Arrow beam antenna test
OldRadioGuy
I have an Arrow portable "take down" beam antenna intended for 440MHx/70cm ham radio.
I bought this antenna for my ham radios, before I had GMRS.
Mine is the dual band version with a second set of elements for 2M but otherwise identical to the link below.
http://www.arrowantennas.com/arrowii/440-7ii.html
I finally got around to checking the SWR with my Wouxun 805G.
It was very good - like darned near a perfect 1:1.
My output power was actually a bit higher than with other antennas I've tested so somehow this antenna seems to "tickle" the 805G just right.
Maybe the 805G is not a perfect 50 ohm output but this antenna is a near reciprocal match????  I'm just reporting the data.
I did not talk to anyone on it but triggered the repeater 15 miles away.
So I know it was transmitting.  That repeater is hard to hit on a simple 1/4 wave antenna with 5W.
My meter is an MFJ-842 set on the 10W range.
I had about 6' of RG-58 coax in the path.
Hams use RG-58 awith BNC connectors for short runs all the time on 440Mhz.
Vince
2 answers to this question
I looked at the web site to see if there are any gain figures published, didn't see any for that Yagi.
Have you considered a "corner reflector" type antenna? They look like the old style UHF TV antennas, the ones with a "Vee" shaped reflector.
I've done some simulations using EZNEC+ software. If you're into modeling, building or just plain curious about antennas this is a good software package to use. Not too expensive. There is a free demo version.
https://www.eznec.com/
A few of the UHF corner reflector models I built show a real gain of 11+ db over a dipole if optimized a bit. The bandwidth seemed wider than the 11 Yagi I modeled from M Squared antennas. The horizontal side lobes seems small and the vertical side lobes were reasonably small.
Arrow also sells corner reflectors too.
http://www.arrowantennas.com/solid/cr4501.html
With a corner reflector you don't have to worry about the metal mast buggering up the match or ruining the gain of the antenna since the mast is always behind the reflector.
