Kenwood tk880 no audio, or voice
I have a Kenwood TK-880.  The audio and voice aren't working.  I can hear when I hold the monitor button.  It worked when I bought it.  I think I messed something up using the up/down keys on the right side.  Any ideas?
8 answers to this question
i'm not familiar with the model (i'm sure there are some here that are) to tell you exactly where to find the setting.
that said, since it works when you hold the 'monitor' button, that sounds like it's something with your squelch setting, either looking for a tone, or level set too high. there's some info on page 6 here (if you don't have a manual)
http://www.repeater-builder.com/kenwood/pdfs/tk-880-svc-man-rev-e.pdf
You likely may have changed the tone settings or OST. If you are unsure what happened or how, it may be best to simply re-program the radio with an older code plug you know works. This would rule out the user (programmed) side if the radio still does not give audio.
I'm not familiar with code plugs.  I only have the one GMRS radio.  Can you suggest the software that I need?
Really liked my 880 until I toasted it by ripping the antenna off and trying to transmit.. sizzle.  Have replaced with 8180.  Below is info on all you should need for the 880.
Software
KPG-49D
https://hamfiles.co.uk/index.php?page=downloads&type=entry&id=radio-programming%2Fkenwood-programming%2Fkenwood-kpg-49d-rss_2
Programming cable:
https://www.ebay.com/itm/FTDI-USB-Kenwood-Programming-Cable-TK-780H-TK-880H-TK-980-TK-981-KPG-46/163486194020?hash=item2610895964:g:lfAAAOSwARxfZCD5
Manual:
https://www.manualslib.com/k/kenwood+tk-880.html
Thanks for all of your help.  I now have audio, but I can't transmit and for some reason, I can't program my radio from my computer.
Happy holidays
sounds like the RJ45 port (where the mic/programing cable plugs in) is bad, or one of the solder pads cracked. Simple fix if you know how to.
