tornhat Posted January 11, 2021 Report Posted January 11, 2021 Hey people Anybody know if you are able to skip channels on the 115I don’t see it in the manual it all maybe I missed it Quote
H8SPVMT Posted January 12, 2021 Report Posted January 12, 2021 I'm new here too.Trying to learn what I can. I own a Midland MXT400 but don't understand the term you're using in, "Skip channels."I'm thinkings you want to just listen to two/scan two or more, channels and not cycle thru all the avaliable channels? Quote
tornhat Posted January 12, 2021 Author Report Posted January 12, 2021 Hi I have a couple mobile and some handheld that have dual watch on it no problem with them just The mxt115 you can stop on the channel you wanna listen to but there’s no Duel watch on it I only use two channels 575 and 600 repeter I would love to skip all the rest but I don’t think you can like on the MXt 400 I can skip channels (base station)I just have the last eight repeater channels customize with the name of the towns per ch Quote
H8SPVMT Posted January 12, 2021 Report Posted January 12, 2021 HiI have a couple mobile and some handheld that have dual watch on it no problem with them just The mxt115 you can stop on the channel you wanna listen to but there’s no Duel watch on it I only use two channels 575 and 600 repeter I would love to skip all the rest but I don’t think you can like on the MXt 400 I can skip channels (base station)I just have the last eight repeater channels customize with the name of the towns per chPlease, if you don't mind, how do you skip channels on the MXT400?I only understand that I can set a channel to monitor, then scan all the others. I have very a limited use of FRS/GMRS in my area at all. My radio is mounted in the Jeep so it is mobile and not a base station. Quote
tornhat Posted January 12, 2021 Author Report Posted January 12, 2021 In order to get inside your radio to make it how you like it you have to get a data cable then download the software to add or take away changes it’s not gonna do anything to go outside the GRMS protocol per FCC I found a download link somewhere on this form for the MXT 400 I don’t have it on my phone or my computer hope it helps Quote
WRJZ943 Posted January 14, 2021 Report Posted January 14, 2021 I'm not sure on the MXT 115, but my MXT90 can. I have to go to each channel and press,hold the scan button for a second or two. When I release the button the scan icon no longer appears on the display. When I scan frequencies it will jump those channels I've removed. Repeat the process to add channels back. I've found this isn't possible on theMXT275. My MXT 275 won't even scan repeater channels after they've been enabled. With the MXT400 it's capable, but only with the software. Quote
tornhat Posted January 14, 2021 Author Report Posted January 14, 2021 Thank you I will try that unfortunately it’s in the shop and I’m off today hope it works Todd Wrdn973 Quote
Citizen Posted January 15, 2021 Report Posted January 15, 2021 I have an MXT115. I too searched the manual and could not find that you can set up a channel to skip during scanning. I also have an MXT105, which does have this feature. So I thought it might be similar, so I tried some key combinations, but I cannot get the MXT115 to skip a channel. Sorry, nice feature that Midland seemed to have forgotten. ... WRJZ943 1 Quote
tornhat Posted January 15, 2021 Author Report Posted January 15, 2021 Thanks I’ll switch it out with the AT779uv Quote
