2 Position Antenna Switch, for that purpose a long time ago. GigaParts has them for around $40. I am sure there are other brands and venders out there.
