AdorkableRen Posted April 28, 2021 Report Share Posted April 28, 2021 Can anyone help me program a midland mxt275 for a repeater. I have the rx frequency and the code for it. But I can't seem to hear anything or even speak on it. But it shows up in simplex mode. I'm new to this so a little confused. Any help would be appreciated. Quote Link to comment Share on other sites More sharing options...
wayoverthere Posted April 28, 2021 Report Share Posted April 28, 2021 Midland makes you enable the repeater channels in the menu first...there's a recent thread on the same topic here:https://forums.mygmrs.com/topic/2673-new-to-gmrs-got-a-midland-mxt275/?fromsearch=1 Quote Link to comment Share on other sites More sharing options...
Extreme Posted April 29, 2021 Report Share Posted April 29, 2021 I just downloaded the manual for the 115 a buddy has on order. Guessing the 275 would be same procedure. Enter CTCSS codes for the appropriate repeater when done. "Privacy Codes" in Midland nomenclature. ------------------------------------------ Repeater Channels Your MXT115 has the ability to access repeater channels. The use of a repeater can significantly increase a radio’s range and coverage area. Prior to using a repeater you must coordinate with the owner of the repeater to gain permission to use the repeater. Be sure to understand and follow the sharing and usage rules for each repeater system. To Set the Repeater Channel: 1. Press and release the Menu button to place the radio in “Menu” mode. 2. Use the Channel Up or Channel Down button to scroll through the menu options until the LCD display shows rP 3. Press the Monitor/Scan / button to confirm your selection. 4. Use the Channel Up or Channel Down button to select ON or OFF. 5. Press the Monitor/Scan / button to confirm your selection. YOU MUST PRESS THE MONITOR/SCAN BUTTON TO CONFIRM YOUR SELECTION OR THE REPEATER CHANNEL SELECTION WILL NOT BE CHANGED ▪▪ When activated the repeater channels will be displayed as the channel number (Ex. 15,16,17,ect.) and the rP icon ▪▪ Repeater channels will appear immediatly following the standard GMRS channels (ex: 20,21,22,15rP,16rP17rP etc) Quote Link to comment Share on other sites More sharing options...
Extreme Posted April 29, 2021 Report Share Posted April 29, 2021 Also, not all repeaters ID when activated. Listen for a simple squelch break. Quote Link to comment Share on other sites More sharing options...
Extreme Posted April 29, 2021 Report Share Posted April 29, 2021 Midland assigns digits to correspond with CTCSS Freq. Most common for repeaters is 141.3 (22) but be sure to verify. Quote Link to comment Share on other sites More sharing options...
