Mr6453 Posted October 1, 2025 Posted October 1, 2025 How do I get the DB-20 to display both the name and the frequency of the same channel? Either using the front panel or CHIRP. Also, can this radio dual watch? Monitor 2 different channels at the same time? Thanks Quote
0 WRUU653 Posted October 2, 2025 Posted October 2, 2025 I have the Anytone version of this radio. If I use the mic shortcut keys and press “Fun” and then “8” it takes it out of dual mode into just one channel with the name listed in the upper section and the frequency listed in the lower section. WRXB215 and SteveShannon 1 1 Quote
0 WRYS709 Posted October 2, 2025 Posted October 2, 2025 8 hours ago, Mr6453 said: How do I get the DB-20 to display both the name and the frequency of the same channel? Either using the front panel or CHIRP. If you use your programming software, save the current version of your DB20-G setup. I put the date and time in the file name such as DB20-G 202510012300 If I remember correctly, try this: Press FUN - it should now show the Menu at the bottom of the screen Using the V/M and MAIN keys, go through the Menu items until you get to 29: DSPCHANNEL Using the Up and Down keys, change to FREQ Using the V/M and Main keys again, to to 19:DSPSUB Using the Up and Down keys, change to FREQ Press the FUN key to exit the menu system. If you use your programming software, save this version of the settings. Let me know if that works for you. Quote
0 amaff Posted October 2, 2025 Posted October 2, 2025 To display both the name and frequency, IIRC you'd set DSPCHANNEL (Menu 29) to Name, and DSPSUB (Menu 19....because that makes sense) to Freq. As @WRUU653 said, FUN + 8 on the mic takes it in and out of dual mode. WRUU653 1 Quote
0 Davichko5650 Posted October 2, 2025 Posted October 2, 2025 15 hours ago, Mr6453 said: Also, can this radio dual watch? Monitor 2 different channels at the same time? Thanks Yes it can _ i use it to watch either 2 GMRS SImplex Frequencies or 1 GMRS Simplex and 1 Amateur repeater. Quote
0 Mr6453 Posted October 3, 2025 Author Posted October 3, 2025 Thanks for the help. Appreciate it. Quote
Mr6453
Thanks
6 answers to this question
