AlligatorClick Posted February 15, 2019 Report Posted February 15, 2019 Hello; I'm new and shopping for my first GMRS hand held radio. I want this to be dedicated GMRS without the limitations of FRS. What is the max wattage legally allowed to transmit on GMRS and what is a good model hand held? Quote
0 haneysa Posted February 16, 2019 Report Posted February 16, 2019 I have the BTECH GMRS-V1. It is FCC Part 95 compliant. Mine do not put out the 5 watt limit for handheld radios. The put out around 3 watts on high (on my MFJ cross-needle SWR meter). They can be "programmed" from the front panel or with a special USB interface cord (same one as for the Baofeng UV-5R and BF-888S). Motorola, Kenwood,Vertex, ICOM ( and a few others) make radios that can be programmed to operate on GMRS,and that are also Part 95 certified, however, programming can be tricky, and might be best left to a radio shop. I am sure some others on the forum will let you know if they have done this. I know that these "name brand"radios are going to be more rugged than the GMRS-V1, and they will probably put out 4-5 watts. I am very satisfied with the GMRS-V1,especially with the price. cateyetech and AlligatorClick 2 Quote
0 berkinet Posted February 16, 2019 Report Posted February 16, 2019 Note: More power out the antenna equals more drain on the battery. So, even though a radio like the GMRS-V1 might only output 3 watts, if that is all you need for your uses then it is fine. Bigger is not necessarily better. In particular, if you are using a local repeater, less power is often a plus. cateyetech, RCM, Logan5 and 1 other 4 Quote
0 Elkhunter521 Posted February 16, 2019 Report Posted February 16, 2019 Amazon sells a Btech battery for the Gmrs-v1.Its 3600 mAh, and sells for $20. They also a battery replacement pack to plug into a vehicle accessory receptacle for $16. Note: get the Bl-8 not the Bl-5 berkinet 1 Quote
0 berkinet Posted February 17, 2019 Report Posted February 17, 2019 Amazon sells a Btech battery for the Gmrs-v1.Its 3600 mAh, and sells for $20. Note: get the Bl-8 not the Bl-5 Thanks for this tip. The ability to use alkaline batteries is perfect for emcomm applications where there may be no time or facilities to recharge batteries. Quote
AlligatorClick
Hello;
4 answers to this question
