Glider Posted April 18, 2019 Report Posted April 18, 2019 Looking at the Kenwood TK-8180H radio.It lists:Frequency Range Type 1 - 450~512 MHzFrequency Range Type 2 - 400~470 MHzWhich one would I want/need for full GMRS access and repeaters? Sorry for the novice question. Quote
Durake Posted April 18, 2019 Report Posted April 18, 2019 I recommend 400-470 if you think you'll eventually get your Ham license or would like to monitor Ham. If not then 450-512 is fine, but I've never had a need to go past 467. They both work the same for GMRS since GMRS is just 462-467. revclstoner, SteveC7010 and Logan5 3 Quote
Glider Posted April 18, 2019 Author Report Posted April 18, 2019 I recommend 400-470 if you think you'll eventually get your Ham license or would like to monitor Ham. If not then 450-512 is fine, but I've never had a need to go past 467. They both work the same for GMRS since GMRS is just 462-467.Thank you so much - There is a guy selling new Kenwood TK-8180H Frequency Range Type 2 - 400~470 MHz for a decent price with Laird NMO mount and some weird antenna for what seems to be a very fair price. Quote
JohnE Posted April 18, 2019 Report Posted April 18, 2019 even if you go w/range 1 the vco can be adjusted to go into 70cm ham.my 880's and 8180's have both T-band and ham in them 440 - 482. Quote
Jones Posted April 19, 2019 Report Posted April 19, 2019 While they will both TECHNICALLY work in the GMRS band, I believe the type 1 is Part-95 certified for use on GMRS, but the type 2 is not.Check the FCC ID numbers of both. Source:Type 1 https://fccid.io/K4437313210Type 2 https://fccid.io/K4437313220 ratkin 1 Quote
Glider Posted April 19, 2019 Author Report Posted April 19, 2019 More good information - Love this place, so helpful. Thank You. Quote
revclstoner Posted April 22, 2019 Report Posted April 22, 2019 I recommend 400-470 if you think you'll eventually get your Ham license or would like to monitor Ham. If not then 450-512 is fine, but I've never had a need to go past 467. They both work the same for GMRS since GMRS is just 462-467. I second this comment! Durake 1 Quote
