WQTK732 Posted May 28, 2014 Report Posted May 28, 2014 Can we use this with a gmrs repeater? If I'm out at say the mall can I use it to get into my rptr? Thanks Sent from my SM-G900V using Tapatalk Quote
Shriekmau Posted May 28, 2014 Report Posted May 28, 2014 I believe the answer is "no". The station broadcasting would need both licenses. GMRS and Ham can relay, but I do not think they allow for cross band repeat between the two. Now, you could use cross band for something like MURS and GMRS as long as the repeater operator has a GMRS license and the MURS side did not transmit at more than 0.5 watts. Quote
quarterwave Posted May 29, 2014 Report Posted May 29, 2014 In the United States, the Multi-Use Radio Service (MURS) is an unlicensed two-way radio service similar to Citizens Band (CB). Established by the U.S. Federal Communications Commission in the fall of 2000, MURS created a radio service allowing for unlicensed (Part 95) operation, with a power limit of 2 watts. The FCC formally defines MURS as "a private, two-way, short-distance voice or data communications service for personal or business activities of the general public." MURS stations may not be connected to the public telephone network, may not be used for store and forward operations, and radio repeaters are not permitted. Industry Canada (IC) established a five year transition plan, which will permit the use of MURS in Canada starting June 2014.[1] IC has not yet published rules for MURS, other than frequency limits. Quote
WQTK732 Posted May 29, 2014 Author Report Posted May 29, 2014 I'm not planing on using another service I would use the gmrs to gmrs so I'm not sure where all that came from lol Sent from my SM-G900V using Tapatalk Quote
Shriekmau Posted May 29, 2014 Report Posted May 29, 2014 Cross band repeat specifically means to broadcast a signal on one band that was received on another. GMRS only operates within one band, so to cross band repeat with GMRS would mean one side or the other would not be operating on GMRS. Quote
WQTK732 Posted May 29, 2014 Author Report Posted May 29, 2014 Ok so I'll be in banding then lol Sent from my SM-G900V using Tapatalk Quote
PastorGary Posted May 29, 2014 Report Posted May 29, 2014 Another thing to consider is that using the output of one GMRS repeater to activate the input of another GMRS repeater is not allowed under current regulations. Repeater input and output frequency availability is regulated and there is a 5 mhz offset between the 467 mhz repeater input channels and their corresponding 462 mhz repeater output channels. To have one GMRS repeater activate another repeater by RF signals alone, would require that one repeater operate in reverse mode. That is not allowed. Channel paring is covered in 47CFR95.29 [a] and and specifically says: {a.} For a base station, fixed station, mobile station, or repeater station (a GMRS station that simultaneously retransmits the transmission of another GMRS station on a different channel or channels), the licensee of the GMRS system must select the transmitting channels or channel pairs (see §95.7(a) of this part) for the stations in the GMRS system from the following 462 MHz channels:462.5500, 462.5750, 462.6000, 462.6250, 462.6500, 462.6750, 462.7000 and 462.7250.{ b.} For a mobile station, control station, or fixed station operated in the duplex mode, the following 467 MHz channels must be used only to transmit communications through a repeater station and for remotely controlling a repeater station. The licensee of the GMRS system must select the transmitting channels or channel pairs (see §95.7(a) of this part) for the stations operated in the duplex mode, from the following 467 MHz channels:467.5500, 467.5750, 467.6000, 467.6250, 467.6500, 467.6750, 467.7000 and 467.7250. Hope that helps if this was being considered as well. Quote
Guest spd641 Posted May 30, 2014 Report Posted May 30, 2014 Crossbanding GMRS to any band is not allowed no matter what power output or what service it is..........William Quote
WQTK732 Posted May 30, 2014 Author Report Posted May 30, 2014 Gmrs to gmrs is Sent from my SM-G900V using Tapatalk Quote
Guest spd641 Posted May 30, 2014 Report Posted May 30, 2014 How are you going to crossband 2 UHF frequencies.You have to be using to different bands to crossband.If you do as you are talking about it is in band repeat GMRS to GMRS and it would be the same as having a regular repeater unless you use simplex repeat which may be what you are thinking about.I am not sure what you have configured so please let us know...William Quote
WQTK732 Posted May 30, 2014 Author Report Posted May 30, 2014 What am saying I'm gonna do is use a simplex gmrs freq to my repeater kind of deal..... Quote
WQTK732 Posted May 30, 2014 Author Report Posted May 30, 2014 Ummmmmm nope I'm good but hey. Thanks for your help Sent from my SM-G900V using Tapatalk Quote
Guest spd641 Posted May 30, 2014 Report Posted May 30, 2014 What am saying I'm gonna do is use a simplex gmrs freq to my repeater kind of deal.....Why not save all the trouble and just build a regular GMRS repeater,the way you are describing what you want to do it sounds like that would be the answer.I do not think what you have planned is with in the rules of GMRS...William Quote
WQTK732 Posted May 30, 2014 Author Report Posted May 30, 2014 I have one and its been up for a few months all I wanna be able to do is if I have my ht and I'm in a area where I know my coverage is not the best I wanna be able to get into my rptr via more power. Sent from my SM-G900V using Tapatalk Quote
PastorGary Posted May 30, 2014 Report Posted May 30, 2014 Does your repeater system have a RECEIVER preamp? That's one way to enhance the access range of the system without too much expense. Please check with John E. - I believe that he mentioned something about those receive preamps awhile ago. Quote
JohnE Posted May 30, 2014 Report Posted May 30, 2014 https://forums.mygmrs.com/index.php/topic/66-rx-pre-amps/ Quote
