Mrsig Posted April 30, 2025 Posted April 30, 2025 What is better to use DTCS or CT codes? On a repeater & radio. Quote
0 Lscott Posted April 30, 2025 Posted April 30, 2025 My personal guess would be DTCS since it's a series of digital numbers sent over the air. The attached paper describes in some detail how the system works. With tones it all depends on the quality of the TX and RX radios. A few have commented that radios with low levels of deviation have failed to access some repeaters. Also there are cases where ding-dongs using something like DMR, against the rules on GMRS, have caused false triggering of the CTCSS squelch function to turn off the audio mute. DPL _ DCS Squelch System.pdf WRNU354 1 Quote
0 Mrsig Posted April 30, 2025 Author Posted April 30, 2025 Thanks guys. My Repeater is coming today. Lscott 1 Quote
0 WRUE951 Posted April 30, 2025 Posted April 30, 2025 CTCSS is older and more prone to spurious noise opening the squelch - weather or ambient. Additionally, there are relatively few usable tones. DCS is newer was was designed to address those shortcomings. Both came out of Motorola, who initially was one of the only manufacturers of radios with enough frequency stability to use DCS (though others caught up quickly). Even today, some Baofeng as they age have trouble with a DCS system. Also, many older radios can't use DCS at all, and a few transitional models needed modules to enable it (usually you'd swap our the CTCSS module to a dual mode module). So, yes, DCS is better, but CTCSS more compatible. WRNU354 and RoadApple 2 Quote
0 dosw Posted April 30, 2025 Posted April 30, 2025 This is a topic you could search for hours on and not come up with a clearly definitive answer. In fact, there's almost no argument, even. The advantages and disadvantages of each are so minor people don't really seem to be all that passionate about it. CTCSS will behave with older equipment that doesn't support DCS. But who are we protecting? There aren't a lot of people operating 20 year old blister pack GMRS radios lacking DCS support on repeaters. Both are subaudable tones or sequences that have to be filtered out by the radio's high pass filter. Both have different reasons for behaving a little oddly at fringe-reception areas. DCS *may* take a little longer for the sequence to be transmitted completely enough for a radio to open squelch, but we're talking tenths of a second at most. CTCSS may be a little more crowded (you may have a slightly harder time finding a channel and tone pair that isn't in use). But the fact that we have both systems really is a product of the evolution of marketing bullet points from vendors. One or more vendors claimed they had a new and improved system, and they pushed it to the point that it gained adoption. But the fact that DCS and CTCSS have continued to co-exist for decades, filling the exact same purpose, without a clear winner pushing the other out of the way kind of indicates there's not a clear winner. WRUU653, SteveShannon, TrikeRadio and 1 other 4 Quote
0 WRTC928 Posted May 1, 2025 Posted May 1, 2025 22 hours ago, Socalgmrs said: Doesn’t matter at all. Some people even mix them up. Some radios, even newer ones, won't support cross-mode tones. I was surprised to find that my TYT TH-9800 doesn't. There's only one GMRS repeater in Oklahoma using cross-mode tones, and I've never seen an amateur radio repeater using them, so I guess it doesn't matter much. The one guy using cross tones is probably a goober anyway, and I don't want to use his repeater. Lscott, WRHS218 and SteveShannon 2 1 Quote
0 WRHS218 Posted May 1, 2025 Posted May 1, 2025 19 minutes ago, WRTC928 said: Some radios, even newer ones, won't support cross-mode tones. I was surprised to find that my TYT TH-9800 doesn't. This is one more thing I didn't know. If a person's radio didn't support cross-mode tones they could always just the leave RX tone off. They would receive all traffic on that frequency in range but that probably isn't too big of a deal. I, too, avoid Goober Operated Repeaters. There is one GOR in an area I travel occasionally, that after seeing the clues, decided it would be to my benefit not to use the repeater. SteveShannon and WRUU653 2 Quote
0 WRTC928 Posted May 1, 2025 Posted May 1, 2025 9 minutes ago, WRHS218 said: If a person's radio didn't support cross-mode tones they could always just the leave RX tone off. They would receive all traffic on that frequency in range but that probably isn't too big of a deal. True, but the repeater isn't anywhere near me and it's in a city I'm not likely to go to, so I just deleted it from my radio. Leaving off the Rx tone would be a viable option in Oklahoma, but perhaps not in southern California. We don't get enough GMRS traffic here to create a headache. Quote
0 LeoG Posted May 6, 2025 Posted May 6, 2025 On 5/1/2025 at 10:46 AM, WRHS218 said: This is one more thing I didn't know. If a person's radio didn't support cross-mode tones they could always just the leave RX tone off. They would receive all traffic on that frequency in range but that probably isn't too big of a deal. I, too, avoid Goober Operated Repeaters. There is one GOR in an area I travel occasionally, that after seeing the clues, decided it would be to my benefit not to use the repeater. The main reason I operate tones on the RX is noise. There is a lot of DMR and other digital noise in my area that is beyond annoying. It interferes with medium to strong signals by either degrading the voice or overriding it. Tones don't help when the interference is active while someone is talking. But I would be insane by now if I had to listen to all that crap. WRNU354 and SteveShannon 2 Quote
0 WRKW444 Posted May 10, 2025 Posted May 10, 2025 Here's my experience with the subject. I'm a fan of DCS for all the reasons listed above. However, I have found that some radios take a slightly longer time to open with DCS than CTCSS. Not a problem for us "radio people", but I have a group of radios that I use with a local theater. Sometimes the users push and talk at the same time and the first syllable would be missed using DCS. I reprogrammed the radios for CTCSS and that solved the problem. Again, this might be a brand/model specific issue but something to take into consideration. SteveShannon and WRTC928 2 Quote
0 WRTC928 Posted May 11, 2025 Posted May 11, 2025 18 hours ago, WRKW444 said: Sometimes the users push and talk at the same time and the first syllable would be missed... I don't know why it's so hard to teach people to do that. It drives me nuts. I tell them, "Push the button, THEN talk. Think of it like the second or so it takes your phone to dial a number. You're essentially doing the same thing." They smile and nod, then continue to start blowing from their pie-hole before they push the button. SteveShannon 1 Quote
0 nokones Posted May 11, 2025 Posted May 11, 2025 On 4/30/2025 at 9:18 AM, WRUE951 said: CTCSS is older and more prone to spurious noise opening the squelch - weather or ambient. Additionally, there are relatively few usable tones. DCS is newer was was designed to address those shortcomings. Both came out of Motorola, who initially was one of the only manufacturers of radios with enough frequency stability to use DCS (though others caught up quickly). Even today, some Baofeng as they age have trouble with a DCS system. Also, many older radios can't use DCS at all, and a few transitional models needed modules to enable it (usually you'd swap our the CTCSS module to a dual mode module). So, yes, DCS is better, but CTCSS more compatible. There were several names used by the real radio manufacturers for their CTCSS marketing names. PL for Motorola Private Line; CG for General Electric/ Ericsson/Tyco/Harris Channel Guard; QC for RCA Quiet Channel; CG for EF Johnson Call Guard; and QT for Kenwood Quiet Talk. For the DCS Digital Coded Squelch names used by real radio manufacturers, there are DPL for Motorola Digial Private Line; General Electric/ Ericsson/Tyco/Harris just went with DCS; RCA stayed with QC; EF Johnson also stayed with their old CG name;and Kenwood uses DQT Digital Quiet Talk. I don't believe that the CPRs (Cheap Pandaland Radio) manufacturers used any marketing names for CTCSS/DCS. Quote
0 WRUE951 Posted May 11, 2025 Posted May 11, 2025 37 minutes ago, nokones said: . I don't believe that the CPRs (Cheap Pandaland Radio) manufacturers used any marketing names for CTCSS/DCS. The only thing those CPR's used for marketing was Amazon and the video guy Quote
0 LeoG Posted May 11, 2025 Posted May 11, 2025 The BTech uses DCS and my Tidradio uses CTCSS and DCS Quote
Mrsig
14 answers to this question
