#1
Posted 17 December 2020 - 07:48 PM
Can anyone enlighten me if this is a safe setup? And if not what NMO antenna should I get?
Thanks in advance
#2
Posted 17 December 2020 - 08:24 PM
Modifying a dual band antenna is not for the faint of heart.
Purchasing one designed for GMRS frequencies is what I recommend. I personally use the Midland MXTA-26A GMRS antenna and have zero complaints.
Michael
WHRS965
KE8PLM
- SteveC7010 and digitaldevo like this
Michael
WRHS965
KE8PLM
#3
Posted 17 December 2020 - 08:33 PM
#4
Posted 17 December 2020 - 09:11 PM
It is possible it would work but it is not tuned for GMRS. Antennas that are not tuned for the frequencies you transmit on present a higher SWR to the radio. The higher the SWR, the stronger the signal reflected back from the antenna to the radio. Some folks have reported for example that Midland GMRS radios can only handle a max SWR of 1.5:1 and anything more than that warranty is void. If that is true and you put an antenna on that exceeds that value you are living on borrowed time.What antenna would you suggest? Because I was told by other Ham guys this would work on both. So I'm lost now. Lol
Some radios can handle SWR upwards of 3:1. (Some high power expensive amateur rigs have built in automatic antenna tuners). High SWR support is great on one hand as it means the radio will survive and your investment is reasonably protected from a poorly tuned antenna. On the other hand, an unnecessarily high SWR number means you are wasting extra power in your cable, thus reducing your range.
If you had a quality SWR meter and you have confirmed it was within a safe range for your radio, buy all means use it. If you do so without verifying, by all means put your radio in lowest power mode to prevent letting the magic smoke out.
BTW, about a month ago I checked my personal Comet Dual Band Amateur antenna with an antenna analyzer for the exact same reason as you. While I do not recall the exact number, I concluded it was too high risk for my radio. So I carry two antenna in my car. I swap them as needed to suit the service I want to use.
Regarding antenna recommendation. I shared that I personaly use the Midland MXTA-26A. I have no complaints with it. I would buy it again.
Welcome to the world of radio.
Michael
WRHS965
KE8PLM
- digitaldevo likes this
Michael
WRHS965
KE8PLM
#5
Posted 17 December 2020 - 09:15 PM
#6
Posted 17 December 2020 - 09:26 PM
Midland MTXA26 user here as well happy end user so far use it as a mobile and repeater/base antenna.
#7
Posted 17 December 2020 - 09:35 PM
#8
Posted 29 December 2020 - 12:58 PM
Just added the Midland to my cart. Will order it after Christmas. Thank you both.
Michael
WRHS965
KE8PLM
#9
Posted 29 December 2020 - 01:07 PM
Yes. I got the Midland MTXA26 antenna and the little Tram both.Its after Christmas. Have you ordered your antenna yet.
#10
Posted 29 December 2020 - 01:08 PM
Michael
WRHS965
KE8PLM
#11
Posted 29 December 2020 - 01:48 PM
Also tagged with one or more of these keywords: Antenna
General Mobile Radio Service (GMRS) →
Technical Discussion →
Slim Jim NewbieStarted by davidrayt , 16 Feb 2021 ![]() |
General Discussion →
Antenna mount locationStarted by WRKS617 , 08 Feb 2021 ![]() |
433 specific antenna working perfectly on MURS ! ? Huh ?Started by JCase , 27 Oct 2020 ![]() |
Installation/Mounting in vehicleStarted by Savage , 20 Sep 2020 ![]() |
Comet GP-1 or Diamond X50AStarted by krvw , 07 Feb 2020 ![]() |
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
