Can not register on the Forum
Guest UserTrying2Register
I have been on mygmrs.com before, registered my callsign and have requested some repeater access in the past. When trying to login here on the forum I am greeted with a red box saying that I have not signed in before and need to create and account. I have tried several times over the past few months to register an account here on the forum and after I put in my callsign to verify, it comes up and says my callsign is already registered and shows me a green squared window with all my information in it. Underneath the block where you verify the callsign it states in red that my callsign is already registered to my callsign. Any help would be greatly appreciated. Screen shots can be provided if needed.
1 minute ago, gortex2 said:
Forum and main site are different. You need to register here as well.
I realize that and as stated above I have tried to register here on the forum multiple times.
I’ve reported your issue to the admin. He’s the only person who can help. What’s your call sign?
WRYE567
Guest WSHQ739
9 hours ago, SteveShannon said:
Okay, check your email to see if you received a password change link. Follow it, bla, bla, bla.
I have the same issue & reset password & followed instructions.  Still same issue.  I am told I have to create an account in forum but it won't let me saying I already have an account.
Okay, I reported your issue also.
  • 2 weeks later...
Guest WSIC904
I continue to have the same problem with accessing the forum.  The forum won't permit a photo of the screen shot displaying the error message.
I’ve reported this to Rich.
Thanks to Rich for running down the issue!  There was an issue with the e-mail used to register and using VPN.  Now, thanks to Rich, we are registered and able to post.
WSIC904/KB9VVT
ed WSIC904/KB9VVT
Interesting,,  are you seeing issues when you use your VPN?  I just recently started using Nord and i've been seeing all kinds of HTML issues after i started using it,  not just here but with other sites too..  I never suspected the VPN but next time will toggle it off to see if VPN is causing problems.
Good morning WRUE951!  Using the iObit iTop VPN sometimes affects logging onto some social media websites.  The VPN issue is that differing IP addresses show up and can be treated as BOTS or Spam.
  • 3 weeks later...
I had the very same issue today. Had to post a question as a guest as it would not let me set up a forum account with my call sign. (I quit using VPN on my laptop because I kept having to re-enter login info due to the changes in my ISP address.)
I’ve reported your issue.
I've noticed some weird things going on here too.  The last update he sent out was directing to the wrong repeater accounts when you taged on a specific account..  Ii.e. f you taged on a repeater in Ohio, it was directing to an a repeater in New York.   Weird things like that????
Reply to this topic...
