reevesr19
About reevesr19
  • Birthday 10/28/1953
    Ronald Reeves
    Arizona
  • Interests
    Camping, fishing and overlanding.
reevesr19's Achievements
  1. I have watched a number of POTA & SOTA videos and they are running the radio audio out to the recorder and then putting a head set on the earphone output of the recorder to monitor it. It may work out to a speaker also. I will see what I can get working and what I used when I am happy with it. WRNX920 POTA- Parks on the Air SOTA-Summits on the Air
  2. Yes that sounds like a good starting point with a splitter. I have had to make adapters as not all pin outputs are the same. So I will see where this goes. I will update this if I come up with something I like. Thanks WRNX920
  3. I am wanting to connect a digital voice recorder to record call signs, names and local data on contacts made while on the GMRS & HAM bands. I have seen pigtail setups that are used in aviation to record pilot and tower transmissions. Has anybody setup something like this that might share some ideas. I have some hearing loss from to much 2nd amendment fun & work in the early years and sometimes need to have operators go phonetic and slow so I can write things down for my log entry's. Any ideas would be great. Ron WRNX920 KW7RNX
  4. Just passed the Ham Technician test 2/1/2022
    KK7DJD
    1. reevesr19
      reevesr19
      Applied and was granted a vanity call sign.
      KW7RNX
      Has some of my GMRS Call sign in it.
      WRNX920
  5. Thanks for all your suggestions, I will look at the ones you identified on the used market when I start looking. WRNX920
  6. I put a Radioddity DB25-G into service a few weeks ago. It has on the menu a gain control adjustment of 0 to 127. It comes as 0 as a factory setting. After some comments on the quality of my transmissions ( clipping of some letters like s & t ) I adjusted my distance from and angle to the microphone. I still got some sub par reports so I raised the gain to 38 about 30% of the range and have had no reports if clipping. My question is what does gain control on the microphone affect ?
  7. Starting with 2 HT UV-5X's with good aftermarket antennas. Yes the antennas were a performance upgrade. Programmed about 6 repeaters in and am pleased with these HT's to hit and receive repeaters in my area. Added a Radioddity DB25-G 25 Watt mobile in the car and with my little digital SWR / RF Power meter was able to get down to a 1.14 to 1 reading putting out 20 measured watts. Monitoring 4 channels at a time this radio picks up a lot of radio traffic. I will be looking for a better HT in the next few months and hope to keep it's cost in the $ 100 to $ 180 range. It needs to have a removeable antenna so I can put what I want on it for performance, needs to come close or match the 5 watt output ( my uv-5x's are hitting 4.9 ) and not be a all on one chip design. So give me your suggestions on what to consider. This will be my SHF grab and go if the time comes. WRNX920 Listening
  8. I am new to this so my question is can I use a 50 watt dummy load on a 25 watt mobile radio or do I have to more closely match my wattage? I under stand lower dummy on higher radio wattage will produce smoke and bad things will happen, but I don't know if there is a down side with low radio on higher dummy. Any assistance is appreciated.
  9. Programmed and hit two repeaters today. Yes I know that's like a toddler figuring out how to tie thier shoes, but I am on a low point of a ever climbing knowledge curve. Thanks for all the replies and feedback.
  10. Life is short, don't pass up things you want to do. Be polite, respectful and humble that for most things in life they are there to chose from. Enjoy your choices.
