Everything posted by WRTJ223
I really appreciate you helping me. It will be no problem if I have to do a reset - I just love Chirp and have everything backed up. =) I usually am in the mode where can see the name of the channel. So, at your advice I double checked - So, when I look at the frequency before PTT it is 462.55000 when I push the PTT it is 467.55000. So, I'll give it one more go for your advice and then do the factory reset. It's just so strange I just copied and pasted the files in chirp in the the Radioditty UV-5G Plus and it works like a charm. Hmmmm - Thank you again for your patience. I really appreciate you helping me. I miss that repeater
Wow, this is also very helpful, Ill try all these suggestions, thank you for helping me Ok, I just did all these things - here is the report No R is appearing next to W+. When press PTT [after pressing mode three times I see 462.7000]
I have had the exact same problem - a local repeater is working on all my other GMRS radios except the 935G [this problem has been going on for two years]. Are those the settings I need to have to fix the problem. I just did a test and the repeater with 462 worked great on my other radios except the 935G. I was actually considering a factory reset and that is how I found this thread.
Ok thank you so much!! Below is my mobile set up for UHF/VHF/GMRS https://www.dxengineering.com/parts/CMA-CA-2X4SR and https://www.dxengineering.com/parts/DMN-K702M Last week confirmed with DX Engineering that my Diamond X50 will work on GMRS - right now that bad boy is SWR 1 perfect we tested it on a rig expert and that device I was asking about - I just want to key up on my GMRS radios to be sure - hence the original question [key up on my mobile set up and my Diamond X50]. I'll check out your recs, always like to have a couple antennas - the Diamond X50 has survived tornadoes, ice storms and still working like a charm! My friend's comet works great ! I run HF, UHF, VHF, GMRS, and wanted to give CB a little try. I have a CB dipole to deploy and looking for something low key for mobile. Also taking a crack at CW via Long Island CW club. When we get these flood events, never hurts to have multiple modalities of communication. I find GMRS operators are so much fun and we have lots of repeaters popping up in Texas. I really have to thank Randy for his videos - that is what got me into GMRS. Have a Blessed Sunday WRXP381 Best, LMC
YES, I agree - the only antennas I tune are my HF inverted vee and EFHW. I just want to be safe before I key up and not fry my rigs/hand held. Just a precaution, not an artistic project Speaking of CB - which antenna do you rec for mobile - maybe something rather low profile? Thanks for your help! Ok, so it really does not matter if it is UHF or Type N - this is good to know. All my coax is UHF.
Good Afternoon, Which one is better for GMRS & UHF/VHF This one - my friend used his to test my Diamond X50 and confirmed its reading with a rig expert https://www.amazon.com/gp/product/B01D86IKIQ/ref=ox_sc_act_title_3?smid=A263LSCPZJCHO0&psc=1 [type N connectors] Or this one https://www.amazon.com/gp/product/B01M7QPXEY/ref=ox_sc_saved_title_2?smid=A263LSCPZJCHO0&psc=1 [SO239] Is there a benefit to the type N - clearly the So239 would be easier. OR, do you have another recommendation. This would be for GMRS and UHF/VHF. I am noting these do not come with a ground plane dang it - I wanted to test the dual band Signal Stuff antenna for GMRS. Anyone ever do a try with the Signal Stuff dual band for GMRS? I have a rig expert for HF. Thank you in advanced for your help! Texas is starting to get the GMRS popularity and it is great to see!! Also I cannot seem to find a BNC connector version which is in stock for the Nagoya NA-771G. Any ideas? Best, LMC
Do Governmental Entities Ever Establish GMRS Repeaters?
WRTJ223 replied to WRTJ223's topic in FCC Rules Discussion
Or, more specifically (1) can we do this (2) how would we do this.....Im having an "ah-ha" moment. So, in essence only individuals can obtain GMRS license and not governmental entities. Correct? -
We have a couple of locations that the city controls. The city is willing to work with a group of involved citizens to put up a repeater. So, how would we do this?? Could a club or a group fo citizens who want to be proactive for emergency communications {in our situation flash flood alley in Texas] work with the city under FCC guidelines? Maybe these specifics will help y'all help me get this repeater up. Thank you to all for your help on this question. The grandfathering notion does not apply to our situation. -
So, there is nothing that prohibits a governmental entity from putting up a repeater ... correct? If it is for citizens to have weekly nets to practice for emergencies such as in mine with floods or occasional winter freezes which nock out everything including phone communication. The public would request permission for the tones to access the repeater. -
Configuring GMRS repeater on handheld with CHIRP
WRTJ223 replied to WRQX938's question in Technical Discussion
This thread helped me so much! I had successfully programmed my radio by hand and then for then with the KG-935G Chirp suddenly became compatible. Well then with Chirp I did something wonky. I just hit a repeater near my hometown and am just so excited. However, lesson learned know how to program by hand and also, bonus Chirp! Thank you again for this thread!!! On to programming and testing! -
All of these responses are very helpful. Thank you!!! So, I guess this begs the question, is there a workflow document somewhere for us to install install our own repeater? Im noticing the GMRS repeaters seem to be connected. Ive been focusing on my ham skills and am now switching back to learning GMRS. Goal: We want to be able to communicate across our community if we get another ice storm here in Texas and the phone lines go down again. Thank you again to all who are helping me! -
Yes, that is why we are looking into establishing GMRS in our community! It would provide an added modality of communication for citizens who do not have the time to invest to study and pass the ham test. I really appreciate all the help on my question. Still reading thru all the comments. -
Chirp works like a charm on my Mac and my KG-935G is working so awesome! It is laborious to program by hand the names of the channels. I can copy and paste rows. Etc. Not clunky at all! I hope they have a Chirp release for your 905. I really like my radio. I even programmed in the ham frequencies and it is working like a charm to listen!!! Now all these channels are being put to use!!
Alamo City GMRS Community
WRTJ223 replied to FranktheTank's topic in National and Regional GMRS Nets
Oh my gosh, Im in San Marcos! I would love to talk to you about working Im doing with the city to try to get us up some GMRS repeaters. Is the repeater up yet here in 78666? -
I love Chirp for my ham radios! I dislike the cumbersome hand programming of the KG-935G. Almost broke down to purchase a PC laptop because the Wouxun software does not support Mac! Im one happy camper! It works like a Charm. See, even posted here today!! https://www.buytwowayradios.com/blog/2022/09/the-wouxun-kg-935g-is-now-supported-by-chirp.html
How do we determine number of GMRS licensees in my area?
WRTJ223 replied to WRTJ223's topic in General Discussion
THANK YOU!!!!! -
Thank you so much for all the guidance!! Researching codes is actually my "hobby" so Ill find that out. This is great news about the tin! Thank you for the recommendations ! I REEALLY like that KG100G and now you are really persuading me. Ill take a look at the ham cousin as well, thank you!! Ill check out the Swapmyrigs, this is awesome!! Great suggestion about going to my friend's house with the antenna. Thank you so much wayoverthere And, still very much digesting the sagely advice of KAF6045 Y'all have a rocking day! Thank you for helping me, this means allot!!!! I feel so much better now that have some "marching orders" to make this work. Im so happy signed up for this group. Thank you again!!
Thanks for all the help. No I have never used a microwave. I cannot use blue tooth head phones either, someone gave me a nice pair for Christmas and got a migraine, I never get headaches even. So, I gave it to a friend. Ok, ill have to reflect on all this. Well this is to bad, im really enjoying studying for my ham and also all the youtube videos researching. Thanks you KAF6045 for all this great info. Y'all have a Blessed Week.
I live in a historic area with an old roof (I think its tin) and have lots of huge heritage live oaks. I am new to GMRS and also test for my Ham license soon. What do y'all recommend for an antenna? I am working with our municipality and businesses to develop a repeater infrastructure for our area as we have experienced the freeze (I live in Texas), if we get black outs from the heat (predicted) and live in flash flood alley. Thanks for any help that you can provide. Have a great week! PS I am also VERY sensitive to waves. Even got my city to enact a Smart Meter Opt Out Ordinance (it took me five years to accomplish). I hate my BaoFeng (it emits nasty energy) and have ordered some other hand held Han radios and also working on selecting a GMRS radio. I can even feel the waves from the little two way radios my neighborhood is setting up a comms system. So, any thoughts on this would be appreciated. I would like to set up a GMRS base station so that is why I am waiting on ordering a hand held for now until figure out the antenna situation.
