486
Using 462.xxxx MHz Frequencies Outside of GMRS Channels
SteveShannon replied to WSEI687's question in Technical Discussion
And if you mess with the meteorological satellites how would the guvmint control the weather and send hurricanes at their foes?? (Joking!) -
GMRS Antenna grounding (not ground plane)
SteveShannon replied to WSEX658's question in Technical Discussion
Not necessary. There’s no DC in your coax. In fact most people use a magnetic mount and the only “connection” to the metal roof is via capacitive coupling to allow the roof to be the ground plane. If you have a non-ground plane antenna you don’t need to worry about ground. -
Welcome! Grounding an antenna is not the same as providing a ground plane. In order to provide a ground plane you need a metal plate, such as a metal roof or hood. In your case I would suggest buying an antenna that doesn’t require a ground plane. I doubt that you need any kind of a ground strap. -
Welcome! Enjoy the perusal!
Baofeng UV 5RM: Challenges with successful TXng with tone settings.
SteveShannon replied to WSET483's question in Technical Discussion
Start by clearing out all of the receiver tones on the repeaters you don’t hear. That way you’ll hear anything transmitted on those frequencies. If you still don’t hear the repeaters, you’re out of range or one the wrong frequency or the repeater are down. Then work on your transmitter configuration only. Get closer if you have to and ask others to listen for your transmission. Carrying two radios and hoping to hear yourself on one while transmitting on the other often fails because your strong transmitter deafens the receiver of the other handheld. That’s called desense. That may easily be why you hear the courtesy tones and squelch tails after you release the PTT. Others may be hearing your transmission. Ask them to respond. -
If after doing this you are disappointed, there are also mounts for ground plane antennas that mount them to the fender. Although it’s not perfect, it does provide a ground plane and a lot of people get by with fender mounts just fine.
Dale, As others have commented you are transmitting on a frequency that isn’t a GMRS channel with a non-GMRS certified transmitter. Your license only grants you permission to transmit on the official GMRS channels and only when using GMRS certified transmitter. So, technically you’re violating the regulations and by publishing your question in a public forum you have increased your risk of being fined. The good news is that the FCC typically doesn’t do anything unless someone files a complaint and even then they send you a stern letter first demanding that you cease and desist and confirm in writing to them how you intend to avoid doing such a terrible thing ever again. Just delete that channel and use the established channels at the permitted power levels and go in peace. -
No. I think you just make stuff up. It’s more likely to affect your eyes and your testes. RF is non-ionizing radiation, and although excessive RF exposure can have harmful effects the calculation is more complicated than just some arbitrary power level. It involves frequency, distance, cumulative time of exposure, antenna gain, and power output. ARRL makes a free calculator. https://www.arrl.org/rf-exposure-calculator
Nobody can answer that but you. There are always trade offs, such as definitely shortened battery life, probable shortened electronics’ life, slight possibility of battery rupturing and catching fire in a spectacular way, possibility of generating interference, and/or spurious emissions. Do you have test equipment to see what happens to the signal? Why didn’t the manufacturer do it?
The “sub-channels” are achieved by using CTCSS tones or DCS codes. Those are fairly standardized so you should be able to use them with any other FRS or GMRS radio. Just bear in mind that anyone listening without tones or codes set will be able to hear your conversations. It’s not secure. Nor will the 2 watts instead of 5 watts make a huge difference. The thing you can’t do is communicate through a repeater.
Yes, individuals just like you and I own the repeaters. They choose whether to allow others to use their repeaters. Most allow others to use them. The licensing is specifically for individuals, with the exception of a few grandfathered licenses. Channels are established by regulations: https://www.ecfr.gov/current/title-47/chapter-I/subchapter-D/part-95/subpart-E There is no organized coordination of channels. You are responsible for not interfering with others, just as others are responsible to not interfere with you. Nor does anyone own any of the frequencies. You’re free to use any established channel that’s not in use. The eight repeater frequency pairs are established by federal regulations and are the same everywhere in the United States. The frequency your radio receives from a repeater is also used as a simplex frequency, but the frequencies you transmit to the repeater are for the most part limited to repeaters. Note that a couple of frequencies may not be used above Line A, but that will only affect you if you are using your radio in the northern tier states. There’s a similar prohibition for folks who live near the eastern border of Alaska.
We had a person on the forum a few months ago who connected backwards to the duplexer and had a similar result. On the repeater the high frequency connection goes to the receiver side and the low frequency connection goes to the repeater transmitter. Your friend probably didn’t do that, but it wouldn’t be the first time. Second, I second Boxcar in suggesting that you strip away all of the tones at first. Once you know the repeater is working you can always reprogram them, ideally one at a time. If there are no tones and you are certain you’re transmitting to the repeater on the same frequency the repeater is receiving (one thing at a time) then make sure the repeater transmitter works. When you’re done you should be able to verify each of the following steps: handheld radio transmitting correctly repeater receives correctly repeater transmitter works handheld radio receives from repeater Then add an input tone to the repeater and the same output tone to your handheld and test again. Then add an output tone to the repeater and the same input tone to your handheld and test again.
Radioddity DB 40G DCS tone?
SteveShannon replied to Soggybottomboy's question in Technical Discussion
Radioddity says that they have an expanded manual (250 pages) for this radio and two others and they provide a link to the download page, but I can’t find it. -
The fact that nothing has been posted in the last two years isn’t encouraging.
Of course. They’re on the same frequency. DMR sounds terrible on an analog radio.
Not if done correctly. The entire purpose for the duplexer is to ensure that the transmitter’s signal has no effect on the receiver.
You have to choose the SUBSONIC or TRANSMIT SUBSONIC menu and then choose CDC rather than CTC from the menu: -
I have two. I would be willing to loan them one, but eventually I would like it back. I’d be willing to pay shipping both ways.
You’re not alone in your opinion and it has been discussed frequently here. There are a few experimental digital GMRS repeaters as I recall. @Lscott is the main advocate on these forums.
Recording both receive and transmit audio
SteveShannon replied to WRQJ559's question in Technical Discussion
For some radios, in order to have the headphone jack reproduce the transmitted audio, there’s a built in “monitor” or “side tone” setting that must be turned on (not to be confused with the “moni” function that simply opens up squelch.) Does the BTech radio allow CAT control? If so, HRD (Ham Radio Deluxe) has a recorder app built in that records both the outgoing and incoming audio. It works well with my Yaesu radio. The Yaesu FT5DR handheld will record both sides to a microSDR card in the radio. So will their FT3DR and probably their mobile radios such as the FTM500. I wouldn’t be surprised if some of their less expensive models do also. -
Getting back to the DB20G, has anyone approached the Chirp developer about adding the Radioddity DB20G? It would sure be nice to have something other than the factory CPS for this radio.
If you haven’t seen it, HamStudy.org is a great way to interactively study in a way that helps you understand the questions and answers. It’s free to use their website and inexpensive to buy their app for your phone so you can study almost anywhere.
