High SWR and reflected power using repeaters
Recently installed a Browning BR-6146 in my attic. I used 1/2 heliax 55 feet and Belden 9914 as the jumpers to and from the heliax. All connectors are N except at the radio(PL-259 for Midland MXT-400). SWR is great across the board (never more than 1.07), until I get to repeaters. Then the SWR jumps to 1.35 and almost to 1.95 on higher power output applications. The reflected power is high as well.
My question is: is this a result of the installation being in an attic? Or is this Browning some type of Jpole that needs ferrite magnets or a coil of wire at the antenna to remedy?
5 answers to this question
The antenna should work fine. Do you have asphalt shingles? Some folks have metal roofing and/or trim and overlook that. Especially flashing materials and face boards.
Make sure the antenna is at least 6 feet away from any metal or electrical lines. That includes any metal outside on the roof and side of the house.
The antenna does seem to work fine. I just find it odd that I got that result. I have asphalt shingles, no metal on the roof, and a UHF TV antenna that’s about 10 feet away. It’s also mounted very high as I have a steep roof pitch that allows me to get it up as high as I can reach. I just like knowing how and why things work. Thank you for the input.
Try putting some toroid chokes on that 9914 jumper at the base of the antenna.  It sounds like it is working fairly well anyway.
