dosw
Everything posted by dosw
  1. Mygmrs lists 131 in Florida. Good repeaters are expensive to put up and maintain. They benefit greatly from height. Most of Florida is height challenged. But 131 is a decent number. California has twice the land area, and 160 repeaters listed on mygmrs, which is far fewer per square mile, and per capita.
  2. Actually the lowest GMRS channel is 15: 462.5500. Channel spacing sequentially is 25kHz, but because of the interstitials (channels 1-7, and 8-14), the spacing within the band is actually 12.5kHz. Maximum deviation on the 462.* channels is 5kHz, if I recall. So I would, for example, listen on 462.5500 (channel 15). The channel width is 25kHz (+12.5kHz to -12.5kHz from 462.5500), so the actual GMRS band (including the full channel width) goes from 462.5375 to 462.7375, once you account for the bandwidth. And the same goes for the 467 portion of the band. 462.5625 is not a private channel. It's a channel that would overlap OUT of GMRS band by 12.5kHz. So you're actually asserting a privilege you don't have all the way down to 462.5250, which is clearly out of the GMRS band. GMRS is channelized. You are only permitted (with your license) to transmit on the 22 channels, plus the 8 repeater channels with a type approved radio, and the reason type approved radios are required is so that people can't do stupid things like transmitting out of band or in ways that cause interference. Let's say you decided that it would actually be more clever to select a frequency within the GMRS band, rather than one that falls outside of the band: 462.55625 (for example). What's the worst that could happen? Well from a technical standpoint, that means you've selected a frequency that falls exactly between channel 15 (462.5500) and channel 1 (462.5625). And because you have a channel width of 25kHz, and maximum deviation of +/-5kHz, you're overlapping two channels. You haven't created a private channel, you have caused interference to users on channel 1 and on channel 15. There is NO space between the GMRS channels that would allow for you to transmit FM in a way that doesn't interfere with existing licensed users. Now let's go out of the GMRS band. You've gone below the band; you're radiating below 462.5500. What's the worst that can happen? Look at the following chart, available on the FCC website: You see the long vertical bars named "Land Mobile" at 462.xxxx and 467.xxxx. Those are GMRS/FRS. Now do you see the shorter bars listed as both Land Mobile and Fixed? Those are LMR (business), and other licensed users. Your selection of a frequency that bleeds outside of GMRS causes interference to non-GMRS licensed users who pay for the licenses they have to use the frequency you're squatting on. Let's look at that a little more closely: Here, you can see exactly how the frequency is allocated that you're interfering on: Private Land Mobile, and Fixed Land Mobile - 460-462.5375. The lower half of your signal overlaps into the Private Land Mobile spectrum, and the upper half overlaps into the "Personal Radio" (FRS/GMRS) part of the spectrum. You are interfering with someone who has a license to use PLM up to that frequency. You might say, "But I don't hear anyone." And that's probably true, but not hearing someone doesn't mean the frequency isn't allocated, and doesn't mean that your interference couldn't be harmful. What if it's a digital service that only transmits in time of dire need? Your FM transmission could stomp on a digital transmission that only happens once in a blue moon, but when it does happen, is of vital importance to someone. You didn't get an amateur radio license. If you did, you would have had to take some tests that demonstrated you knew how to regurgitate answers that the FCC thinks are sufficient for you to behave mostly responsibly within the amateur bands. But even an amateur license doesn't give you permission to just pick a frequency anywhere you like and start transmitting. It limits you to the amateur bands, and asks you nicely to look at the band plan first for any of those given bands. Anyway, what you're doing has the potential of being harmful to someone who has a legitimate license. It also is harmful to GMRS users of channel 15, which you're overlapping onto. And it's illegal. You should have bought a GMRS radio and stuck to GMRS channels. Here are a couple more screenshots showing what's going on: In this first screenshot I have a software defined radio set to 462.5500, with a channel width of 25kHz so we can see more clearly the width of a channel. You can see that 15 overlaps with 1. Now in this second screenshot I'm going to show the frequency you selected: 462.5375: As you can see in this picture, that 25kHz channel spacing causes your channel to overlap part of channel 15 in the GMRS range. But it also puts you squarely on top of someone transmitting a digital signal exactly on the frequency you selected. Of course this is in my area. Your area will have different licensees and they will be using that frequency in some different way. But how do you think their digital signal (if that's what they're doing) is going to work out if you stomp on it with FM voice? This is why the FCC has rules, and has the power to fine you heavily for interfering with other licensed users. In this case it's not a case of "The FCC doesn't care about GMRS users." It's worse, because you're mostly interfering outside of the GMRS band. What you're doing doesn't fall under the GMRS rules; you're transmitting an FM signal on a band that you have no license for.
  3. How are you determining you can't hit it? Need steps to reproduce the issue, including how your radio is programmed. If he sets his own radio to listen to the repeater's input frequency can he hear you?
  4. I have a similar issue when skiing. But I don't think a car-based repeater would solve it. Several resorts I ski at have distinct "sides", with a mountain ridge between them: Alta Ski Area: The Albion/Sugarloaf side is distinct from the Collins/Wildcat side. There are distinct parking lots, and a bit of a mountain between them. Snowbird Resort: The Mineral Basin side is behind the Cirque, and there's no way a radio would carry from mineral basin to the parking. Solitude: The Summit lift area, and the back (Honeycomb Canyon) are behind mountains, and can't be reached from the parking lot. Deer Valley: There is skiing near the parking area, but there are three other distinct sides with mountains between them: Silver lodge area, Mayflower, and one other i don't remember the name of offhand. Snowbasin: The Strawberry side is beyond radio range from the main parking area. Brighton: The mid-section off of the Snake Creek lift is hidden from the parking. But in those cases, we tend to be pretty good at keeping the group together within that topographical "side." Anyway, the A/B approach is good. There are two ways I see to do it: A is on simplex 18 (for example). B is on repeater 20 (for example). Set the radio to dual-watch. Make sure the operators mention which side they're on when they call (A or B ) just to keep it easy. A is on simplex 18 (for example). B is on repeater 18, same tones. Set radio to dual watch. Make sure operators mention which side they're on when they call. 2 is more seamless, but also a little less clear to listeners whether they're hearing the repeater or simplex.
  5. 50 yards is far enough that it's likely beyond the width of your home/property, unfortunately. With a scanner, or an SDR, you could put both the output frequencies and the input frequencies in the scanner. When you key up you're going to be transmitting on the input frequency. The scanner should jump to the strongest signal; the input frequency. When you release the PTT, the scanner would probably jump over to the output frequency since it will still be outputting the squelch tail. When you're not transmitting but someone else is, the scanner would jump to that. So with, say, a Uniden scanner, if you're trying to listen to the 700 repeater, then you would create a very small scan group of 462.7000 and 467.7000, set squelch appropriately, plug into your VOX recorder, and let the scanner jump to the strongest signal (or at least the first signal it hears, which will be the input frequency until it goes away). With an SDR, you would use SDRTrunk (software) and set up a small scan group of those two frequencies. Again, it will jump to the stronger of the two. SDRTrunk has a recording mode. So I'm saying your base station may not be the receiver you need to be using to accomplish this. I understand it's what you want to do, but this is an XY problem. Here's the Wikipedia explanation of an XY problem: While the Wikipedia explanation is not as tactful as I would prefer (I would not suggest you're ignorant about X or confused about the problem Y that you're solving, I assume you know a lot about all this stuff), it does demonstrate that if you take a step back from the problem and look at what you actually want to accomplish (Y), you may find that X is not the best way to do it. Just being open to other options may make the problem easier to solve. If you don't have a scanner or an SDR, never fear. Even a cheap-o Baofeng will let you put 462.7000 in "A" and 467.7000 in "B", and set up dual watch. Plug it into a recorder, leave it on the other side of your house, and it should do what you want. All three techniques I've mentioned -- a scanner, an SDR with SDRTrunk, and a Baofeng with the repeater pair in A/B slots -- are techniques I've actually used.
  6. Hook up the *handheld* to the recorder. Or get an SDR and run SDR++, which has a recording mode.
  7. Create your petition with the FCC. https://www.fcc.gov/about-fcc/rulemaking-process#:~:text=Electronic Filers%3A Comments may be,the website for submitting comments. There's nothing to debate until the actual process has started. (It's never going to pass, but there's no point stirring up an argument here without any skin in the game. Go ahead and get the process started.)
  8. Before buying a nice, expensive KG-1000 Plus and a nice antenna, get an inexpensive Baofeng UV-5G Plus kit that includes a 771G style (longer) antenna. Get to high ground in your area, and try to hit that repeater. BUT, if I understand correctly, a repeater has advertised a range of 35 miles, and you're 20 miles past that. My guess is you're not going to reliably hit that repeater. However, you can set that radio to scan, and leave it on for a few days (in its charging cradle). If you hear traffic that sounds like repeater traffic, take note of the channel, and then start doing some research, or reach out on simplex in hope that someone will be listening with an open radio (no tones). That way you might find a repeater that isn't listed, and can discuss access. Once you've found actual access, you can spend on the KG-1000 Plus. If there are no repeaters, you may be better served by going for an amateur Tech license, because there ARE 2m/70cm repeaters in your area: https://www.wr9g.net/links/repeaters.html (Looked up your town via callsign lookup)
  9. Height is might doesn't mean a longer antenna, it means get up above the terrain, because the real rule is that if two antennas can see each other, they can communicate. And if they can't, and the reason is due to terrain, lots of buildings, or dense forest, they may not be able to communicate. In this case, a longer antenna might not change much for you other than making your radio more particular about being held very close to vertical.
  10. I've re-read this thread and fail to see what it has to do with the post you added to it. You're dragging an amateur radio fight that got dragged into a reddit fight into a random thread on a GMRS site.
  11. You need "triple modular redundancy" if it *really* matters. That means, a third opinion, basically. The old sailor's saying was "Never go to sea with two chronometers; take one or three." But you're below 2:1; it doesn't matter enough to worry.
  12. i can drive 4 minutes to a location where I'm at 5500 feet, and have clean line of sight to the entirety of the Salt Lake Valley, mostly 4200-5000 feet. The amount of traffic pulled in even by my MXTA26 at that vantage point is overwhelming. Even my home (5050 feet) has clear reception when transmitting to a repeater 45 and 64 miles away. Any further than that, and mountains block everything. But one time I hiked up Mt Olympus (near 10k feet) and was hearing a repeater in Wyoming, and another in Idaho with a Nagoya 771G antenna. I didn't try hitting them though. There are 2m and 70cm repeaters at the top of mountain peaks near Brighton and Snowbird ski resorts. Those things have a bubble that reaches three states: Wyoming, Idaho, Nevada. ...maybe Colorado but the Uinta mountain range gets in the way a bit.
  13. I trust the NanoVNA more. Try hooking it up to your computer so you can get nearly infinitely fine-grained scan points. Or narrow your scan range, or set the center instead of start/end points. Also there's a menu buried deep within for increasing the scan power. I haven't used it, because "auto" seemed good enough. I've found the two tools disagree a bit, too. Be sure you're calibrating for the exact range you're sampling.
  14. Do you know the name of the menu option that needs to be enabled for this to work? I wanted to hook it up through 70dB attenuation to a TinySA, to see what is happening. UPDATE: Found it. Menu option 41: Voicepri (on/off). I don't see it doing anything. I suspect I would need two device both with this set up to actually work. When I key up, I just see the frequency I have selected being used, within the TinySA, and also when I directly connect to my RTL-SDRv4 (both through 70dB attenuation).
  15. A ground plane is more than just having the antenna mounted against a metal surface. It needs to be 1/4 wavelength radius (6.5 inches) or more, in all directions. It doesn't have to be electrically connected or grounded, just needs to be a fairly flat surface for the 6.5" radius (or more). A lip mount works for me because there's a flat metal panel aft of the hood, too. But if you're at the edge of the hood without a flat metal surface on the other side from the mount your propagation will be stunted in the direction of inadequate ground plane. But if you experience this issue at, say, 200 feet, it's less likely to be a ground plane issue. I'd still be looking for sources of electrical interference.
  16. My experience has been different. Using Chirp, with the 5RM profile, I first downloaded a stock code plugs from the radio, then added a few air band frequencies and uploaded them to the radio without any problem. I guess YMMV.
  17. Yes. The repeater has an awesome antenna at an elevation that provides near perfect line of sight to your radio's minimal-value rubber ducky antenna. Your friends within 1/2 miles are not "line of sight" to your antenna; there could be trees attenuating signal, buildings, hills, and other obstacles blocking your antennas. If you can see the other antenna, you can talk. If you cannot, all bets are off. The repeater must have a high gain antenna, may be outputting near 50w into the feed line, with high quality cable, the antenna may be on a tower, and it may be up above obstacles. Probably all of these things are happening. By way of example, a 70cm ham radio (UHF, very similar to GMRS) can transmit to the ISS (250 miles away) with a Yagi antenna pointing in the right direction, and with less than 5w output. On the other hand, two 5w handhelds may not be able to communicate with each other more than a few hundred feet away. The difference is almost always line of sight first, antenna design second, power a distant third.
  18. There are not a lot of dual band options that cover GMRS while also being stubby. The full length monster of a mobile antenna, the Comet CA-2X4SR-NMO covers 2m, 70cm, MURS, and GMRS. It even has reasonable SWR in Marine VHF and 1.25m. But it's 40 inches long. However, it can be folded down when you need to get into a garage, as it has a folding hinge. Some say it's not super in GMRS range. I would say its ears aren't quite as good as my MXTA26, but that's a tradeoff you might need to make to get a multi-band antenna. I have used it to achieve impressive distances, though. I like it. But you'll have to fold it down to get into the garage. There are some very good reviews for it online, and a few mixed. I guess I'm in the thumbs up group. A ground plane for GMRS needs to be metal, with a radius of about 6.4 inches or more. More doesn't hurt anything. Less hampers signal propagation. It doesn't need to be electrically grounded to the antenna, it just needs to be directly beneath the antenna. Ground plane radials are common for fixed (immobile) installations, while using a vehicle body for the ground plane for mobile antennas is common in that application.
  19. Ok, since I got into GMRS I've added to my pre-existing collection that included a scanner, a couple of Marine VHF radios, a shortwave radio, and FRS radios, the following: Radios: UV-5G (2), UV-5G Plus (1), AR-5RM (1), MXT-275 (1), RA-87 (1), GTX1000 (2). Antennas: MXTA25, MXTA13, MXTA26, HYS SDN-1T, Laird TE B4505CN, Comet CA2X4SR (2). Nagoya NA771G, NA771 dual band, NA701G, ABREE dual band, Tram Marine VHF 5.1dB whip. Ground plane kits: Nagoya GP01 (2) Test equipment: Surecom SW102, NanoVNA, TinySA, 50w dummy load, 40dB, 20dB, and 10dB attenuators, and a whole bunch of various adapters and patch cables. SDR: RTL-SDRv4 (4), Raspberry Pi (2) Software: Chirp, SDR++, SDRAngel, TrunkSDR, nanovna-saver. Cables: LMR400, RG8X, RG58A/U, various lengths, plus various short length connectors. UHF/VHF diplexer (to use radios on two different bands on the same antenna). Mounts: NMO through-deck mounts, GP mounts, Midland magnetic mount, Midland hood mount. Multiple MXT275 brackets. Upcoming: Another Comet CA2X4SR and another diplexer to share a dual-band antenna. A mobile 2m/70cm dual band radio. A 2m/70cm Yagi antenna because I want to experiment with listening to / working through the ISS repeater, downloading NOAA imagery (using the SDR), and so on. Prep for General.
  20. https://chirpmyradio.com/issues/11566 "Unable to upload to AR5RM": Closed as "not a bug" because the person reporting the bug resolved the issue by following the instructions of downloading from the radio first, not from some other similar radio. https://chirpmyradio.com/issues/11535 "No programming for UV-5RH": Different radio, but either way, this one was rejected because it's a duplicate of https://chirpmyradio.com/issues/10889, but also not applicable to the AR-5RM. https://chirpmyradio.com/issues/11529 "Add AR-5RM to the model alias map": Closed as done, implemented. https://chirpmyradio.com/issues/11474 "Error downloading from AR-5RM": This issue is still open, presumably because nobody's been able to reproduce it. Is that the same issue you're seeing? Adding your screenshots and radio pictures may help if that's the issue you're having. https://chirpmyradio.com/issues/11333 "Error reading data from radio: not the amount of data we want": This one is still open, and I'm not sure why. It looks like it's actually providing a solution of making sure that the driver for the cable be installed. But again, if this is the same issue you're having, providing more diagnostic information would probably help. But also that one is the UV-5RH, not AR-5RM. Which bug, specifically, addresses the issue you're seeing? This is active development, volunteer software. They only improve what they know about.
  21. I've reviewed the Chirp code for the 5RM and the 17Pro. It's largely the same code (5RM class inherits from 17Pro class). There is no reason that I can see that the 5RM radio of the same version as mine, would not work with the 5RM entry in Chirp, unless you downloaded your code plug from a different radio and then modified it and tried to upload it as a 5RM. I suggest that if you cannot use the 5RM model in Chirp for your 5RM radio, you file a bug report with Chirp, because it's clearly not the intent for that to not work. As a software engineer it drives me crazy that two people with identical hardware and identical software would not get the same result. If you file that bug report, you will help all the people who are experiencing the same problem you are experiencing. Here is a link to the code in question: https://chirpmyradio.com/projects/chirp/repository/github/revisions/master/entry/chirp/drivers/baofeng_uv17Pro.py#L1313 That code encapsulates both the 17Pro and 5RM classes of radios. And here is a link for submitting bug reports: https://chirpmyradio.com/projects/chirp/issues I've seen that the developers for Chirp are highly responsive. Your bug report will get addressed. The address may be "We can't reproduce", but I rarely see bugs closed that way in the Chirp issues stream. Usually they either result in a patch being created, or the developers discovering an issue with how the software is being used. But either way, someone learns, the developers improve their knowledge base too.
  22. I cannot explain why your experience with Chirp would be so different from mine, for the same radio. I have the vendor set to Baofeng, and the radio set to 5RM. I set channel 193 to 121.300, named it AirGround1, and immediately the software selected "AM" as the mode. I set Duplex to "off" which disables transmitting (though the radio won't transmit, regardless). I saved the image. I uploaded it to the radio. I turned on the radio and selected channel 193. It has AirGround1, and it can hear ground control traffic. That's with Chirp next-20240919 on Python 3.12.3. Could you try with that configuration? My radio is firmware version v0.14. Hardware version v01.
  23. Can't speak definitively to programming airband frequencies, as I haven't tried setting up specific ones. But on my version of Chirp, the Vendor setting should be Baofeng, and the Model should be set to 5RM. If you don't have this configuration you might be running an old version of Chirp. You're using Chirp-Next, right? I can say that when I tried programming 118MHz into Chirp for this radio, Chirp automatically selected "AM": I set Duplex to "off", as that's actually the setting that disables transmitting, though I'm fairly certain the Baofeng won't transmit on airband AM frequencies either way. I haven't tried uploading it to the radio. But Chirp does accept the frequency and auto-selects AM.
  24. Yes. My 2021-era USB-C style MXT-275 uses wideband FM for the repeater channels with the stock firmware. Don't believe everything Midland's support communicates. They're often just wrong. There is no way to *set* wideband or narrowband on an MXT275 with stock firmware. But I've tested several ways that I've mentioned in other threads, and have verified that it does switch to wideband on the repeater channels. I've seen support messages posted here and there that are confusing, probably because support, themselves, are confused by the fact that you can't set it explicitly. The FCC signal description is: 16K0F3E - Frequency modulated (FM) analog voice, 4 kHz deviation (NPSPAC); (FM mode) The FCC test report is here: https://fcc.report/FCC-ID/MMAMXT275/5301846 You'll find that 4kHz deviation is wider than "narrowband", which must remain within 2.5kHz deviation. A narrowband transmitter would be classified as 11K or 12K, not 16K. Additionally, the test results in the document I linked to showed its bandwidth envelope at significant levels to be within 16kHz, which is again wider than 11K or 12K you would expect to see of a Narrowband radio. It is true that a full wideband implementation would be a 20K envelope / 5kHz deviation. But it's quite common to find "wideband" radios with a 16K designation like this one. I don't love the MXT275. I'm particularly annoyed that you can only set one repeater per channel. But it's a solid radio, works correctly out of the box with minimal configuration, and very little to screw up.
  25. Tested again in the 467 0.5w channels, also didn't see a difference. Then I switched to the RTL-SDR because the software is easier to take a screenshot of. Also this time I spoke into the mic rather than just keying up. I think that was where my previous measurements fell down. Within the waterfall (the lower section of the screenshot) there are two transmissions. The top transmission (more recent in time) was narrowband, the bottom transmission (more distant in time) was wideband. You can see the bandwidth peaks are wider. The red shading above is a 20kHz span, 10kHz deviation. The actual deviation of the radio is supposed to be around 2.5kHz in narrowband, and up to 5kHz in wideband. I see some difference when measured this way. In this example I fed the radio on low power mode into the 61.5dB attenuation, and then into the RTL-SDRv4 on channel 19, and used SDR++ to observe the waterfall.
