Guest Jacob Posted 10 hours ago Report Posted 10 hours ago I'm trying to take the audio out from a BTech GRMS-V2 radio and take it to an audio-in on my PC. Does anyone have any solutions or ideas for making this work? My PC refuses to see it as an audio-in source. Quote
SteveShannon Posted 9 hours ago Report Posted 9 hours ago 1 hour ago, Guest Jacob said: I'm trying to take the audio out from a BTech GRMS-V2 radio and take it to an audio-in on my PC. Does anyone have any solutions or ideas for making this work? My PC refuses to see it as an audio-in source. You have to match levels and impedances. That’s frequently done using an audio transformer. What is the output impedance on your radio? It’s probably 8-16 ohms, but your manual should say. Is it a speaker output or a headphone output? They have different levels. What are the specs of your audio input on your PC? Amazon sells cables that match outputs to inputs, but you really need to know what you’re matching first. Another way to do this is by placing a speaker and microphone close to each other and letting them couple audibly, but there are drawbacks to that as well. Good luck, Jacob! Quote
