Baofeng
Is a 5rm a GMRS legal radio ?..   what’s the difference between a uv-5rm. And a 5rm.   Seems like 5rm comes unlocked Right out of the box…new to the GMRS world.  Amy help would be appreciated
thank u
10 answers to this question
  • Is a 5rm a GMRS legal radio ? : No - the 5RM is a H.A.M.s radios
  • what’s the difference between a uv-5rm. And a 5rm:  a UV-5RM and 5RM are the same thing. I assume you are asking about the 5RM vs the AR-5RM - the 5RM is locked and the AR-5RM is not locked.
If my assumption was wrong, please elaborate.
EDIT/UPDATE! -- There is NOW a 5RM GMRS version available in addition to the H.A.M.s radios version of the 5RM.. So look carefully at the description before purchasing.
The GMRS version of the 5RM series is the UV-5G Plus.
Type-approval aside, the 5RM variants (with the exception of the UV-5G Plus) cannot be set to power levels below about 2w. That makes them incapable of meeting the technical requirements for operating on GMRS/FRS channels 8-14, since those channels are supposed to be constrained to 0.5w or less. Aside from that they can be correctly configured for 1-7 and 15-22, though they would still not be type-approved, so still in violation of the FCC rules, which not even the FCC has enforced against individuals historically. It would be impossible to distinguish a 5RM series configured technically correctly on channels 1-7 and 15-22 from a UV-5G Plus. Nobody could tell the difference. And on 8-14 it would be hard to know, though transmitting at 2w when you're supposed to stay under 0.5w is more likely to interfere with nearby repeater mains, so not a good practice.
<update>
If there is now a 5RM GMRS variant, that is probably going to be something very similar to the UV-5G Plus. And it may even be a type-approved radio. You could look it up in the FCC filing but it's a lot of work to find, and ultimately not worth the bother.
Thank you for the clarification
Thank you for the explanation helps out a lot.  Sadly seems like a lot of these radios are being falsely advertised on Amazon. No shock there I guess.
28 minutes ago, OffRoaderX said:
What part is false/what are they claiming?  When I look them up they just say they are H.A.M.s radios..
"Some people" seem to read between the lines too much, and miss the bigger picture....
says 5rm. But think it’s advertising GM-5RH.  I am probably wrong still learning that’s why I appreciate the forum to ask questions
If i had to guess if you ordered that radio, it would show up as a uv or ar 5rm.... if it says anything for 70cm, 1.25m etc, i would put money on it being the rm, not the 5g+, further more under the item spec i would dare say it very plainly lays out the rx and tx frequencies... just because it says gmrs in the title is not "false advertising".... a 5rm radio is capable of transmitting on gmrs... it may not be type approved, and it may not have a legit fcc part whatever cert.... but it will do it... LOL
Even the FCC doesn't seem to care about type-approval, although technically it's required for a radio to be approved for the frequencies upon which you transmit. What people DO care about is being a good and considerate user of the airwaves. As mentioned, on the "interstitial" frequencies (channels 8-14) you're operating very close to the repeater inputs and could potentially cause interference. Besides, it's a jerk move to jack up the power and walk all over everyone else trying to use the frequency.  I set my...err...I mean...if I were programming an AR-5RM to operate on GMRS/FRS frequencies, I'd set channels 8-14 to receive only. If there's a genuine emergency (defined by the FCC as an immediate threat to life or property and no other means of communication is available, it takes only a few seconds to turn on the transmit feature if you know what you're doing.
If you don't bring attention to yourself by being a jackwagon, nobody will know and few will care which flavor of 5RM you're using. However, unless you plan to eventually get an amateur radio license, most of the features of the ham variants will mean nothing to you and you'll get no use out of them. The wacky part is that sometimes it's cheaper to buy the ham version than the GMRS version, which is probably why a lot of people do it. Others do it because with some radios, the ham version will store 999 channels and the GMRS version will only store 30, which means you can only have 8 repeaters in the radio at a time. Apparently, the manufacturers think GMRS users don't travel and won't need more than a few repeaters programmed in. However, the UV-5G Plus claims to have the capability for 999 channels just like the AR-5RM.
I have a couple of AR-5RMs, and I like them a lot. I'd probably like the GMRS version too. I don't think you could go wrong with it.
