Baofeng UV-5G programming
I just bought a pair of these radios for outdoor purposes and I am trying to connect to a repeater.  I can't make heads or tails of it truthfully and need help.
Repeater information:
Frequency is 462.600
Input tone is 107.2
Output tone is 107.2
No permission required, the info is available to anyone on the map.
I am looking to program it, but again I feel like I took off a bit more than I can chew.  I am certainly a newbie at this.  Thanks for the help!
5 answers to this question
its very simple:
  • Select channel "REPEATER 17" (it may also be listed as Channel 24, or Repeater 24)
  • In the menu find the CTCSS/CTC TRANSMIT/TX setting and select 107.2
  • Forget about the output tone for now as its optional and will just confuckulate you
  • Save the change
  • Push the talk button, and enjoy using the repeater.
1 hour ago, OffRoaderX said:
its very simple:
  • Save the change
Hey there - im also having harad time - 1. Can you help with chirp settings? I think i got it right its TOne squelch 141.3 (WRQD476) and Duplex is +. 2. How to test repeater outside of hello callsign message. I am in its range but how to test f it goes through and noone is talkin? use 2 radios and try out of LOS communication around it?
