WSHI752 Posted 22 hours ago Report Posted 22 hours ago Just curious, but why don't GMRS mobile units have a PA option like some CB radios do? Quote
WRTC928 Posted 17 hours ago Report Posted 17 hours ago 5 hours ago, WSHI752 said: Just curious, but why don't GMRS mobile units have a PA option like some CB radios do? I can't imagine it being very useful. I don't think even most CBs include it anymore. Quote
nokones Posted 16 hours ago Report Posted 16 hours ago 6 hours ago, WSHI752 said: Just curious, but why don't GMRS mobile units have a PA option like some CB radios do? Why would you need a PA for? In most communities it is illegal to use a PA in a vehicle if you are not Public Safety. Quote
SteveShannon Posted 14 hours ago Report Posted 14 hours ago 1 hour ago, nokones said: Why would you need a PA for? In most communities it is illegal to use a PA in a vehicle if you are not Public Safety. For our rocket launches I am the LCO (launch control officer) who announces the launch, counts down, and then presses the launch button. The LCO is required to be able to command the attention of the spectators. I’m also the guy who has his mobile GMRS station setup there with a battery so I can talk to the the rocketeers who have walked out on the range to recover their previously launched rockets. It would be great if I could use the GMRS station as a PA. WRTC928, amaff and GreggInFL 3 Quote
GreggInFL Posted 13 hours ago Report Posted 13 hours ago 42 minutes ago, SteveShannon said: For our rocket launches I am the LCO (launch control officer) who announces the launch, counts down, and then presses the launch button. The LCO is required to be able to command the attention of the spectators. I’m also the guy who has his mobile GMRS station setup there with a battery so I can talk to the the rocketeers who have walked out on the range to recover their previously launched rockets. It would be great if I could use the GMRS station as a PA. Don't many mobile radios have an audio out port for an external speaker? Quote
amaff Posted 13 hours ago Report Posted 13 hours ago 9 minutes ago, GreggInFL said: Don't many mobile radios have an audio out port for an external speaker? yeah but that's a pretty different function than a PA, where you're talking into the mic and the same unit is outputting the audio, but louder. Quote
SteveShannon Posted 13 hours ago Report Posted 13 hours ago 8 minutes ago, GreggInFL said: Don't many mobile radios have an audio out port for an external speaker? They nearly all do for reception, but they don’t allow you to send your own amplified voice to the speaker. amaff 1 Quote
amaff Posted 13 hours ago Report Posted 13 hours ago 2 hours ago, nokones said: Why would you need a PA for? In most communities it is illegal to use a PA in a vehicle if you are not Public Safety. What would you need a Jeep for? In most communities it is illegal to drive off the pavement. See how that reads? SteveShannon 1 Quote
WRUE951 Posted 13 hours ago Report Posted 13 hours ago I remember that PA in my old PACE radio... Almost had as much fun plying the PA then on the CB Quote
GreggInFL Posted 13 hours ago Report Posted 13 hours ago 5 minutes ago, SteveShannon said: They nearly all do for reception, but they don’t allow you to send your own amplified voice to the speaker. Okay, good point. My DB25-G has a jack for a headset. Perhaps some bubble gum and bailing wire could somehow make that work. SteveShannon 1 Quote
nokones Posted 11 hours ago Report Posted 11 hours ago 2 hours ago, SteveShannon said: For our rocket launches I am the LCO (launch control officer) who announces the launch, counts down, and then presses the launch button. The LCO is required to be able to command the attention of the spectators. I’m also the guy who has his mobile GMRS station setup there with a battery so I can talk to the the rocketeers who have walked out on the range to recover their previously launched rockets. It would be great if I could use the GMRS station as a PA. That shouldn't be a problem. There are all sorts of ways to do that. Take a GMRS mobile, tap into the audio out port, run the audio through an amp onto a speaker horn. Simple basic manipulation of electrons that an engineer should be able to easily make happen. Let know how that turns out. Quote
SteveShannon Posted 11 hours ago Report Posted 11 hours ago 43 minutes ago, nokones said: That shouldn't be a problem. There are all sorts of ways to do that. Take a GMRS mobile, tap into the audio out port, run the audio through an amp onto a speaker horn. Simple basic manipulation of electrons that an engineer should be able to easily make happen. Let know how that turns out. Thanks, but apparently I didn’t explain my situation well. We are not trying to amplify the receiver audio. We already have a separate PA. I’d like to reduce the number of devices. Having a PA built into a mobile radio, like the old CB radios all seemed to have, would meet my needs well. Quote
nokones Posted 2 hours ago Report Posted 2 hours ago 9 hours ago, SteveShannon said: Thanks, but apparently I didn’t explain my situation well. We are not trying to amplify the receiver audio. We already have a separate PA. I’d like to reduce the number of devices. Having a PA built into a mobile radio, like the old CB radios all seemed to have, would meet my needs well. Oh, ok, even my new (2 Years Old now) Cobra 29 LTD Classic AM/FM CB radios have the PA switch and jack port in the back of the radio. Quote
