SteveShannon
    486
  1. I'll keep looking. Do you live in an area where the battery temperature might drop to +40°F?
  2. I don't have a better idea, but the IC-V85 looks too short and squat to me.
  3. For a range of 14.4 vdc in and 12.0 +/-0.5 vdc out? How much peak current do you guess? Also, what type of battery? For lead acid something like this might be everything you need: https://www.dxengineering.com/parts/wmt-58403-1046?seid=dxese1&gclid=Cj0KCQjw9Km3BhDjARIsAGUb4nyW7YSRHOOjCy1OcM9SCYZ074KAnDL2RJZPhS-6XOWi7AQkuLw4WnoaApUTEALw_wcB But if you already have a charger, there’s no point in paying for that circuitry again.
  4. First Hezbollah, a terrorist organization, fears their cell phones are compromised. So, they change over to pagers. 3000 people are wounded and 10-12 killed when they simultaneously explode. Then they change over to “walkie talkies” that they bought because of earlier concerns about secure communications and attend the funerals for people who were killed. Their walkie talkies explode with even more force. I wonder what their next line of backup communications is. They’ve got to be nervous by now.
  5. Here’s the web page for the marine radios from the European distributor for the Middle East: https://www.icomeurope.com/en/radio/handhelds-for-marine/
  6. Yeah, for two days I’ve been chortling. I’m pretty sure I’m going to hell.
  7. Your voltage is close enough you just need a voltage regulator, not a dc-dc converter.
  8. More explosions have occurred. This time it appears to have involved handheld radios. An Icom is displayed during the video:
  9. In this video some guy says that the 5,000 pagers had their batteries replaced with battery assemblies containing explosives as well. It may have been done while they were being held in customs at a nearby country.
  10. That might already be covered by traffic regulations.
  11. I’m thinking I’ll be better with something like a Yaesu ftm300. But I already have these two DB20G radios that are great go box radios. I just need to pay closer attention before I start building a configuration file.
  12. I have two of the db20g radios. I like almost everything about it: small, easy to use, powerful enough. What I don’t like is the fact that you cannot use Chirp or RT Systems, and the software provided by Radioddity doesn’t allow imports, and copying and pasting doesn’t work the way I want. Also, this is probably the most frustrating: once you have a configuration file created, you cannot change the frequency range in the CPS to another, even if all of the channels you’ve programmed are well within both of the ranges. There’s a range of channels that goes up to 470 MHz. There’s another range that’s higher in the list of available ranges that goes to 490 MHz. A program file written for one range cannot be used for the other and changing the range in the settings wipes out all the channels you’ve created.
  13. Here’s the frequency table in Wikipedia. https://en.wikipedia.org/wiki/General_Mobile_Radio_Service#Frequency_table Note that channels 15-22 are used for simplex communications (meaning that transmission and reception is done on the same frequency, taking turns to talk). Channels 15-22 are also used for duplex communications by the repeater. The repeater receives a transmission on one of the frequencies marked 15R through 22R and simultaneously retransmits it on a frequency that is 5 MHz lower, marked 15-22 (no ‘R’).
  14. Here’s the actual rule the specifically permits traffic reports: 95.1731(b) One-way communications. The operator of a GMRS station may use that station to transmit one-way communications: (1) To call for help or transmit other emergency communications; (2) To provide warnings of hazardous road conditions to travelers; or, (3) To make brief test transmissions.
  15. Good job figuring it out. What brand of LMR400 and connectors were they?
  16. Something appears to be lost in quotation...
  17. What's your area? Perhaps you can show us a screenshot of your search terms. I suspect you have a term that excludes all of the repeaters in your area.
  18. I bow in your direction... That's one of the funniest videos I have seen lately. Timely too. In rocketry we have a lot of little gadgets. One of our members had built a nice little business making kits (like Heathkit, but rocketry related). A couple of his kits are wifi switches, tiny little circuit boards that connect to a battery and to the rocketry electronics. The switch is very reliable and allows a person to arm the ejection charges while standing a safe distance away. $15 for the miniature version: https://eggtimerrocketry.com/home/altimeters-av-bay/
  19. It’s possible to make a microphone from one work with another, but because of different features, like push buttons on the mic, some things might not work as expected.
  20. No, there is not. Each mic is wired to its own radio.
  21. GMRS radios come preprogrammed with the right frequencies.
  22. https://youtu.be/t9wmWZbr_wQ?si=UbyYQZA6vKW4cMyw
  23. Why can’t you listen to the output frequency? No tone or permission is needed to listen.
  24. In a GMRS radio, just choose one of the pre-programmed repeater channels, 23-30 (there are 8 of them) and set the necessary tone to get into the repeater.
