Riktar Posted July 4, 2021 Posted July 4, 2021 I need the ribbon cable that connects the "faceplate" to the main body for a Kenwood TK8180 radio. I have searched online but am coming up with conflicting results. Anyone have a spare laying around? Quote
0 Extreme Posted July 4, 2021 Posted July 4, 2021 https://www.pacparts.com/model.cfm?mfg=Kenwood&model_id=TK8180&row_start=1&src_model_id=tk-8180&action=list_part 2 Flex Cables on this page. If you've had the faceplate off you should know which you need. Quote
0 Riktar Posted July 4, 2021 Author Posted July 4, 2021 Thanks for the reply. I have taken the faceplate off and compared the ribbon cable in the radio to the 2 listed on Pacparts website and neither matches the numbers/specs I have on my existing cable. This is why I am not confident in ordering either. I suppose I could just order both since they are only 6 bucks and change for each. But it would be nice to just order the correct one and be done with it... Quote
0 okinater Posted July 4, 2021 Posted July 4, 2021 I believe one ribbon is for the KRK-10 and the other is for a front mount configuration. Riktar 1 Quote
0 WRNA236 Posted July 5, 2021 Posted July 5, 2021 18 hours ago, okinater said: I believe one ribbon is for the KRK-10 and the other is for a front mount configuration. I have a TK-8180 and KRK-10. The stock ribbon cable between the face and body was part number E37-1120-05 and has description of FLAT CABLE (30P/TX-RX). You leave this ribbon in place and add a couple of folds when installing the KRK-10. The kit includes a new ribbon for the face side of the kit. Either way the description matches close the Pacparts part number 880H04-8897-72 which has description of Flex Cable (Display - Tx/Rx), that substitutes to 881H04-8116-92. It also looks the same as the original ribbon, which has no folds originally. The other ribbon shown in the service manual is E37-1110-05 and is called FLAT CABLE (30P/D-SUB). That connects the 25-pin D-Sub on the back to the PCB in the body. That description matches the other cable part number 880H04-8887-72 Flex Cable (Tx/Rx - D-Sub) that subs to 880H04-8115-72. Riktar 1 Quote
Riktar
5 answers to this question
