Tidradio DPL/DCS tone question
I'm trying program an open system repeater that is 8 miles away from me with a 051 DPL input/output tone into my Tidradio TD-H3 Plus. I tried it programmed with the 051N DCS code in the radio and I have not been able to hit it, I think I'm programming something wrong. Does 051 DPL correspond to 051N or am I supposed to use the DCS code list in my manual and look up 51 and select the corresponding DCS code (in this case D274N)?
4 answers to this question
I have the H3 and it's easy to program it.  Are both input and output tones the same?  If not reverse them just to make sure you aren't mistaken which one is the repeater input tone.  If both are the same then leave the Rx tone at none so you will receive the repeater output no matter what.
Yes, both input/output are the same. Not my first time programming/utilizing repeaters with this radio. The repeater must be out of service at this time. Not a lot of choices for repeaters on Cape Cod. Can't hit the two repeaters in Falmouth from Yarmouth.
can you reach the Plymouth 700 that might be near enough.
