WRUE951 Posted June 6 Report Posted June 6 19 hours ago, WRVE426 said: No, but I will go to vendors who try to help even with a radio is out of guarantee. I have had good experiences so far with BetterSafeRadio and their latest KG-UV9GX+ looks rather sexy (see here: https://bettersaferadio.com/wouxun-kg-uv9gx-plus-gmrs-radio-shtf-scanner). And there are other vendors and distributors out there. There are always options even if BTWR think that they are irreplaceable BSR is just a vender for the Wouxun product. His warrantee options are based on what the manufacture supports for their products. My very first Wouxun KG935G i bought developed a dirty volume control potentiometer 2 months after the warrantee expired. Like you, i contacted the vendor i purchased from, (BuyTwoWayRadios) hoping for some leniency on the warranty but no luck.. They said the manufacture would not support a replacement.. But they did give me some tips how to correct the problem with simple contact cleaners, it worked and I'm happy. RoadApple 1 Quote
OffRoaderX Posted June 6 Report Posted June 6 Am I the only one thinking it's weird/irrational that the OP expects warranty support from a vender when the product is no longer under warranty and will angrily boycott that vender when denied free out-of-warranty support? or, maybe i'm just missing something? WRUU653 and WRXB215 2 Quote
WRYZ926 Posted June 6 Report Posted June 6 16 minutes ago, OffRoaderX said: Am I the only one thinking it's weird/irrational that the OP expects warranty support from a vender when the product is no longer under warranty and will angrily boycott that vender when denied free out-of-warranty support? or, maybe i'm just missing something? No you are not. One shouldn't expect a manufacturer or reseller to replace a defective product after any and all warranties have expired. I don't know of any manufacturer or reseller of any consumer products that will replace or fix (free of charge) any product after the warranty has expired. WRUU653, RoadApple, OffRoaderX and 1 other 2 2 Quote
Andrei Posted June 6 Author Report Posted June 6 28 minutes ago, OffRoaderX said: or, maybe i'm just missing something? yes, you missing the fact that you are arguing against a strawman (look it up). Quote
OffRoaderX Posted June 6 Report Posted June 6 2 minutes ago, WRVE426 said: you are arguing against a strawman (look it up) I looked it up but I am still confused. WRXB215 1 Quote
Andrei Posted June 6 Author Report Posted June 6 5 minutes ago, OffRoaderX said: I looked it up but I am still confused. yes, I figured you might but, no worries, you will get more radios to review from them, you've definitely earned it! thank God for the "ignore" option Quote
RoadApple Posted June 6 Report Posted June 6 As I read this thread, I'm now trying to figure out which issue is causing the burr under the saddle, the product(s) or the product support? I'm a simple guy, but it seems to me that unless extra $ was paid to a reseller for some level of warranty beyond what the manufacturer offers, you cannot expect the reseller to do much of anything! Now, for the sake of trying to cultivate some future business maybe the reseller could be a little helpful and talk to you or try to walk you through the setup to rule out operator error, and that would be nice, but that is not a responsibility on their part. You certainly cannot expect a reseller to fix or replace a product for free. Then there is the product itself not being of the quality you want or expect. If product quality is the issue, then it really doesn't matter which reseller you go thru for the purchase. For me, the lesson here is that when you buy a new product, you need to take the time to put it thru its paces and identify issues within the warranty period or forever hold your piece! Almost everything will fail eventually, and I've thrown away my share of failed equipment over the years. That is just the way it is.... WRUU653 1 Quote
Andrei Posted June 6 Author Report Posted June 6 1 hour ago, WRUE951 said: BSR is just a vender for the Wouxun product. His warrantee options are based on what the manufacture supports for their products. Exactly! So, for context, the first KG-Q10G I ordered had a defective GPS receiver. When I contacted BuyTwoWayRadios (not BetterSafeRadio!) they told me that they could not exchange the unit because they were sold out. They offered to send me a used unit which was given to them by Wouxun to test. I agreed. Tried the GPS - it was slow (not a real GNSS chip) and had a pretty bad design, but I did not really care. What I did not do is double-triple-check that the Channel Wizard did work properly. I got no error messages of any kind. However, much later, I did notice that for some reason, I could not hit some repeaters. So I sat down and tested it fully. I found out that others had the same problem, so I found a workaround: use the Wizard as indicated, then manually fix the frequency. I worked in IT long enough to know that code does not degrade over time, at least not by itself and for no reason. So I contacted BTWR again and asked them about it, and they told me that they never heard of any issues with the wizard and offered me to send them the radio for testing. That is when I told them that my model was already an exchange of a new for an old one. They replied "Oh that's interesting. Can you provide me that order number?" and when I did and suggested either an exchange or a rebate for my purchase of a brand new one. Why? 1) because that code error was not due to time passing, it was always there, I just spotted it too late and 2) I can still use the KG-Q10G even with a buggy wizard. Their reply was simply "there ain't nothing we can do, it is out of warranty". I had mistakenly assumed that finding out that the radio I had was a used radio sold to me for the full price, that would entice them to try a tiny bit harder. Instead it showed them the out of warranty date and they were done with that. I was naive, I admit. Now here is why I decided to ditch them: I did not demand or expect a new unit, and certainly not for free. But I did think that since they sent me a used unit to begin with (and sold me a defective unit originally) they would provide at least some kind of support. That is, after all, why BuyTwoWayRadios are advertised as "we are in Murica!! We offer Murican customer support, not that frustrating Chinese one!". LOL! You put it best (even if you confused the sellers): BTWR are "just a vendor" for a Chinese product. They offer exactly ZERO extra value. Once the Chinese warranty is done, so are these good Murican boys. That is my problem with them. That attitude. Some may like it. I don't have to! By the way, I had a similar problem with a Meshtastic device from Rokland and they immediately agreed to giving me a rebate for the purchase of new gear (by that time, mine was also out of warranty). So there are sellers out there which give you true extra value. And since I get go to BSR or another US seller (or even order from China or any other country, I have done that many times), I am happy with the outcome: I have a workaround and plenty of sellers to go to in the future. And if some "sad posters" think that a condescending tone is a substitute for expertise or if they think that BTWR does a stellar job giving us extra value, by all means, enjoy! From now on their "insightful comments" will go to my /dev/null I cannot say that this thread has been great fun, so I think that I am done, let the "sad posters" keep share their immense wisdom with anybody but me! Cheers Quote
Andrei Posted June 6 Author Report Posted June 6 3 minutes ago, RoadApple said: For me, the lesson here is that when you buy a new product, you need to take the time to put it thru its paces and identify issues within the warranty period or forever hold your piece.... yes, that was my mistake: I had assumed that the used testing unit they sent me was, actually, really tested. My bad. I will learn that lesson! RoadApple 1 Quote
WRUE951 Posted June 6 Report Posted June 6 2 hours ago, OffRoaderX said: Am I the only one thinking it's weird/irrational that the OP expects warranty support from a vender when the product is no longer under warranty and will angrily boycott that vender when denied free out-of-warranty support? or, maybe i'm just missing something? think it is wishful thinking and a slight attempt to gain some support.. It's not right to try to bash a vendor, especially when the vendor would be left $$ out of pocket. Hopefully the OP will understand that and move ahead without trying to hurt someone Quote
