TNFrank Posted July 20 Report Posted July 20 Normally I can hit the Shaw Butte repeater on North Mountain but for the last 2 days I get nothing, not even the static from the repeater opening. Does anyone know if they're still up or are they down for repair or something else? Thanks. Quote
TNFrank Posted July 20 Author Report Posted July 20 Ok, I feel dumb, I was TX on 462 and RX on 467. I need to swap those around. I should know better. Raybestos 1 Quote
TNFrank Posted July 20 Author Report Posted July 20 Well, after double checking and making everything right I still can't get a response to any of the 3 Repeaters in the area. I can normally hit Shaw Butte easily even from my Man Cave at the back of the house but none of my radios get a response. Now I am starting to wonder if they're down for some reason. Raybestos 1 Quote
TNFrank Posted July 20 Author Report Posted July 20 2 hours ago, WSAA635 said: Ok, I feel dumb, I was TX on 462 and RX on 467. I need to swap those around. I should know better. Or was I right all along. I had it working, now it doesn't work, not sure anymore. RX=462, TX=467, is that right? Quote
LeoG Posted July 20 Report Posted July 20 Yes. Transmit into the repeater on 467 and you will get a response on 462 Quote
nokones Posted July 20 Report Posted July 20 At the moment, I can only hit 550 Alpha and Sun City West 625. I usually have no problem hitting Shaw Butte, Towers 575 & 600, but not today. I suspect the problem child is back at it since Shaw Butte, and the two Towers repeaters are down. Quote
TNFrank Posted July 20 Author Report Posted July 20 2 hours ago, LeoG said: Yes. Transmit into the repeater on 467 and you will get a response on 462 I noticed a lot depends on the software I'm using. In CHIRP I enter 462 and it automatically adds the +5 offset to correct the TX to 467. With the Baofeng Factory software I have to manually enter the 467 TX and 462 RX. Even with everything correct I'm not getting any returns from anyone so maybe no one is monitoring the Repeaters. Quote
LeoG Posted July 20 Report Posted July 20 I'm not getting anything either. But I'm in Connecticut. TNFrank, GreggInFL, Seapup and 1 other 4 Quote
OffRoaderX Posted July 21 Report Posted July 21 Too bad our GMRS friend from So.Cal isn't around anymore, he always hit repeaters in Arizona, over 200 miles away... ..whatever happened to that guy anyway? SteveShannon and GreggInFL 2 Quote
amaff Posted July 21 Report Posted July 21 35 minutes ago, OffRoaderX said: ..whatever happened to that guy anyway? I just figured enough people had him blocked to where I wasn't even seeing replies to him anymore Quote
OffRoaderX Posted July 21 Report Posted July 21 4 minutes ago, amaff said: I just figured enough people had him blocked to where I wasn't even seeing replies to him anymore Either that, or ... someone here casually mentioned his GMRS callsign (which he had tried to hide after he got run-off the site last time).. Then everyone looking it up and seeing sh!thole where he lives, his full legal name, and pretty much everything else about him... He got real quiet right after that.. Quote
nokones Posted July 21 Report Posted July 21 12 hours ago, OffRoaderX said: Either that, or ... someone here casually mentioned his GMRS callsign (which he had tried to hide after he got run-off the site last time).. Then everyone looking it up and seeing sh!thole where he lives, his full legal name, and pretty much everything else about him... He got real quiet right after that.. Thank God that the closest affected repeater is 425 air miles, twice the distance of his 200 mile range capability from Phelan, I would think we would be well out of range especially with a hill or two in between the two points. Although, the two Crown King repeaters are at 7,800 feet in elevation, I guess there may be a slight possibility only for his radio. Quote
TNFrank Posted July 22 Author Report Posted July 22 Double and Triple checked my settings for the local Repeaters and I still can't get anyone. I wasn't having any trouble at all getting Shaw Butte but now, NOTHING. It's just crazy. Can anyone else in the Phoenix, AZ. area hit the Show Butte repeater and get a reply, 462.725/ TX CTCSS 100.0, none needed for RX. Quote
WRXL702 Posted July 22 Report Posted July 22 3 minutes ago, WSAA635 said: Double and Triple checked my settings for the local Repeaters and I still can't get anyone. I wasn't having any trouble at all getting Shaw Butte but now, NOTHING. It's just crazy. Can anyone else in the Phoenix, AZ. area hit the Show Butte repeater and get a reply, 462.725/ TX CTCSS 100.0, none needed for RX. Dude - Your Transmit Frequency For The Repeater Should Be 467.725MHz / CTCSS 100.0 - Not 462.725 MHz. Re-check Your Programming....... Quote
TNFrank Posted July 22 Author Report Posted July 22 46 minutes ago, WRXL702 said: Dude - Your Transmit Frequency For The Repeater Should Be 467.725MHz / CTCSS 100.0 - Not 462.725 MHz. Re-check Your Programming....... Yes, I know. In CHIRP you'd enter 462.725 and it'll automatically offset to TX to 467, my radios don't work with CHIRP, might be a WINE/Linux deal or something. In the Stock Software you enter 467 as the TX and 462 as the RX. Quote
nokones Posted July 23 Report Posted July 23 Shaw Butte and the two Towers repeaters are still down this morning. Quote
WSBR383 Posted August 1 Report Posted August 1 Unfortunately, all the non-member good repeaters are down in Phoenix area, don't know for sure why but I think I know.....Ug peeps always ruin a good thing. Quote
nokones Posted August 1 Report Posted August 1 8 hours ago, WSBR383 said: Unfortunately, all the non-member good repeaters are down in Phoenix area, don't know for sure why but I think I know.....Ug peeps always ruin a good thing. There was quite a bit of silly nonsense stuff going on early yesterday morning on Shaw Butte, and both Towers repeaters. I think I might have heard something on the 650 channel. It appeared to be simplex traffic since the repeaters are still down and signal level of this nonsense appeared to be at the same signal level at location I was in. Quote
TNFrank Posted August 2 Author Report Posted August 2 I checked a couple days ago and Shaw Butte was back up. For how long is anyone's guess. Quote
nokones Posted August 2 Report Posted August 2 9 hours ago, WSAA635 said: I checked a couple days ago and Shaw Butte was back up. For how long is anyone's guess. And it is back down again along with the two Towers repeaters Quote
TNFrank Posted August 2 Author Report Posted August 2 1 hour ago, nokones said: And it is back down again along with the two Towers repeaters Oh well, I really wish we knew what was going on. Quote
nokones Posted August 2 Report Posted August 2 Several days before the repeater owner shut down Shaw Butte and Towers 575, there was a lot of silly nonsense going and more than likely it spilled over to Towers 600. It usually does and the Towers 600 owner usually shuts down his repeater. Quote
WSEZ903 Posted August 4 Report Posted August 4 Funny thing is they typically transmit in simplex, so they are not even using the repeater. Once they hear him talking, the paparazzi gets on the air and mad chaos starts. Quote
WSDF209 Posted August 9 Report Posted August 9 Shaw Butte has been an issue for a long time. For a while there was someone with a 50w simplex in north Phoenix bantering with someone in south Phoenix through the repeater and it tied it up. I haven't heard anything for quite some time and I figured it had stopped. I haven't been on the radio for a few months but tried to test a new HT the last week of July and got nothing - not even squelch trail. It was working on the 26th because I was able to talk with someone near 7th and Dobbins from my home near 7th and Deer Valley. The same guy that owns Shaw Butte also owns diamond pointe and one near pinetop and both of those work perfectly so it's anyone's guess whats going on. Quote
