Retevis RT97L 25W Repeater Duty Cycle
I watched the YT video on the Retevis RT97L 25W repeater ( Thank you @OffRoaderX ! ).  Unless I'm misunderstanding things, the video indicated that this repeater is intended for "lite use" and suggest that it may not have the duty cycle or capacity to serve as an open use general repeater.  The spec sheet says it has a "Transmitter Duty Cycle of 100%".
What does that really mean, and has anyone out there done any serious real-world general use testing with this specific repeater?
3 answers to this question
I suspect even when it supports a farming operation, it will be quiescent more than it's transmitting. There probably are business operations which could overwhelm it, but even the GMRS repeaters I consider pretty active near me spend a lot more time listening than transmitting.
