19 answers to this question
So that’s not “high gain” in any ones world.  And you really need to do some research’s BEFORE you put this up.  You may have local ordinances regarding grounding and how they want it done.  You may have home owners insurance issues.  This is the type of thing that can burn your house down.  Love the safety straps/harness and proper boots for climbing as well.
NEC says ground the Tower  to common ground, the same ground your radio equipment is grounded to, your main electric panel ground.  Some folks add a separate ground for the tower but NEC says to ground that to your common.   BTW, your antenna is grounded to the tower via the mounting so no you dont need to ground to antenna
44 minutes ago, Mrsig said:
I have a MA09 High Gain 462~467MHz GMRS Omni-Directional Base Antenna  4.5/7.2 dBi High Gain Fiberglass Antenna 5.75’ height. On a 30' tower do I need to put a  ground wire on this antenna?tower.thumb.jpg.05b76f6e40690bc2752a0d5372e8b356.jpg
You Need To Ground The Tower Leg. The Antenna Is Already Connected To The Tower For Grounding Purposes.
The Coaxial Cable Should Also Have The Shielding Bonded To The Single Point Ground System.
Unless You Have A Particular Type Of Commercial Antenna That Has Designated Grounding Straps At The Antenna - The Type Of Stick Does Not Matter.
A Lightning Arrester Is Also Recommended - PolyPhaser Makes An Excellent Arrester, Used Frequently On Commercial Radio Sites.
Proper grounding can only be achieved by using 500MCM wire. Using anything less is totally and utterly foolish and breaks all safety and grounding requirements.
That Sir, Is Not Correct. I Suggest You Do Further Research, And Consult The Motorola R56 Manual For Site Grounding Requirements For Commercial Sites.
See Link:
https://wiki.w9cr.net/images/1/14/Motorola-Standards-and-Guidelines-for-Communication-Sites-R56-Manual_68P81089E50-B.pdf
See Link:
The Motorola guide is their recommendation but not a NEC requirement, however their guideline does meet NEC grounding specifications.  To meet code, grounding requirements must meet the NEC
Suggest You Re-Read NFPA 70 - Chapter 810.15 Addressing Communication Site Grounding. (2023 Version)
I Am A Licensed Inspector In The State Of Michigan, & NFPA Is Recognized In All 50 States. (Year Of Adoption - Same As Previous Versions.)
NFPA 70 is also know as the National Electric Code  (NEC), whereas  NFPA 70E is a voluntary standard.   Surprised you didn't know that as a 'Licensed Inspector'   🤣
10 minutes ago, WRXL702 said:
No, Not Really - You Did Not.
When You Take The Time To Read NFPA 70 - Attempt To Understand It - Get Back To Me.
I'll stick with the national electric code...   at the end of the day, we should agree on everything..   Get Back to me there fella..
NFPA 70 Is The National Electrical Code Sir.....
or the National Electric code is NFPA..  Read..    Carry on      I told you at the end of the day we would agree, but stubborn you wanted to keep on arguing  😂
Wrong Again - No Lesson - A Mis Read On Your Part - Again.....
NFPA 70 Is The Standard For The Nation Electrical Code.
There is a very slight difference,  one protects the welfare of workers while doing installations and includes certain electrical guidlines, whiel the other outlines the actual electrical guidelines..  One of these guidelines came before the other.   I actually attended a class on this in 1986 and i still remember..   Do you know whichy guideline came before the other than adopted the one before?     You might have to do some studing on that one.     Carrry on
See Link:
Rubbish, that only points out the bare minimum requirements, but not what is optimal and yields a higher degree of safety and functionality. I look at the NEC the same way, a guide to get by with minimal effort. I've seen way too much substandard abominations the "met" code, but is an embarrassment to the trade. Plus, not all inspectors are created equal..
I wouldn't consider the NEC a 'bare minimum' but more so of a 'standard'  Some manufactures of electrical equipment may 'suggest' additional steps or recommendations beyond the 'standard' but defiantly not required..  However some manufacture may require their recommendations for warranty purposes but i dont know if any manufactures that do.
