Could I put a base antenna on my 4g cell booster mast?
3 answers to this question
Sure. Why not? GMRS at 462MHz is not going to cause any trouble with your 820-890MHz 4G antenna.
4G has many bands which vary by carrier. None are in the 400-500 MHz range of course, so it should be okay as long as harmonics don't pose an issue with one of the bands. Even so, that usually wouldn't be catastrophic to 4G as I believe multiple bands may be leveraged concurrently depending on the area.
