EARL5555
1 Follower
EARL5555's Achievements
  1. Thank you, WyoJoe.
  2. Thank you, WyoJoe. I tried to make the changes through the key pad, not the software. And yes, I was trying to input a repeater. My firmware is version 6.03.003. If there is now version 6.03.006, then I need to upgrade the firmware. Thanks again!
  3. Hi folks, I have two Radioddity 5 watt GMRS HTs. They were acting fine, until I tried to add a DIY channel to the memory (right after the 8 repeater channels. Now the CTCSS/DCS codes "disappeared", so I had to re-enter them to hit the repeaters. I also notice that the display no longer shows 467.XXX while transmitting to the repeater, it just shows the receive frequency 462.XXX instead. Should I just delete these channel memories, or should I do a factory reset? Any advice and suggestions are greatly appreciated. Thank you.
  4. Unfortunately, I don't know much about antenna grounding. But I do know that copper J-poles and roll-up J-poles do not need a ground.
  5. Sounds very cool. Good luck getting everything cabled together. 25 watts pushed through a roof antenna should give you very good range.
  6. You could also try this copper J-pole antenna tuned to GMRS frequencies. https://www.jpole-antenna.com/shop/462-mhz-land-mobile-gmrs-j-pole-antenna/ You could clamp the J-pole to a piece of PVC pipe. Personally, I think this setup would be useful for a temporary mount that could be set up and taken down quickly and easily. I have columns on my front walkway, and I could bungee-cord this antenna clamped to a length of PVC pipe to the columns. You could raise the J-pole antenna up ten feet in the air, by using lengths of PVC pipe, joined together with PVC couplers. I have been trying to reach Michael, the site owner, for a week now, and he has not written back,. Hopefully nothing happened to him.
  7. Thank you, Michael. Don't buy a Green Dot debit card from Walmart whatever you do.....there have been lots of fakes sold!
  8. Thanks. I take it that you are not impressed by MURS. Being that the FCC doesn't impose a license fee or a test on MURS, that alone is telling.
  9. Thank you. Good observations about that chart. Range could probably be improved with a longer (and more expensive) mag-mount antenna. As the old saying goes, "height is might".
  10. Thanks. I am in the suburbs outside of Sacramento. It's suburban terrain, with mostly flat ground, but some rolling hills, maybe 100-200 feet high. P.S.: I ran across this chart, which gives estimated ranges for different radio services and power levels. Single-sideband CB (12 watts) seems to be the winner here. http://hflink.com/hfpack/radiorange/#VehicleToVehicle
  11. Thanks for the answer. My application would be to try to reach my housemate, with each of us having these mobile radios and using magnet-mount antennas, for those times when cellular phone service is out. (Although I hear that you might get through by text message when voice is out of service). The distance between us could be 10-15 miles, so I realize it can be hit or miss. Thanks again.
  12. Thanks for the thorough answer. My application would be mobile, not base, so I would be pushing 20-25 watts through a magnet mount antenna. I haven't gotten the radios yet. Have you gotten good results going mobile with these radios?
  13. Thank you.
  14. Thanks. For your mobile radio, what kind of range are you getting going simplex? I know that there are a lot of variables at play, but I am curious about real world performance. Thanks.
  15. Thanks for letting mw know. Glad that you have solved the issue you were having.
