Playing around today after some severe storms we had yesterday. I've noticed this afternoon, that I am able to TX from the HA1G to the GM-30's no problem, however I am not RXing on the HA1G from the GM-30's. I originally thought the PTT was broken on the GM-30 but I tried a second GM-30 and have the same issue. I've assured there are no privacy tones on either radio. I've also factory reset all three radios and continue to have the same problem.
5 answers to this question
24 minutes ago, OffRoaderX said:
How close are the radios to each other when you are testing?
I did start with the radios next to each other. I left the HA1G inside and went outside with one of the GM-30's walked for a ways and tried again. Same result unfortunately. I'm not sure what I'm missing. I know they have worked together in the past.
If they were working a few days ago, you changed nothing, and suddenly they aren't working, then you aren't missing anything - they have both gone defective..
OR ....
You DID change something, you're on the wrong channels, or committing some other user-error.
Had that happen to my H3.  Was in a building and wanted to see if I could hit my repeater.  I couldn't.  It was strange cause I was pretty close by.  Then I drove by it and still couldn't hit it.  Somehow my tones got changed and all I had to do is restore them and bingo, success.
It can happen.
