ran across this looking for a customer. would have to ask on the connectors as I'm not sure what ones would be compatible w/cables. I would imagine it would either be RFS or Andrew/Commscope.
http://www.tessco.com/products/displayProductInfo.do?sku=94526&eventPage=2
http://www.tessco.com/products/displayProductInfo.do?sku=397793&eventPage=3
***update***
connectors are only available from the manufacture.
http://www.eupen.us/mm5/merchant.mvc?Screen=CTGY&Store_Code=EUPEN&Category_Code=1_2_Conn
http://www.eupen.us/mm5/merchant.mvc?Screen=CTGY&Store_Code=EUPEN&Category_Code=7_8_Conn
Well I missed this deal. I just got a used 75 foot run of TM-LMR600, 125 shipped with male type N connectors. is slightly more flexible than hardline.  still planning the install. I would love 7/8" but will have to live with this for now.
***update***
John,
If you run across any ldf4.5 N connectors let me know it has to be Andrews,Commscope will not work on the older Andrews...William
John,
I had a friend give me over 120ft of the LDF4.5-50 or 5/8 Heliax but I am having a problem finding some N connectors for it.I have looked all over this area with no luck to no avail.I noticed Tessco does have them but I am not sure if the Commscope brand will work for the Andrews.If you have any clue let me know I do have a account with Tessco so no problem there.
If anyone else has access to and 5/8 Andrews left me know please @ 1.0 loss at 450mhz this should work perfect...William
  • 4 months later...
JohnE there gave a good place for your Heliax connectors. I've used them before & have nothing but good to say.
SPD641,
How long of a run do you have? Ecoflex 15 & Aircocomm are 2 coax (Aircomm uses air cell dielectric) with fabulous loss numbers @ 100 meters
Not as low as Heliax but for the cost I have no complaints. If you have a 200'+ run then I suppose I'd go for the Heliax as well...
Just curious mainly..this for a repeater?
Guest spd641
LAMBSONB60,
I have a 100ft run I need to swap out so I will have cable left over and found the real Andrews connectors on eBay just trying to figure out if I need the whole lot or not.
