10 hours ago, WRUE951 said:
Wow,  check out this big bruit battery from Baoefeng and the price.    https://www.baofengradio.com/products/battery-5200mah-bl-5rhplus-usb?utm_source=Klaviyo&utm_medium=email
I have several of the 3,800 mAh batteries and they have enough juice for 24 hrs or so. That big battery should provide plenty of talk time. I have several radios that use the same battery. Maybe I'll buy one eventually.
the price is what blows me away..  I have two of the new Baofengs DM32 radios with 2500 mH  and i get an easy 2.5 days out of them, 3-4 in monitor mode.  That 5200 on a UV5 has to last an easy week for under 25 bucks..
Oh, yeah, I can get days on a 3,800 mAh battery if it's mostly on standby. With regular use, about 3 x 8 hr days. Or, I guess 24 hrs straight through, if you have enough stamina for that.
38 minutes ago, WRYS709 said:
Still having problems with this link; even on my Mac in addition to my iPhone.  Is it just me?
Do these work with the older style format: UV-5R, DM-5R and RD-5R?
It opens fine on my iPhone:
It's for the 5RM series.
Ok,thanks; no good for me then.
I am looking for an upgraded 5200 MAh USB-C battery for my DMRs; I just ordered the 3800 high capacity one with USB-C from Amazon:
2 minutes ago, WSDE760 said:
Is it safe to assume this will also work on an AR-5RM?
If it works on the older UV-5R, then NO..
If it works on any of the newer/bigger ones with the color screen, then, probably.
I am sending this one back!
It requires unscrewing and screwing the two screws each time.
On 8/27/2025 at 2:05 PM, Davichko5650 said:
Have to look at home. Work 'pooter won't let me access. But sure, I just got the 3800 MillerAmpHour ones for $15 a pair...
i hear you..  My businesss was starting to do that the last two years i was there back in 2022..   Kind of weird, they let people shop on Amazon all day long..
